How to Simplify Fractional Exponents?
  • Context:
  • Thread starter Thread starter CSmith1
8 replies · 3K views
CSmith1
32 2/5(on top of the 32)+64 2/3(on top of the 64. I got 7(32 1/5 on top)squared =5
(64 2/3=(64 1/3) squared (2)=96 squared=2
Mathematics news on Phys.org
What did you get for each term? There are two terms added together in this problem so doing each part separately will help us understand your thought process.
ok for the first part this is what i did
1.)(32 1/5)2(squared = 32 to the 5th power(
32x5=160 so i have to find the power to give me 160 which is 32x5. so 32x32x32x32x32=5 .i got 5 for that.
2nd part 2.) 64 2/3=(64 1/3)squared...64x3=192.then i have to ask what power gives me 192. and i got 96 squared.96x96 gives me my 192 so i put the power which is =2
5+2=7
5+2=7
You start with [math]32^{\frac{2}{5}}[/math]. The 2 means square 32 and the [math]\frac{1}{5}[/math] or 5 in the bottom means find a number which multiplied by itself 5 times equals 32.
Your first idea was good. You tried to find [math]32^{\frac{1}{5}}[/math]. To do that you need to find a number that when multiplied by itself 5 times equals 32, not that number times 5. Start with really small numbers and multiply them together 5 times. You should quickly figure that out.
Put another way, [math]x^5 = x \cdot x \cdot x \cdot x \cdot x[/math] not [math]5x[/math]
CSmith said:
i squared the 32 and got 1024
Hi CSmith, :)
Yes it's correct. You can do this problem in two ways.
1) Find \(32^{\frac{1}{5}}\) first and then square the answer to find \(32^{\frac{2}{5}}\).
2) Find \(32^{2}\) first and then take the fifth root. You have done the first part. Now what remains is to find a number \(x\) such that, \(32^{2}=1024=x^5\). Then \(x=32^{\frac{2}{5}}\)
Among these methods I think it would be easier to use the first method since \(32^{\frac{1}{5}}\) is easier to find than, \(1024^{\frac{1}{5}}\)
Kind Regards,
Sudharaka.
Thanks! after that what should i do?
Sudharaka said:
Hi CSmith, :)
Kind Regards,
Sudharaka.
can u show me an easiert method to do this sum please
I suggest that you review how to simplify fractional exponents and try to find the answer to your question along the methods described above. Some useful webpages are given below,
1) Khan Academy
2) Math is Fun
3) The Math Page
Kind Regards,
Sudharaka.
