How to solve 2nd order non-linear DE with exponential
To solve the second-order non-linear differential equation d²V/dx² = A*exp(-B*V) - C*exp(B*V), a common approach is to convert it into a first-order equation. This can be achieved by using the substitution dV'/dx = V' dV'/dV, which simplifies the problem. The constants A, B, and C play a crucial role in the behavior of the solution. Engaging with this transformation allows for easier manipulation and potential solutions. Understanding this method is essential for tackling similar equations in mathematical physics.
El Flea
Hi,
Does anyone knows how to solve this 2nd order non linear differential equation with exponential components?
d"V/dx" = A*exp(-B*V)-C*exp(B*V)
where A, B, C are constants.
Thanks
Hi El Flea! :smile:
(try using the X2 tag just above the Reply box :wink:)
Hint: you can make this a first-order equation by using the standard trick:
d2V/dx2 = dV'/dx = dV'/dV dV/dx = V' dV'/dV :wink:
(which btw is where the 1/2 mv2 in energy equations comes from)
