How to practice writing LaTeX before posting
  • Topic: LaTeX
  • Thread starter Thread starter rude man
    Latex Writing
13 replies · 3K views
Insights Author
What's the best way to "practice" writing latex text? I'd like to write, revew, edit, write etc. before posting in a forum or in Insight.
Or, can the latex compiler be downloaded?
Yes, for example as part of the MikTeX distribution if you're using Windows or MacTeX if you're using a Mac. These will get you the LaTeX compilers on your computer along with a large collection of useful supporting packages.
But just to check you know what it is (it's not obvious from your post): LaTeX is a programming/markup language and family of programs for writing structured documents in PDF and some other formats. It deals with a lot more than only typesetting equations. This forum does not support all of LaTeX (that would not make much sense) but only a subset of the LaTeX math-related commands for including equations in posts and insights.
Thanks @wle for your help.
I found out later that the arachnoid compiler does not accep ## as a delimiter so I didn't use it. And as I said already the codecox did not allow longer text, apparently.
I do have an excellent set of latex instructions for PF use at forums -> help which worked fine. But to de-compile I went to a blank "reply" page in an arbitrary thread. This is obviously not ideal so I'm still looking for a PF-oriented latex compiler and de-compiler.
Why not? Use the "Preview..." button to see what your LaTeX code produces. Nobody else will see what you're doing if you don't hit the "Post Reply" button.
No argument! It works very well IF you don't hit the "post reply" button by mistake, which I did once! o:)
robphy said:
You can write a draft Insight, which is private until you publish it.
Yes I had been doing that but I think someone (Greg?) reads all the drafts which are kept on file, so I started feeling uneasy about that. I think the best sol'n is what I've been doing, just taking a blank "reply" space to any old post, then making sure I don't post! Thanks for your help.
BTW if you do it that way do you get to read the de-complied ("real") text? I don't remember.
When composing an Insight, you can read the PRE-compiled "real mark-up" text.
You have to Preview it to view the LaTeX-compiled version.
(btw,... DE-compiled implies "attempting to recover the original (or approximate) markup" from the compiled-version alone [no access to the original markup], which is not easy)
I would be surprised someone read all such drafts.
If you are concerned about that, compose and save drafts on https://www.overleaf.com .
Of course. I remeber now. Thaks.
I had a draft (a google drawing with embed) which I saved and subsequently accessed. After 3 weeks or so it disappeared !
Are they wiped automatically after a set period?
