How to test f=ma using trolley and ticker timer?
  • Thread starter Thread starter threy
    F=ma Test Timer
To test how mass affects acceleration using a trolley and ticker timer, it's important to clarify the setup and measurement methods. The angle of the inclined plane should remain constant while varying the mass of the plasticine attached to the trolley. Instead of measuring the total length of the ticker tape, focus on the spacing between the markings to calculate average velocity and acceleration. The spacing between dots can be used to determine speeds at different points, and the number of dots between these points provides the time for the change in speed. Properly applying the 'suvat' equations will yield accurate acceleration results based on these measurements.
threy
To test mass affects acceleration.
is it correct to change the mass of plasticine attached to the trolley and measure the length of the ticker tape strip with the constant variable be the angle of the inclined plane?
It might be, depending on exactly how your "ticker timer" works. The experiments that I've done using a tape strip involved measuring not the length of the entire tape, but instead the locations of markings made on it as the trolley moves along it. Can you provide more details about your apparatus so we can be sure we're all discussing the same thing?
My apparatus includes inclined plane, ticker tape, ticker timer, wooden block, trolley and plasticine.
Is it correct to measure the length of the ticker tape strip to indicate the change in acceleration? Why?
What length of the ticker tape are you talking about?
What are you considering as the start and finish of the ticker tape?
I know how I did the experiment, but an outline of your procedure might also be in order.
Somehow you have to convert the distance between ticks into an average velocity, and do a calculation to find the acceleration.
How do you think you should do that?
You can find the acceleration by measuring the spacing between dots at a point where they are close together and then measuring the spacing further along the tape. The two dot spacings will give you the two speeds and the number of spaces in between will give the time taken for the change in speed. That will give acceleration, using the appropriate 'suvat' equation.
But there are a few different combinations of the measurements you can do with ticker timer tape results. Just remember that tape distance represents s and number of dots represents t.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 19 ·
  • · Replies 35 ·
34K
11K
