How to write a proof: from (A + B) = C to (A - B) = (C - 2B)
751 replies · 91K views · last reply
CompuChip said:
In the notation I just made it explicit that, except on the variable x, the function f also depends on some other object, namely the set B. Of course if you want to be very formal, you could go
Define [tex]f: \mathbb{R} \times \mathscr{P}(\mathbb{R}) \to \mathbb{R}[/tex] as [tex]f(x, B) = x + \sum_{b \in B} b[/tex].​
So f is a function that takes a number (x) and a subset of the reals (B). However, in some applications the subset is "fixed" in the sense that you pick some specific B and then define f as above for that specific B, so it is really only a function of x. Still, there is some dependency on B of course, if I pick a different B then in general f will evaluate to a different number - for example the value of f(0) will change. So instead of writing f(x, B) we often write f(x; B) or fB(x) to indicate that x is really the variable, but the definition also depends on some (earlier) choice of - in this case - B.
I hope that makes it clearer.
When you say
[tex]f: \mathbb{R} \times \mathscr{P}(\mathbb{R}) \to \mathbb{R}[/tex]​
I'm not sure I understand in which context you use ℝ × p(ℝ) ---> ℝ , why ℝ × p(ℝ)?
In
[tex]f(x, B) = x + \sum_{b \in B} b[/tex]​
, why is there a B in f(x,B) , why is it described as if the function had an impact on B while it doesn't since B stays the same and only x receive some kind of ''treatment'' from the function?
micromass said:
This is an interesting point and I want to continue a bit on it. What CompuChip is saying is that the functions f(x)=x+5 and f(y)=y+5 are the same thing. In textbooks you will often encounter the phrase that x is a "dummy variable". This means that you can change x in any other symbol (that's not used already) and that the function won't change.
Now, why is this? Well, remember that a function is essentially a set. What set is the function f(x)=x+5. By definition is a subset of ##\mathbb{R}\times \mathbb{R}##. Which subset?
[tex]f=\{(x,x+5)~\vert~x\in \mathbb{R}\}\subseteq \mathbb{R}\times \mathbb{R}[/tex]
I was aware that x could be replaced by any other letter in theory , sorry if I confused you in some ways.
I feel like there's something that I should understand very clearly right away because it's not the first time I'm scratching my head over something similar , when you say [tex]f=\{(x,x+5)~\vert~x\in \mathbb{R}\}\subseteq \mathbb{R}\times \mathbb{R}[/tex] , why is (x,x+5) written like this beside f?
Let me try to explain it to you to see if I understand it correctly.Here we have a function f which is subset of ℝ × ℝ because the function operates on x (which is an element of ℝ) and produce or generate the result x+5 (which is also an element of ℝ).Is that pretty much it?
When we claim that the variable x and y can be interchanged, then we actually say that we have the following equality of sets:
[tex]\{(x,x+5)~\vert~x\in \mathbb{R}\} = \{(y,y+5)~\vert~y\in \mathbb{R}\}[/tex]
Okay that's clear and pretty sure I understood it.
Now, the above is a bit imprecise. Take two functions ##f:A\rightarrow B## and ##g:C\rightarrow D## are the same thing if
[tex]\{(x,f(x))~\vert~x\in A\}= \{(x,g(x))~\vert~x\in C\}[/tex]
When you say [tex]\{(x,f(x))~\vert~x\in A\}= \{(x,g(x))~\vert~x\in C\}[/tex] , why isn't it mentionned that (f(x)) is an element of B or D?
This is nice and it works suitably well. But usually we also demand that ##A=C## and that ##B=D##. This has a few consequences that can look weird at first. For example, take ##f:\mathbb{R}\rightarrow \mathbb{R}:x\rightarrow x^2## and ##g:\mathbb{R}\rightarrow \mathbb{R}^+ = \{x\in \mathbb{R}~\vert~x\geq 0\}##.
We can see easily that the following equality holds:
[tex]\{(x,f(x))~\vert~x\in \mathbb{R}^2\}= \{(x,g(x))~\vert~x\in \mathbb{R}\}[/tex]
I'm confused here , in ##g:\mathbb{R}\rightarrow \mathbb{R}^+ = \{x\in \mathbb{R}~\vert~x\geq 0\}## , what does R+ means?
In [tex]\{(x,f(x))~\vert~x\in \mathbb{R}^2\}= \{(x,g(x))~\vert~x\in \mathbb{R}\}[/tex] ,why does it hold if one is ℝ and the other is ℝ^2? I'm a lot confused about this whole part so I'm not sure which question to ask , I feel like I have something missing.Mainly my knowledge or understanding of how to define a function seems to be lacking in precision.
micromass said:
I suggest you make different threads for the different books you read. So make another thread specifically for Kline. I think it will be a bit confusing if you're going to use this thread both for calculus and set theory.
Sure , I'll do that when I start which should be this week-end or next week.
I'm having a very busy week and it's a real pain for my personal math studies.Hopefully I can clear everything within 2 weeks and start to spend even more time studying set theory and calculus.I noticed that when you had some unrelated worries learning math is at least twice as difficult as it is when you have a clear mind.Stress isn't friendly to mathematical thinking.
Fredrik said:
This seems to be a good time to point out a pecularity with the definition of a function from X into Y as a special kind of subset of X×Y. Suppose that f is a function from X into Y according to the definition you have studied, and that Y is a proper subset of some set Z. Then f is also a subset of X×Z, and it satisfies both conditions in the definition of a function from X into Z. So Z has an equal right to be called the codomain of f.
With this definition of "function", the range is simply the smallest set that can be called the codomain of f.
Another question about this.
As I've already asked you , if Z ⊆ W , W also has an equal right to be called the codomain of f.Then I presume that if W ⊆ Q , then Q also has an equal right to be called the codomain of f and so on.My point is since everything is a set , then while the range is the smallest possible set that could be called the codomain of f , if you rise in the hierarchy of set you will eventually reach set U , which would have an equal right to be called the co-domain of f , but since U is the set containing all sets , then it means that the co-domain is also the domain?
reenmachine said:
Again , in ##f(A)=\{y\in B\,|\,\exists x\in A~~ f(x)=y\}## , why is ''there exist'' necessary?
I thought the example would make that clear. It wouldn't make sense to write ##f(A)=\{y\in B\,|f(x)=y\}##, because it's not clear what x refers to. Consider the f I used as an example. If you say that for this f, f(ℝ) is defined by ##f(\mathbb R)=\{y\in B|f(x)=y\}##, then you're saying that f(ℝ) denotes the set of all y in ℝ such that y=x2. But this doesn't tell me what set f(ℝ) is. It looks like f(ℝ) is some singleton set (for example if x=2, we have f(ℝ)={4}), but I can't tell which one.
reenmachine said:
When you define it as ##f(A)=\{f(x)|x\in A\}## , is it implied that f(x) transforms x into y?
What is the y in your question?
The equality is supposed to be the definition of the range of a function from A into B that's denoted by f. That fact alone ensures that for each x, f(x) is an element of B. This follows from the definition of "function from A into B".
That's not what I meant , I wasn't speaking about both ##\exists## and ##x\in A## , I was only speaking about ##\exists##
Okay , but then where is B in your exemple? Simply implied by f?
thanks a lot!
"Contains" is an ambiguous word in this context. The set {x,y,z} "contains x" in the sense that ##x\in\{x,y,z\}## and "contains ##\{y,z\}##" in the sense that ##\{y,z\}\subseteq\{x,y,z\}##. So I'm not sure if what you had in mind is that every set is an element of U or that every set is a subset of U. Edit: I corrected the last sentence of this paragraph.
In ZFC set theory, there's no set U such that every set is an element of U. We can prove that there isn't by deriving a contradiction from the assumption that there is. So suppose that U is a set that such that every set is an element of U. By the ZFC axioms, this implies that ##\{S\in U|S\notin S\}## is a set. But if this is a set, and we denote it by R, the definition of R tells us that ##R\in R## if and only if ##R\notin R##. This is a contradiction, so we are forced to conclude that there's no set U such that every set is an element of U.
There's also no set U such that every set is a subset of it. Suppose that U is such a set, and let S be an arbitrary set. By the ZFC axioms, {S} is a set. By assumption, this implies that ##\{S\}\subset U##. This implies that ##S\in U##. Since S is arbitrary, this implies that every set is a member of U. This contradicts the previous result that no such set exists. This contradiction forces us to conclude that there's no set U such that every set is a subset of it.
Don't know what I have today but my head feels like exploding.Just one of those days :smile:
Just for the sake of ultimate clearness , in ##\{S\in U|S\notin S\}## , what does the vertical line in the middle means?
So set S is an element of U if and only if S isn't an element of S is that right?
I don't understand what happened when you switched to R.Why is the definition of R telling us that ##R\in R## iff ##R\notin R##? Why isn't it ##R\in U## iff ##R\notin R##?
sorry for my troubles today , I can't always be on my A game (I'm at least using this rough day to slowly but surely introduce some LaTeX in my posts).
thanks a lot!
OK, so you're suggesting that we define the range of a function ##f:A\to B## as the set ##\{y\in B|x\in A~~ f(x)=y\}##. The problem is that it's not clear what the statement ##x\in A~~ f(x)=y## means. Using the same example function again, the set we're talking about would be "the set of all real numbers y such that x is a real number y=x2". This sentence doesn't make sense to me. Even if we interpret the end of the sentence as "... x is a real number and y=x2", we can still ask what real number x is. The sentence seems to be referring to an x that's been defined earlier.
I used the notation ##f:\mathbb R\to\mathbb R##, which tells us either that ℝ is the codomain of f (if we use definition 2 of "function") or that ℝ is a codomain of f (if we use definition 1 of "function"). Regardless of whether ℝ is a codomain or the codomain, f(x) is still going to be a member of ℝ for all x.
Fredrik said:
OK, so you're suggesting that we define the range of a function ##f:A\to B## as the set ##\{y\in Y|x\in A~~ f(x)=y\}##. The problem is that it's not clear what the statement ##x\in A~~ f(x)=y## means. Using the same example function again, the set we're talking about would be "the set of all real numbers y such that x is a real number y=x2". This sentence doesn't make sense to me. Even if we interpret the end of the sentence as "... x is a real number and y=x2", we can still ask what real number x is. The sentence seems to be referring to an x that's been defined earlier.
how does ##\exists x\in A## help define x better than just saying that ##x\in A## ? What supplemental information about x did we acquired by reading that ##\exists x\in A## instead of ##x\in A##? If ##x\in A## , isn't it implied that ''there exist'' an x? You're saying we could ask ''what real number x is?'' if we only read ##x\in A## , but isn't it also true with ##\exists x\in A##?
Also , didn't you mean ##y\in B##?
About the clearness , shouldn't there be some kind of transition symbol or concept from ##\exists x\in A## to ##f(x)=y\}##?
thanks man!
If that's going to happen, this is a good time for it. :smile: Russell's paradox and the closely related liar's paradox has that effect on people.
http://www.youtube.com/watch?v=EzVxsYzXI_Y&t=1m23s
It means that S is not an element of S.
The notation ##\{S\in U|S\notin S\}## should be interpreted as "the set of all S in U such that S is not an element of S".
The definition of R is ##R=\{S\in U|S\notin S\}##.
Every statement must be either true or false. The statement ##R\in R## is no exception.
Suppose that the statement ##R\in R## is true. Since the elements of R are precisely those sets that are not elements of themselves, the assumption implies that R is not an element of R, i.e. that ##R\notin R##. This contradicts the assumption that the statement ##R\in R## is true
Suppose that the statement ##R\in R## is false. This assumption is clearly equivalent to ##R\notin R##. (We can see that without using the definition of R). Now R satisfies the condition that ensures that it's an element of R. So ##R\in R##. This contradicts the assumption that the statement ##R\in R## is false.
Since we get a contradiction regardless of whether ##R\in R## is true or false, R can't be a set.
http://www.youtube.com/watch?v=EzVxsYzXI_Y&t=1m23sIt means that S is not an element of S.
The notation ##\{S\in U|S\notin S\}## should be interpreted as "the set of all S in U such that S is not an element of S". The definition of R is ##R=\{S\in U|S\notin S\}##.
Quick question and brain cramp , why the bolded?
##x\in A## tells us that "x is an element of A". This is a statement about x and A. That's why we need to know what x is.
##\exists x\in A## tells us that "there's an x that's an element of A". In other words, "there's a set that's an element of A". This is a statement about A alone. It can clearly be made without even using the symbol x.
##x\in A~~f(x)=y## would be "x is in A f(x)=y". This doesn't make sense as it stands (no punctuation), and if it's interpreted as "x is in A and f(x)=y", then it's a statement about x,y and A.
##\exists x\in A~~f(x)=y## tells us that "there's an x in A such that f(x)=y". This is a statement about A and y.
Obviously ##x\in A## wouldn't make sense if x doesn't exist, but how would you know that x isn't a variable that represents some specific element of A? If I say "micromass is Belgian", you would interpret it as a statement about a specific person for whom I'm using the label "micromass". You wouldn't interpret it as "there exists a Belgian person", which is exactly what ##\exists\text{ micromass}\in\text{Belgians}## would mean.
Not at all, because ##\exists x\in A## means the same thing as ##\exists y\in A##. ##\exists x\in A## is a statement about A alone. ##x\in A## is a statement about x and A.
Yes. I will edit that in my post.
Sometimes a colon is used for clarity. (You probably noticed that CompuChip did that). The colon isn't part of the logical language (and neither are the spaces I added), but it's OK to use it if it improves readability.
Because that condition is "is not an element of itself". Recall that the definition of R is ##\{S\in U|S\notin S\}##. So a set is a member of R if and only if it's not an element of itself. In other words, an arbitrary set x is an element of R if and only if ##x\notin x##. Therefore R is an element of R (i.e. ##R\in R##) if and only if ##R\notin R##. This is the contradiction that forces us to conclude that R is not a set.
wow ok , I see it now. :smile:
thanks
Before going further , I have to ask what relation does R have with U or S for them to be included in it's definition? It confuses me a bit.
R and U are notations for two specific sets. (At the end of the argument, we find that they're not sets at all, but until then, they are to be treated as sets). R is only defined to make it easier to derive a contradiction from the assumption that U is a set.
S isn't some specific set, so it wouldn't make sense to say that it has a relationship with U or R. All the statements involving S can be made using any other letter of the alphabet instead, except maybe U and R, because that could be confusing.
The reason why U is mentioned in the definition of R is that the ZFC axioms do not allow us to just think of any statement ##\varphi(x)## about an arbitrary set x, and then say that ##\{x\,|\,\varphi(x)\}## is a set. But if y is a set, they do allow us to say that ##\{x\in y\,|\,\varphi(x)\}## is a set.
In my proof, ##\varphi(x)## is the statement ##x\notin x##. The axioms do not ensure that ##\{x\,|\,x\notin x\}## is a set, but if U is a set, they ensure that ##\{x\in U\,|\,x\notin x\}## is a set. This is the set I denoted by R.
I came across a one of micromass' posts about this when I did a search earlier, so I will quote him:
micromass said:
It is indeed true that
[tex]\{x~\vert~x\notin x\}[/tex]does not exist. But the question is, what sets do exist??
Before Russels paradox, it was said that every "collection of objects" was a good set. That means, if [itex]\varphi[/itex] is a property, then
[tex]\{x~\vert~\varphi(x)\}[/tex]is a set. This is the comprehension principle. Of course, this leads to a contradiction with Russel's paradox. So apparently, not every collection satisfying some property is a set. But the question becomes: what is a set?? Can we make a definition/axioms of a set such that all of mathematics still holds but such that things like Russel's paradox not come up.
One such axiom system are the ZFC axioms. Here, the comprehension axiom is replaced by the separation axiom. That is: for every set A, the set
[tex]\{x\in A~\vert~\varphi(x)\}[/tex]is a set. Then Russels paradox does not occur. But does this absolve us from other paradoxes or contradictions?? We don't know and we will likely never know. Godels incompleteness theorem states that it is impossible to prove that ZFC does not have contradictions. But as of now, no contradiction has been found. So most mathematicians believe that ZFC is consistent (but we are unable to prove it).
Maybe the following example is useful. If ##x_1## and ##x_2## are variables that represent real numbers, then we can use the notation ##\sum_{i=1}^2 x_i## for the sum ##x_1+x_2##. To ask about the properties of the set S in ##\{S\in U\,|\,S\notin S\}## is a lot like asking about the properties of the integer i in ##\sum_{i=1}^2x_i##. There is no "integer i" in ##\sum_{i=1}^2x_i##, because this is just a notation for ##x_1+x_2##. Similarly, there's no "set S" in ##\{S\in U\,|\,S\notin S\}##.
The x in an expression of the form ##\{x\in y\,|\,\varphi(x)\}## (where ##\varphi(x)## is a statement about x) is always a dummy variable, just like the i and the S mentioned above. So is every variable that's the target of a "for all" or "there exists".
If I want to say that every non-negative real number has a unique square root, I can say "For all ##y\in\mathbb R## such that ##y\geq 0##, there's a unique ##x\in\mathbb R## such that ##x^2=y##". Here both x and y are dummy variables. The statement isn't in any way a statement about either of those variables. It's a statement about ##\mathbb R##, not about x or y.
I'm bored, so I'll answer the questions you asked micromass before I go to bed.
The notation means "f is the set of all ordered pairs (x,x+5) such that x is a real number".
Pretty much, but not exactly. What's missing is a "for all" or "for each" statement. The function ##f:\mathbb R\to\mathbb R## is defined by ##f(x)=x+5## for all ##x\in\mathbb R##.
Micromass used the notation ##f:A\to B## to let you know that B is either a codomain of f, or the codomain of f (depending on which definition of "function" we use). Either way, it implies that for all x in A, f(x) is in B. So there's no need to mention that separately.
##\mathbb R^+## is defined by that equality. Since the right-hand side is the set of all non-negative real numbers, that's what ##\mathbb R^+## is.
That looks like a typo. x is an element of ℝ. (x,f(x)) is an element of ℝ2. If we drop the 2 from the left-hand side, and define "function" as in definition 1 in my post #122, then this equality says that f=g. But we instead define "function" as in definition 2, then the equality only says that the graphs of f and g are the same. This time we do not have f=g (even though both f and g have domain ℝ, and take every real number to its square), because we have explicitly specified that the codomains are different, and definition 2 ensures that two functions can only be equal if they have the same codomain.
When you say ''that the ZFC axioms do not allow us to just think of any statement ##\varphi(x)## about an arbitrary set x , and then say that ##\{x\,|\,\varphi(x)\}## is a set'' I don't think I understand what you mean exactly.
In the micromass post , he says that p is a property , I thought p was a powerset?
I'm afraid I'm unfamiliar with the logic behind the placements of these symbols: ##\sum_{i=1}^2 x_i## :frown:
Does i = x^1 + x^2?
My unfamiliarity with the concepts makes it difficult for me to follow your arguments in the rest of the post.
Or maybe that's just my current state of mind.I've been confused all day.My best bet is probably to go get some sleep and see what happens tomorrow :smile:
It means that a set of the form ##\{x~\vert~\varphi(x)\}## is not guaranteed to exist. It may exist, but then it requires a proof.
So in general, given a property, there is no set which has as elements all the things which have that property.
For example, I can have the property ##\varphi(x)## as "##x## is a set". The set
##\{x~\vert~\varphi(x)\} = \{x~\vert ~ x~\text{is a set}\}##
would be the set of all set and this doesn't exist.
What the ZFC axioms tell you that a set of the following form: ##\{x\in A~\vert~\varphi(x)\}## is always guaranteed to exist (by axiom). So given a specific set A, we can always form a set of all elements of A that satisfy the property. For example, we can form ##\{x\in A~\vert ~ x~\text{is a set}\}##. This is a perfectly well-defined set (and it is equal to A).
So: given a property, we can (in general) not form a set that contains all things satisfying the property.
But, given a property and a set A, we can form a set of that contains all elements of A containing the property.
Well, we only have 26 letters at our disposal. p means power set of course. But in other contexts, p can mean something entirely different.
In general, I write power set as ##\mathcal{P}## and a property as P.
Does i = x^1 + x^2?
No, i is just a dummy variable. It's part of the notation. It doesn't mean anything.
Given numbers ##x_1,...,x_n##, we define
[tex]\sum_{i=1}^n x_i = x_1 + ... + x_n[/tex]
The "i=" is just part of the notation. We can leave it out and write
[tex]\sum_1^n x_i[/tex]
(of course, the moment that you have multiple sums, you can't leave the dummy variable out anymore).
We can (sometimes) even leave out the entire summation signs. This is routinely done in physics and is called Einstein notation.
I think micromass said it better, so look at what he said in the quote. ##\varphi## is a property (of a set). That just means that for all x, ##\varphi(x)## is a statement about x. So ##\{x\in y\,|\,\varphi(x)\}## would be "the set of all ##x\in y## such that ##\varphi(x)##".
No, he doesn't. It's the greek letter phi, LaTeX code \varphi, ##\varphi##.
That doesn't mean that the symbol can't be used for anything else. We just need to explain what we mean when we use it.
I'm still awake because of insomnia , but I think it's starting to all make sense for some reasons.
Will try to explain it myself and tell me if I understood correctly:
When we say ##\varphi(x)## about an arbitrary set x , we mean to define some kind of characteristic of x.The property is what describes something about x.When write something like ##\{x\,|\,\varphi(x)\}## , it means that a property of x is that it's x , which doesn't make sense , just like saying that a property of the color blue is that's it's blue.Is that right?
If ##\{x\in y\,|\,\varphi(x)\}## , they're saying that the property of x is that it's an element of y.Or are they just saying that x is an element of Y regardless of which property x has , meaning that the crucial point is to relate x to something (y)?
Where I'm still confused is it seemed sometimes we used the left side to ''name'' the set then describe something about it on the right side which is the opposite of what happened there.
Another point I'm confused about is what set is ##\{x\in y\,|\,\varphi(x)\}## ? X?
thanks!
EDIT: I think what I said when I started ''explaining'' doesn't make sense in retrospective.
When I said: ''When write something like ##\{x\,|\,\varphi(x)\}## , it means that a property of x is that it's x.'' I missed the point entirely didn't I? Is the crucial point the fact that it's useless to give a property to x if we don't know where the hell x comes from or where he is or where he stands in relation to anything else?
tell me if I'm right: If ##\{x\in A~\vert ~ x~\text{is a set}\}## , then this is equal to set A and perfectly acceptable.But if ##\{x\in x~\vert ~ x~\text{is a set}\}## , then this is a contradiction because a set can't be an element of itself?
thanks
Fredrik said:
R = ##\{S\in U\,|\,S\notin S\}##
Just another round with this:
Here we want to ''describe'' set R using an element of R , which is S.
We state that an element of R is an element of U , and that the property of this element of R is that it's not an element of itself.So to be an element of R , you need NOT to be an element of yourself.But if you take R , which is a set so not an element of itself , then R is an element of itself based on the property of the elements of R.
It's possible this post cancels most of the questions in my last 2 posts.
This is the paradox?
My brain just exploded guys , see you tomorrow :-p
thanks
edit: the definition of R is ''everything'' that's an element of U that isn't an element of itself correct? So S isn't an element of R per say , but it represent everything that is an element of U and isn't an element of itself , and everything that could be included in this definition will be part of the set R?
So far so good.
This notation would be useless if it was always like that. Some examples of this notation:
The set of non-negative real numbers: ##\{x\in\mathbb R|x\geq 0\}##. We can write this as ##\{x\in\mathbb R\,|\, \varphi(x)\}## if we define ##\varphi(x)## as the statement ##x\geq 0##. Here you should think of "being non-negative" as a property that a real number may or may not have. You should think of ##\varphi## as that property. You should think of ##\varphi(x)## as the statement "x has property ##\varphi##", i.e. "x is non-negative", which in mathematical notation is written as ##x\geq 0##.
The set of even integers: ##\{n\in\mathbb Z\,|\,\exists m\in\mathbb Z~~ n=2m\}##. If we write this as ##\{n\in\mathbb Z\,|\,\varphi(n)\}##, then ##\varphi## is the property of "being even", and ##\varphi(n)## is the statement "n is even", which in mathematical notation is written as ##\exists m\in\mathbb Z~~ n=2m##.
Of course, the ##\varphi## notation isn't needed in these examples, because we can just write out the explicit statement that ##\varphi(x)## or ##\varphi(n)## represents. It's useful when we need a notation for an unspecified statement about a set x.
This is the set of all x in y such that ##\varphi(y)##, i.e. the subset of y that consists of all the members of y that have the property ##\varphi##.
The problem isn't that the notation ##\{x\,|\,\varphi(x)\}## is nonsense. It's not. At least not always. For example, if ##\varphi(x)## is the statement ##x\in y##, then ##\{x\,|\,\varphi(x)\}## is just the set y.
The crucial point is that we can't allow this notation to be used with an arbitrary ##\varphi##, because when we choose ##\varphi(x)## to be the statement ##x\notin x##, then everything turns to nonsense.
However, if y is a set, then the notation ##\{x\in y\,|\,\varphi(x)\}## works just fine with any ##\varphi## we can think of. This is one of the things that the ZFC axioms are telling us.
Yes. Note however that the statement "x is a set" doesn't actually tell us anything, since all the variables represent sets unless we say otherwise (like when we said that ##\varphi## represents a property). You could replace "x is a set" with any other vacuously true statement like x=x, and the result would be the same.
I actually don't know if a set can be an element of itself, but the notation doesn't make sense, because the the first x is a dummy variable and the second x is some specific set.
