How to start Laplace infinite domain
13 replies · 4K views
Dustinsfl
This problem seems a little overwhelming at the point. I am not sure on where and how to start.
Suppose that a uniform thermal gradient in the +x direction exists in a very large (i.e. effectively infinite) domain of conductivity $k_2$ such that the temperature field $u_{\infty}(r,\theta)$ can be represented by
u_{\infty}(r,\theta) = Ar\cos\theta
where $A$ is a constant which reflects the gradient magnitude.
Suppose that a circular region of material of radius a is removed an replaced with a new material with conductivity $k_1$.
The most general version
of this problem is when the inner and out conductivities are of unequal, but comparable, magnitudes.
In this case, the steady temperature field inside the disk and outside the disk must be solved separately to obtain the inner and outer solutions, $u_1$ and $u_2$ respectively.
The constraint on the inner solution is boundedness at the origin
\lim_{r\to 0}|u_1(r,\theta)| < \infty.
The outer solution must asymptotically approach the undisturbed temperature field at large distances:
\lim_{r\to\infty}u_2(r,\theta)\to u_{\infty}(r,\theta).
Each of these solutions will contain series coefficients that must be determined by jointly imposing continuity of temperature and heat flux at the boundary $r = a$:
\begin{alignat*}{3}
u_1(a,\theta) & = & u_1(a,\theta)\\
k_1u_{1_r}(a,\theta) & = & k_2u_{2_r}(a,\theta)
\end{alignat*}Obtain the solutions for the temperature fields $u_1$ and $u_2$ with series coefficients expressed terms of $a$, $k_1$ and $k_2$.
u_1 = A_0 + \sum_{n=1}^{\infty}r^n(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta)
u_2 = U_0r\cos\theta + \sum_{n=1}^{\infty}\frac{1}{r^n}(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta)
The equation $Ar\cos\theta$ has been changed to $U_0r\cos\theta$ and $u_1(a,\theta) = u_2(a,\theta)$. Therefore, $A_0 = U_0a\cos\theta$. Then
\sum_{n=1}^{\infty}\left[a^n(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta)-\frac{1}{a^n}(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta)\right] = 0
Only when $a^nA_n^{(1)} = \frac{1}{a^n}A_n^{(2)}$ and $a^nB_n^{(1)}=\frac{1}{a^n}B_n^{(2)}$ <--Is this correct to do?
From this point (if it is correct), can be simplified more now? Or must I use the next condition $-k_1\frac{\partial u_1}{\partial r}(a,\theta)=-k_2\frac{\partial u_2}{\partial r}(a,\theta)$?
Hi dwsmith, :)
When $a^nA_n^{(1)} = \frac{1}{a^n}A_n^{(2)}$ and $a^nB_n^{(1)}=\frac{1}{a^n}B_n^{(2)}$ we have,
\[\sum_{n=1}^{\infty}\left[a^n(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta)-\frac{1}{a^n}(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta)\right] = 0\]
But we cannot say that the above sum is equal to zero only when $a^nA_n^{(1)} = \frac{1}{a^n}A_n^{(2)}$ and $a^nB_n^{(1)}=\frac{1}{a^n}B_n^{(2)}$. For example another possibility that could make the sum equal to zero is,
\[a^n(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta)-\frac{1}{a^n}(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta)=0\mbox{ for each }n\geq 1\]
with $a^nA_n^{(1)} \neq \frac{1}{a^n}A_n^{(2)}$ and $a^nB_n^{(1)}\neq\frac{1}{a^n}B_n^{(2)}$.
Kind Regards,
Sudharaka.
Sudharaka said:
Hi dwsmith, :)
Kind Regards,
Sudharaka.
Then how do I obtain the series coefficients in terms of $a$, $k_1$, and $k_2$?
Not sure whether this is the correct approach, but I think the series coefficients can be found using the remaining boundary condition. What do you get after using that boundary condition?
Using the second boundary condition, we have
\begin{alignat*}{3}
-k_1\frac{\partial u_1}{\partial r}(a,\theta) & = & - k_1\sum\limits_{n = 1}^{\infty}na^{n - 1}\left(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta\right)\\
& = & -k_2U_0\cos\theta + k_2\sum\limits_{n = 1}^{\infty}\frac{n}{a^{n + 1}}\left(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta\right)\\
& = & -k_2\frac{\partial u_2}{\partial r}(a,\theta).
\end{alignat*}
\begin{alignat*}{3}
\end{alignat*}
Eliminate \(A_{n}^{(2)}\) and \(B_{n}^{(2)}\) using, \(a^nA_n^{(1)} = \frac{1}{a^n}A_n^{(2)}\) and \(a^nB_n^{(1)}=\frac{1}{a^n}B_n^{(2)}\).
You have taken, \(A_{0}=U_{0}a\cos\theta\) (which is problematic because a Fourier coefficient cannot be a variable) and neglected that part altogether to obtain,
Is it given that, \(A_{0}=U_{0}=0\)?
No.
k_2U_0\cos\theta = \sum_{n=1}^{\infty}\left[(k_1 + k_2)na^{n-1}A_n\cos n\theta + (k_1 + k_2)na^{n-1}B_n\sin n\theta\right]
Now what?
So
k_2U_0\cos\theta = (k_1+k_2)A\cos\theta\Rightarrow A_1^{(1)} = \frac{k_2U_0}{k_1+k_2}
correct?
How do I find the other coefficients?
dwsmith said:
No.
Then you cannot obtain,
in post #2. Post #3-#7 and #10 becomes irrelevant and you should try to continue from post #2. :)
I have tried many different methods already any better advice?
So you have,
\[u_1 = A_0 + \sum_{n=1}^{\infty}r^n(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta)\]
\[u_2 = U_0r\cos\theta + \sum_{n=1}^{\infty}\frac{1}{r^n}(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta)\]
with the boundary conditions,
\[u_1(a,\theta) = u_2(a,\theta)\mbox{ and }-k_1\frac{\partial u_1}{\partial r}(a,\theta)=-k_2\frac{\partial u_2}{\partial r}(a,\theta)\]
From the first boundary condition we get,
\[A_0 + \sum_{n=1}^{\infty}a^n(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta)=U_0a\cos\theta + \sum_{n=1}^{\infty}\frac{1}{a^n}(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta)\]
\[\Rightarrow A_0 -U_0a\cos\theta+\sum_{n=1}^{\infty}\left(a^n A_{n}^{(1)}-\frac{A_{n}^{(2)}}{a^n}\right)\cos n\theta+ \sum_{n=1}^{\infty}\left(a^n B_{n}^{(1)}-\frac{B_{n}^{(2)}}{a^n}\right)\sin n\theta=0\]
\[\Rightarrow A_0 +\left(aA_{1}^{(1)}-\frac{A_{1}^{(2)}}{a}-U_0a\right)\cos\theta+\sum_{n=2}^{\infty}\left(a^n A_{n}^{(1)}-\frac{A_{n}^{(2)}}{a^n}\right)\cos n\theta+ \sum_{n=1}^{\infty}\left(a^n B_{n}^{(1)}-\frac{B_{n}^{(2)}}{a^n}\right)\sin n\theta=0\]
This is satisfied when,
\[A_{0}=0\]
\[aA_{1}^{(1)}-\frac{A_{1}^{(2)}}{a}-U_0a=0\]
\[a^n A_{n}^{(1)}-\frac{A_{n}^{(2)}}{a^n}=0\mbox{ for all }n\geq 2\]
\[a^n B_{n}^{(1)}-\frac{B_{n}^{(2)}}{a^n}=0\mbox{ for all }n\geq 1\]
Try to do the same thing for the second boundary condition and you should get three equations corresponding to the coefficients of \(\cos\theta\), \(\cos n\theta\) and \(\sin n\theta\).
We have that $u_1 = A_0^{(1)} + \sum\limits_{n = 1}^{\infty}r^n\left(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta\right)$ and $u_2 = u_{\infty} + u_2' = U_0r\cos\theta + \sum\limits_{n = 1}^{\infty}\frac{1}{r^n}\left(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta\right)$.
Using the first boundary condition, we have
\begin{alignat*}{3}
u_1(a,\theta) & = & A_0^{(1)} + \sum\limits_{n = 1}^{\infty}a^n\left(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta\right)\\
& = & U_0a\cos\theta + \sum\limits_{n = 1}^{\infty}\frac{1}{a^n}\left(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta\right)\\
& = & u_2(a,\theta).
\end{alignat*}
\begin{alignat*}{3}
k_1\frac{\partial u_1}{\partial r}(a,\theta) & = & k_1\sum\limits_{n = 1}^{\infty}na^{n - 1}\left(A_n^{(1)}\cos n\theta + B_n^{(1)}\sin n\theta\right)\\
& = & k_2U_0\cos\theta - k_2\sum\limits_{n = 1}^{\infty}\frac{n}{a^{n + 1}}\left(A_n^{(2)}\cos n\theta + B_n^{(2)}\sin n\theta\right)\\
& = & k_2\frac{\partial u_2}{\partial r}(a,\theta).
\end{alignat*}
From the first boundary condition, we have
\sum\limits_{n = 1}^{\infty}\left(a^nA_n^{(1)} - \frac{1}{a^n}A_n^{(2)}\right) \cos n\theta = U_0a\cos\theta
where $B_n = A_0^{(1)} = 0$ since there are no sine and constant terms in the equality.
That is, we have that
aA_1^{(1)} - \frac{1}{a}A_1^{(2)} = U_0a\iff A_1^{(1)} = U_0 + \frac{1}{a^2}A_1^{(2)}.
From the second boundary condition, we have
k_1A_1^{(1)} + \frac{k_2}{a^2}A_1^{(2)} = k_2U_0.
We can now plug in our $A_1^{(1)}$ term.
Then we have that $A_1^{(2)} = \frac{a^2U_0\left(1 - \frac{k_1}{k_2}\right)}{\frac{k_1}{k_2} + 1}$ and plugging $A_1^{(2)}$ into the other equation we have $A_1^{(1)} = U_0\left[1 + \frac{1 - \frac{k_1}{k_2}}{\frac{k_1}{k_2} + 1}\right]$
Therefore, the general solution is
u(r,\theta) = u_1 + u_2 = U_0\cos\theta\left[2r + \left(r + \frac{a^2}{r}\right)\left(\frac{1 - \frac{k_1}{k_2}}{1 + \frac{k_1}{k_1}}\right)\right].
