bfosler
- 1
This is a different take on an elevator problem:
An elevator and contents have a mass of 300kg and travels at 2.5 m/s during normal operation. The elevator's cables break and begins to free-fall.
You need to stop the elevator and the max allowed deceleration is 4m/s^2. There is 0.05m between each side of the elevator and the walls, and the coefficient between steel members and the elevator shaft is mu(k)=0.3.
I assume that you can use steel wedges to help stop the elevator and then couple it with a spring mechanism at the bottom. But, it seems that even with 4 steel wedges on each side, the spring will need to create a force of ~500N.
Any suggestions...because I'm kinda all out of ideas
Thanks
Thanks
