How to Sum an Infinite Series?
7 replies · 2K views
Buffu
Find the sum of the given infinite series.
$$S = {1\over 1\times 3} + {2\over 1\times 3\times 5}+{3\over 1\times 3\times 5\times 7} \cdots $$
2. Homework Equations
I try to reduce the denominator to closed form by converting it to a factorial.
$$\sum_{k \ge 1} {k\over {\prod^{k + 1}_{a = 1} 2a -1 }}$$
$$\sum_{k \ge 1} {k\times \prod^{k + 1}_{a = 1} 2a\over \prod^{k + 1}_{a = 1} 2a -1 \times \prod^{k + 1}_{a = 1} 2a}$$
$$\sum_{k \ge 1} {k\times 2^{k+1} \times (k+1)! \over (2(k+1))!}$$
I hit the dead end here. Although i can simply this a bit more but i still can't find a series that i can sum easily.
Please provide some hints as to how can i proceed further.
Buffu said:
$${1\over 1\times 3} + {2\over 1\times 3\times 5}+{3\over 1\times 3\times 5\times 7} \cdots $$
What are you supposed to show in this problem? Your problem description is lacking this information.
The trick is to write it as a telescopic sum:
[tex] \frac{n}{(2n+1)!} = \frac{1}{2(2n-1)!} - \frac{1}{2(2n+1)!}[/tex]
(in case you haven't seen it before, ! is the double factorial)
I am really sorry Mark. I have edited the question. Please see if my edit is sufficient enough.
Much better. I wasn't sure whether you were supposed to determine if the series converged or diverged, or if it converged, find the sum.
I don't know what double factorial means. Sorry.
Does double factorial means ##n! = n(n-2)(n-4)\times\cdots \times3 \times 1## or ## (n!)!##?
Also, can you tell how you know that this is a telescopic series ?
Have you done this question before ?
Buffu said:
Does double factorial means ##n! = n(n-2)(n-4)\times\cdots \times 1##
This one.
Had you done this question before ?
Nope, haven't done it before - but its a standard technique for evaluating infinite summation of series. It probably helps to examine the structure of the first few terms. This can lead you to a good guess / ansatz that you can then prove in general for an arbitrary term.
Fightfish said:
This one.
Thank you very much. You are genius for sure.
