Proving the Minimum Directed Cycle Mean Cost Using Bellman-Ford Algorithm
  • Thread starter Thread starter Ganesh Ujwal
The discussion focuses on proving the minimum directed cycle mean cost, denoted as ##\lambda##, using the Bellman-Ford algorithm. It establishes that ##\lambda = \min_{i = 1,\ldots, n} \max_{0 \le k \le n-1} \left(\frac {p_i(n) - p_i(k)} {n-k}\right)##, where ##p_i(t)## represents the length of the shortest walk starting at vertex ##i## and traversing ##t## arcs in a directed graph ##\mathcal G = (\mathcal V, \mathcal A)## with edge costs ##c_{i,j}##. The proof requires understanding the relationship between the shortest paths and the directed cycles formed by traversing ##n## arcs.
  • Understanding of the Bellman-Ford algorithm for shortest paths
  • Knowledge of directed graphs and their properties
  • Familiarity with mathematical induction in proofs
  • Concept of directed cycle mean cost in graph theory
  • Study the Bellman-Ford algorithm implementation and its applications in graph theory
  • Explore mathematical induction techniques for proving properties in graph algorithms
  • Learn about directed graphs and their cycle structures
  • Investigate the implications of cycle mean costs in optimization problems
Mathematicians, computer scientists, and students studying graph theory, particularly those interested in algorithm design and optimization techniques.
Ganesh Ujwal
Member warned about not using the homework template
Prove ##\displaystyle \lambda=\min_{i = 1,\ldots, n}\max_{0 \le k \le n-1}\left(\frac {p_i(n)-p_i(k)}{n-k}\right)##
Prove the minimum directed cycle mean cost satisfies: ##\lambda = \min_{i = 1,\ldots, n} \max_{0 \le k \le n-1} \left(\frac {p_i(n) - p_i(k)} {n-k}\right)## using the Bellman-Ford algorithm.Let ##\mathcal G = (\mathcal V, \mathcal A)## be directed graph with associated edge costs ##c_{i,j}## that has at least one directed cycle (##c_{i,j} = \infty## for all ##(i,j) \notin \mathcal A##).Define the directed cycle mean cost to be ##\frac {\{\text {sum of cost of arcs}\}} { \text {# arcs}}##.Set ##p_i(0) = 0## and ##p_i(t+1) = \min_{j \in O(i)} \{ c_{i,j} + p_j(t) \}## for all ##i\in \mathcal V##.I've proven by induction that ##p_i(t)## denotes the length of the shortest walk start starts at ##i## and traverses ##t## arcs.Now, I want to prove that the minimum directed cycle mean cost ##\lambda## satisfies:##\lambda = \min_{i = 1,\ldots, n} \max_{0 \le k \le n-1} \left(\frac {p_i(n) - p_i(k)} {n-k}\right)##, where ##n## is the number of vertices in the graph ##\mathcal G##.I see that traversing ##n## arcs will always create a directed cycle. However, I don't know how to continue from here.
Prove ##\lambda=\min_{i = 1,\ldots, n}\max_{0 \le k \le n-1}\left(\frac {p_i(n)-p_i(k)}{n-k}\right)##
This is the part I can't figure out
##\lambda = \min_{i = 1,\ldots, n} \max_{0 \le k \le n-1} \left(\frac {p_i(n) - p_i(k)} {n-k}\right)##using the Bellman-Ford algorithm.
Let ##\mathcal G = (\mathcal V, \mathcal A)## be directed graph with associated edge costs $c_{i,j}$ that has at least one directed cycle (##c_{i,j} = \infty## for all ##(i,j) \notin \mathcal A##).
  • · Replies 27 ·
  • · Replies 21 ·
