How to show the direct sum of two matrices?
To show that V is the direct sum of U and W, it is necessary to demonstrate that V = U + W and that the intersection of U and W is the zero matrix. The matrices in U and W can be expressed with independent parameters, indicating that they span the entire space of V. By equating elements from U and W, one can derive that the only solution is the trivial case where all parameters are zero. This confirms that every element in V can be represented as a sum of elements from U and W, establishing the direct sum relationship.
looper
Let k be a field, V = Mat2x2(k), U:={[a, b], [-b, a] a, b E k} and W:={[a, b], [b, -a] a, b E k}. Show that V is the direct sum of U and W.
Add the matrix for U to the matrix of W. Values in that matrix still exist in k, so V = U + W. Is that the right reasoning? How do you show the intersection of two matrices is 0? Very confused.
Write W={[c, d], [d, -c] c, d E k} to make it clear there are four independent parameters here. Equate an element of U with an element of W and show a=0, b=0, c=0 and d=0 from the equations you get. Then you have to show any element of V can be written as a sum of an element from U and an element from W.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
11K
12K
