How to Optimize Predictive Models: Include Interactions or Not?
  • Context: Graduate
  • Thread starter Thread starter FallenApple
    Prediction
The discussion revolves around optimizing predictive models, specifically whether to include interaction terms among variables in the model. Participants explore various methodologies for model selection and evaluation, including the use of AIC and cross-validation techniques. The conversation touches on both theoretical and practical aspects of predictive modeling.
  • One participant suggests starting with a full model that includes all variables and then using stepwise AIC for model reduction, questioning whether to include interaction terms.
  • Another participant argues against using AIC for prediction, advocating for direct evaluation of prediction error through cross-validation instead.
  • A follow-up post raises the issue of model selection when no specific models are initially considered, proposing the idea of generating a complete model with all possible interactions.
  • One participant introduces the concept of fitting a full model with penalties to prevent overfitting, mentioning elastic-net regression as a potential method for automatic variable selection.
Participants express differing opinions on the best approach to model selection and evaluation, particularly regarding the use of AIC versus cross-validation. There is no consensus on whether to include interaction terms in the model or how to handle model selection when starting without specific models in mind.
Some limitations are noted regarding the computational complexity of comparing all possible models and the potential for overfitting when including many interaction terms. The discussion also highlights the dependence on the choice of evaluation metrics and modeling techniques.
This discussion may be useful for data scientists, statisticians, and researchers interested in predictive modeling techniques and the implications of model selection strategies in their analyses.
FallenApple
So say I want to predict the next point in the data.(or outside since its prediction)
So first, I would include all the variables inside the dataset into the initial model. Then I would use stepwise AIC to iteratively reduce the model down to the final model with minimum AIC. ( I can do this because I do not care about causal explanation, just about prediction)
Now, should the large model consist of just sums of the variables, or should it also include all possible combinations of interactions as well?
Finally, what do I with the final model? Do I just interpret the estimates and confidence intervals as usual?
If you want to do prediction, why use AIC? Why not evaluate prediction error directly? Cross-validation is what you want. Just compare all the models you're interested in and choose the one with the best predictive performance. The AIC is actually asymptotically equivalent to leave-one-out cross validation, but LOO-CV has weird properties, so go with something like k-fold cross-validation.
Got it.
But what if I don't have any models in mind?
Then should I just take a combination of each possibility? For example, say I want to predict y and my data set has x1,x2,x3. Then complete model with everything in it is y=x1+x2+x3+x1*x2+x1*x3+x3*x2+x1*x2*x3. That is the complete model. Then whatever valid algorithm should be able to spit out the subset that best predicts y.
What if I have some models in mind from knowledge of the science? Then would that influence my choice for the prediction?
This is actually a bit of a tricky question. The simplest approach would be to just compare all possible models and select the best one, which would be 2^7 = 128 models in your case, which might take a while if you have to code them manually.
If you want to try something a little more sophisticated, my general approach to these kinds of problems is to fit the full model (with all variables and all interactions) and put a penalty on the model which will help to prevent overfitting and automatically select which variables should be included. For example, elastic-net regression is a modified version of ordinary least-squares regression which shrinks the coefficients towards zero (which tends to help avoid overfitting and increase predictive power) and has the power to set some coefficients to exactly zero, in some sense "automatically" removing variables which do not contribute to the model. If you're comfortable with R, there are several packages which will do this, included glmnet:
https://web.stanford.edu/~hastie/glmnet/glmnet_alpha.html
The package, handily, can also do cross validation automatically. The above link includes a tutorial.
