How to work out this impact force
17 replies · 2K views
Lily May
During a Formula 1 race a car that was traveling at a speed of 172.8 km/h crashed into a wall. When the car hit the wall it came to a complete stop in 0.0272 s. If the driver of the car holds a mass of 70kg, calculate the impact force he experienced.
I honestly don't know. F = m*a or F= GMm/r^2
I have no idea what to do?
F= m*a
= 70*172.8
= 12 096N
I don't think gravity will have anything to do with this problem, so you can forget that last equation.
F= m*a
= 70*172.8
= 12 096N
What is the acceleration (meaning "deceleration" in this case) of the car as it hits the wall?
Lily May said:
F= m*a
= 70*172.8
Does the unit for acceleration match the unit of the number you've plugged in for 'a'? If not, how might you get that unit from the information provided?
DrClaude said:
I don't think gravity will have anything to do with this problem, so you can forget that last equation.What is the acceleration (meaning "deceleration" in this case) of the car as it hits the wall?
Am I meant to use the acceleration formula for that?
a= v1 - v2 / t
a= v1 - v2 / t
Yes. [But it should be v2 - v1 if v2 is the final velocity. And parentheses can be helpful: a = (v2 - v1)/t.]
So you'd have to mutiple the number by 1000 then divide by 3600?
172.8*1000= 172800
172800/3600= 48m/s/s
172.8*1000= 172800
Put units everywhere:
\begin{align*}
172.8\frac{\mathrm{km}}{\mathrm{h}} \times \frac{1000\ \mathrm{m}}{\mathrm{km}} &= 172800 \frac{\mathrm{m}}{\mathrm{h}} \\
172800 \frac{\mathrm{m}}{\mathrm{h}} \times \frac{\mathrm{h}}{3600\ \mathrm{s}} &= 48 \frac{\mathrm{m}}{\mathrm{s}}
\end{align*}
So
v2 = 0?
v1= 48m/s^2
t = 0.0272s
172.8*1000= 172800
DC seems to be helping you well at the moment. I'm going to step out and let him handle it for now. I'll pop back in later though.
\begin{align*}
\end{align*}
Whoops, I'll be sure to do that, thanks. So then do I use the acceleration fomula or the force fomula?
Lily May said:
So
v2 = 0?
v1= 48m/s^2
t = 0.0272s
Are you sure about the units of v1? What is the acceleration?
v1 = 48m/s
a = (v2 - v1)/t.]
= 0 - 48m/s
= -48m/s / 0.0272s
a = -1 764.71m/s
that doesn't seem right
Lily May said:
v1 = 48m/s
a = (v2 - v1)/t.]
= 0 - 48m/s
= -48m/s / 0.0272s
a = -1 764.71m/s
Units... if you divide meters per second by seconds, what do you get?
Lily May said:
v1 = 48m/s
a = (v2 - v1)/t.]
= 0 - 48m/s
= -48m/s / 0.0272s
a = -1 764.71m/s
The math looks correct, you just have it in units of velocity instead of acceleration.
So I'd just change the end to -1 764.71m/s^2 = a
And mass = 70kg
Then I multiple those two together to get the impact force/final answer?
And mass = 70kg
Correct.
DrClaude said:
Correct.
Thank you all!
Bit of a macabre exercise. 180 g can not be survived by a human. This looks like a post mortem review ..
Fortunately head-on crashes with concrete walls are rare in F1.
