How to Solve Traffic Flow Problems Using Linear Algebra?
The discussion revolves around a traffic flow problem involving three one-way streets at intersections A, B, and C. Participants are tasked with setting up and solving a system of linear equations to determine the flow of traffic (x, y, z) based on given conditions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants attempt to formulate equations based on the principle that traffic flow into an intersection must equal the flow out. There are discussions about the correctness of initial equations and the interpretation of the problem statement.
Several participants are actively working through the equations and providing feedback on each other's attempts. There is a mix of interpretations regarding the setup of the equations, and some participants are questioning the assumptions made in their formulations. Guidance has been offered on how to structure the equations and set up the augmented matrix.
Some participants express uncertainty about the initial conditions and the representation of traffic flows in the problem. There are mentions of needing to clarify the problem statement and the significance of the numbers in the provided diagrams.
vs55
the following statement shows the traffic flow(in cars/minute) along 3 one way streets through the intersections A, B and C
Set up and solve a system of linear equations(using the augmented matrix for the system) to help you find the flows x,y and z. Be sure to generate the RREF of the system
a link of the drawing:
http://img18.imageshack.us/img18/2276/trafficflow.jpg
traffic flow in must equal flow out
so to start things off, equations i put:
3 + z = 3
6 + x = 7
5 + y = 4
is this at all right?
vs55 said:
the following statement shows the traffic flow along 3 one way streets through the intersections A, B and C
http://img216.imagevenue.com/img.php?image=27718_trafficflow_122_18lo.jpg
3 + z = 3
6 + x = 7
5 + y = 4
I don't think so. For your first equation, 3 + z = 3 ==> z = 0, which doesn't make any sense. How about giving us the problem exactly as it was worded? Useful information would be what the numbers in your drawing represent.
I believe that what you have as "relevant equations" means that the traffic flow into and out of an intersection must be equal.
this is the problem exactly as it was worded, but if u insist...i added "cars/minute" :|
i also added the label on the intersections in the image A,B and C
and sorry i thought the numbers were obvious :S, they represent the flow out that that arrow
i'm guessing i have to go take away some of the flow as well? I'm just not sure how to start the problem
If my previous interpretation of what traffic flow in equals traffic flow out is on track, here's what you have:
Node A (upper left intersection) x + 5 = y + 7
Node B (upper right int.) z + 6 = x + 3
Node C (lower int.) y + 3 = z + 4
Solve this system.
i got:
-x + z =-3
-z +y = 1
-y + x = z
to help set up the matrix:
-x 0 z
0 y -z
x -y 0
augmented matrix:
-1 0 1 |-3 ---->(1)
0 1 -1 |1------>(2)
1 -1 0 |2------>(3)
after some math:
(1)/-1
(3)-(1)
(3)+(2)
1 0 -1 | 3
0 1 -1 | 1
0 0 0 | 0
1x -1z = 3
1y -1z =1
z=free
z=1,y=2,x=4
is this right?
i got:
-x + z =-3
-z +y = 1
-y + x = z
The last equation should be -y + x = 2, but otherwise I got the same solution that you showed.
thx for ur help!
  • · Replies 32 ·
  • · Replies 69 ·
11K
  • · Replies 22 ·
