Can You Solve This Recurrence Using the Recursion Tree Method?
  • Thread starter Thread starter 22990atinesh
    Recurrence
The discussion focuses on solving the recurrence relation T(n) = 2T(n-1) + n using the recursion tree method. Participants explore various approaches, including summing non-leaf and leaf nodes, and applying power series methods to derive a closed-form solution. The final expression derived is T(n) = 2^(n+1) - n - 2, which is reached through different summation techniques. There is also mention of a related recurrence T(n+1) = T(n) + floor(sqrt(n+1)) and discussions about the cubic equation form for T(m^2). The thread highlights the complexity of recurrence relations and the necessity for clear problem statements in discussions.
22990atinesh
##T(n) = 2 T(n-1) + n, n \geq 2##
##T(1) = 1##
I'm using recursion tree method to solve the above recurrence
T(n) = Summation of non-leaf nodes + leaf nodes
##T(n) = n + 2(n-1) + 2^2(n-2) + ... + 2^{n-1}##
This thread recurrs thrice.
Each thread had a separate problem. Maybe they should have been combined.
T(1) = 1.
(I assumed that ⌊ ⌋ meant the integer floor of the sqrt).
Note that floor(sqrt(1->3)) = 1, floor(sqrt(4 -> 8)) = 2, floor(sqrt(9->15)) = 3, ... .
T(m^2) = m + 1*0 + 3*1 + 5*2 + 7*3 + ... + (2m-1)(m-1)
T(m^2) = m + sum i=1 to m: (2i - 1)(i - 1)
Which is a cubic equation of the form (I'll let you solve this one):
T(m^2) = a m^3 + b m^2 + c m
I don't know if there's a more generic method to solve this.
T(n) = 2 T(n/2) + 2
T(1)=2
Code:
n=2                               2
                           2             2n=4                               2
                           2             2
                        2     2       2     2  n=8                               2
                           2             2
                        2     2       2     2
                       2 2   2 2     2 2   2 2
sum i=1 to log2(2n) : 2^i
2 T(n) - T(n) = T(n):
2 T(n) =        4 + 8 + 16 + ... + 2^(log2(2n)) + 2^(log2(4n))
  T(n) =    2 + 4 + 8 + 16 + ... + 2^(log2(2n))
  T(n) =   -2                                   + 2^(log2(4n))
  T(n) =   -2                                   + 4n
  T(n) = 4n - 2
For the summation series in the first post above, I used power series method, subracting 1 x series from 2 x series:
Code:
2(T(n)) =        (2)(n  ) + (2^2)(n-1) + (2^3)(n-2) + ... + 2^(n-1)(2) + 2^(n)
  T(n)  = (1)n + (2)(n-1) + (2^2)(n-2) + (2^3)(n-3) + ... + 2^(n-1)(1)
  T(n)  =   -n + (2)      + (2^2)      + (2^3)            + 2^(n-1)    + 2^(n)
2(T(n)+n) =       (2^2) + (2^3) + ... + 2^(n-1) + 2^(n) + 2^(n+1)
  T(n)+n  = (2) + (2^2) + (2^3) + ... + 2^(n-1) + 2^(n)
  T(n)+n  = -2                                          + 2^(n+1)
The other two copies have been deleted.
Edit: The other two copies were deleted in error. They have been reinstated.
Code:
as the height of the tree is n-1. So series would be
##T(n) = n + 2(n-1) + 2^2(n-2) + ... + 2^{n-3}(n-[n-3]) + 2^{n-1}##
on solving with your approach I'm ending up with different ans
##2T(n) - T(n) = T(n) = n + 2 + 2^2 + 2^3 + ... + 2^{n-3} + 2{n-2}(n-[n-3]) + 2^{n-1} + 2##
##T(n) = n -1 - \frac{7}{2} 2^n##
22990atinesh said:
So series would be
A terms is missing, it should be:
##T(n) = n + 2(n-1) + 2^2(n-2) + ... + 2^{n-3}(3) + 2^{n-2}(2)+ 2^{n-1}##
Then 2 T(n) - T(n) is
## -n + 2 + 2^2 + 2^3 + ... + 2^n ##
and you continue with T(n)+n as shown in my previous post.
hmm Sorry little mistake
##T(n) = n + 2(n-1) + 2^2(n-2) + ... + 2^{n-2}(n-[n-2]) + 2^{n-1}##
##2*T(n) = 2*n + 2^2(n-1) + 2^3(n-2) + ... + 2^{n-1}(n-[n-2]) + 2^{n}##
##2*T(n) - T(n) = - n + 2 + 2^2 + ... + 2^{n-2} + 2^{n-1} + 2^n##
##T(n) = - n + 2 + 2^2 + ... + 2^{n-2} + 2^{n-1} + 2^n + 2^0 - 2^0##
##T(n) = - n + 2^0 + 2^1 + 2^2 + ... + 2^{n-2} + 2^{n-1} + 2^n - 2^0##
Now We can directly apply sum of GP formula here
##T(n) = - n + \frac{2^{n+1} -1}{2-1} - 2^0##
##T(n) = 2^{n+1} - n - 2##
By the way what is this "Power Series Method". All I can find on internet is "Power Series Method" for differential equations.
