How to think about increased temperature effect on water autoprotolysis equilibrium constant?
The discussion revolves around the effect of increased temperature on the water autoprotolysis equilibrium constant, exploring theoretical implications, the role of solvent density, and the concept of activity in equilibrium expressions.
  • One participant references the van't Hoff equation to suggest that the equilibrium constant increases with temperature, indicating a shift towards products (hydronium and hydroxide ions).
  • Another participant asserts that the density change of water due to temperature has minimal effect on the equilibrium constant, as the solvent's activity is considered to be equal to 1.
  • A challenge is raised regarding the approximation that the solvent does not matter in equilibrium expressions, using an equimolar mixture of water and ethanol as an example to question which component acts as the solvent.
  • Further discussion highlights that the absence of a reaction in the water-ethanol mixture does not negate the relevance of activity, suggesting that activity is a broader concept applicable beyond chemical reactions.
Participants express differing views on the significance of solvent density and activity in equilibrium expressions, indicating a lack of consensus on these points.
Participants note that the treatment of solvent activity as equal to 1 is an approximation and that the classification of processes as chemical or physical can be ambiguous.
zenterix
The density of liquid water decreases as the temperature increases from 25C to 50C. Will this effect cause ##K_2## to increase or decrease? Why?
I thought I knew the answer to this question until today.
Apparently not.
From the van't Hoff equation we have
$$\ln{\left ( \frac{K_p(T_1)}{K_p(T_2)} \right )}=\frac{\Delta H^\circ_{rxn}}{R}\left ( \frac{1}{T_2}-\frac{1}{T_1} \right )\tag{1}$$
So for ##T_2>T_1## we have ##K_p(T_1)<K_p(T_2)##.
which is to say that the equilibrium constant increases for the higher temperature and the reaction shifts towards products (ie ions, hydronium and hydroxide).
Does the analysis above even take into account something like the change in density of water?
Today I learned that the water autoprotolysis constant is
$$\mathrm{K_{auto}=\frac{[H_3O^+][OH^-]}{[H_2O]^2}}\tag{2}$$
and
$$\mathrm{K_w=K_{auto}[H_2O]^2=[H_3O^+][OH^-]}\tag{3}$$
Which of these constants is the one that is considered in (1)?
In the equilibrium expression for a solution you only need to include the concentration of solutes.
The solvent doesn't matter. It has "activity" equal to 1.
So the density change of the solvent due to temperature change has very little effect, I would say.
That's only an approximation.
Imagine equimolar mixture of water and ethanol. Which one is solvent, and which one has the activity of 1?
Good point!
I'm not sure about your example though. There's no reaction going on there, is there?
So I can mix water and ethanol at any ratio and it'll stay that way if nothing evaporates.
It won't move towards a chemical equilibrium.
Or am I missing something?
Not really my field, but I like to learn!
Doesn't matter - I could go for other examples of things possibly reacting (like equimolar mixture of acetic acid and ethanol), but activity in general is much more universal concept, not limited to chemical processes (and don't get me started on what is chemical reaction vs what is physical process :wink: as this classification is artificial - makes some sense when you start learning, but gets more and more blurry once you get into fine prints).
15K
17K
