How to write a proof: from (A + B) = C to (A - B) = (C - 2B)
- Level: High School
- Thread starter reenmachine
- Start date
- Tags
- Education Highschool Proof
751 replies · 91K views · last reply
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:And this is only part of the notation? The whole thing is ##\{(x,z)\,|\,\text{your statement}\}##? In that case, it still has the problem that the x,y,z have nothing to do with the (x,z). If your statement is true, the set will be "the set of all ordered pairs" (taken from any two sets), which I'm sure is too large to even exist in ZFC set theory. If your statement is false, the set will be ∅.
The part¬(x ∈ A ∧ ¬y ∈ B) ∧ ¬(y ∈ B ∧ ¬z ∈ C)says that if x is in A then y is in B, and if y is in B then z is in C. This is not true for all x,y,z.
Ok , I took the liberty to try my luck at defining G°F using the less shortcuts possible but it seems I'm having problems.It's not the end of the world since I do understand how to define it ''normally''.
thanks man!
reenmachine
- Messages
- 514
- Reaction score
- 9
In the book of proof they introduced the concept of indexed sets.
From what I understood of it , ##A_{1} \cup A_{2} \cup A_{3} \cup ... \cup A_{n}## means that ##x \in A_{i}## in at least one of the set ##A_{i}##.
If you replace the ##\cup## with the ##\cap## , then ##x \in A_{i}## for every set ##A_{i}##.
$$\bigcup_{i=1}^n A_i = A_{1} \cup A_{2} \cup ... \cup A_{n}$$
The same is true if you replace the ##\cup## with a ##\cap##.If there's a known number of set , you could just replace n with that number on top of the symbol.
They talked about the set I , which is called an index set.They say that ##i \in I## .What exactly is the purpose of this set?
Suppose we have $$\bigcup_{i=1}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$ does it mean that ##1 \in I## , ##2 \in I## and ##3 \in I##?thanks ! trying my best to get used to LaTeX , not sure how the post will come out.
- Messages
- 10,876
- Reaction score
- 423
You left out the ##x\in## at the beginning. You can type \dots or \cdots instead of ...reenmachine said:In the book of proof they introduced the concept of indexed sets.
Yes.reenmachine said:If you replace the ##\cup## with the ##\cap## , then ##x \in A_{i}## for every set ##A_{i}##.
It gives us more options with the notation. For example, you can write ##\{A_i|i\in I\}## instead of ##\{A_1,\dots,A_n\}##. Instead of ending a sentence withreenmachine said:They talked about the set I , which is called an index set.They say that ##i \in I## .What exactly is the purpose of this set?
...for all ##x\in\{A_1,\dots,A_n\}##.
you can end it with ...for all ##A_i## with ##i\in I##.
The symbol ##I## isn't assigned a meaning by the above. You have to explicitly say that ##I=\{1,2,3\}## before you can say that ##1,2,3\in I##.reenmachine said:Suppose we have $$\bigcup_{i=1}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$ does it mean that ##1 \in I## , ##2 \in I## and ##3 \in I##?
Looks pretty good. No need to post your experiments, since we have a preview feature. I used my new superpowers to delete your previous post, as requested.reenmachine said:trying my best to get used to LaTeX , not sure how the post will come out.
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:You left out the ##x\in## at the beginning.
Do you mean this:
##x\in A_{1} \cup A_{2} \cup A_{3} \cup ... \cup A_{n}## means that ##x \in A_{i}## in at least one of the set ##A_{i}## ?
It gives us more options with the notation. For example, you can write ##\{A_i|i\in I\}## instead of ##\{A_1,\dots,A_n\}##. Instead of ending a sentence with...for all ##x\in\{A_1,\dots,A_n\}##.you can end it with...for all ##A_i## with ##i\in I##.
Hmm ok , but in this case set ##I## would be the set of all numbers in ##A_{1} , A_{2} , ... , A_{n}## so ##I = \{1 , 2 , \dots , n\}## ?
Would this do the trick?
$$\bigcup_{i \in I}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$
or
$$\bigcup_{i = I}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$
So ##I=\{1,2,3\}## (in that case)
Thanks , I'll try to use LaTeX more and more from now on.I will often have to edit my posts though.
- Messages
- 10,876
- Reaction score
- 423
Yes. You could also end the sentence with "...means that ##x\in A_i## for at least one ##i\in\{1,\dots,n\}##".reenmachine said:Do you mean this:
Note that for all x,
\begin{align}
x\in\bigcup_{i\in I}A_i\ \Leftrightarrow\ \exists i\in I~~x\in A_i,\\
x\in\bigcap_{i\in I}A_i\ \Leftrightarrow\ \forall i\in I~~x\in A_i.
\end{align} What I mean by ##\exists i\in I~~x\in A_i## is "there's an i in I such that x is in Ai". This can also be written as ##\exists i\ \left(i\in I\ \land\ x\in A_i\right)##. Edit: Nope, that last statement is nonsense.
Yes again.reenmachine said:Hmm ok , but in this case set ##I## would be the set of all numbers in ##A_{1} , A_{2} , ... , A_{n}## so ##I = \{1 , 2 , \dots , n\}## ?
Not really, because what if ##A_4=A_1\cup A_2\cup A_3##? Then we also have ##\bigcup_{i\in I} A_i=A_4##, suggesting that ##I=\{4\}##. Edit: I didn't notice that you put a 3 on top of the ##\bigcup##. That's not a standard notation.reenmachine said:Would this do the trick?
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:Yes. You could also end the sentence with "...means that ##x\in A_i## for at least one ##i\in\{1,\dots,n\}##".
\begin{align}
Okay so I could also write ##\forall i\ \left(i\in I\ \land\ x\in A_i\right)## to define the second one?
What about this then?
$$\bigcup_{i = \{1,2,3\}}^3 A_i = A_{1} \cup A_{2} \cup A_{3}$$
If not , I'm not sure what to do.Is it useless to try inserting the definition of ##I## in the notation or should I simply define it separately before starting to define some other set that ##I=\{1,2,3\}## ?
EDIT: What I mean by this is doing something like:
Set ##I = \{1,2,3\}##
...to describe the set ##\{A_{1} \cup A_{2} \cup A_{3}\}##?
It's not clear what ##I## is unless I previously defined it.
thanks!
- Messages
- 10,876
- Reaction score
- 423
Looks like I did that too quickly. The statement ##\forall i\ \left(i\in I\ \land\ x\in A_i\right)## would imply that I is a set that contains all sets, so it's nonsense.
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:Looks like I did that too quickly. The statement ##\forall i\ \left(i\in I\ \land\ x\in A_i\right)## would imply that I is a set that contains all sets, so it's nonsense.
What do you mean? Did you made a mistake in your previous post? (just to be sure we're on the same page)
- Messages
- 22,170
- Reaction score
- 3,335
Fredrik said:This can also be written as ##\exists i\ \left(i\in I\ \land\ x\in A_i\right)##. Edit: Nope, that last statement is nonsense.
I'm not sure why you think that this statement is nonsense. Something like ##\exists x:~P(x)## or ##\forall x:~P(x)## is perfectly allowed. Quantifiers can take as range all sets. The only thing that's not allowed is to call ##\{x~\vert~P(x)\}## a set.
- Messages
- 10,876
- Reaction score
- 423
I'm busy now, I'll explain what I was thinking later.
reenmachine
- Messages
- 514
- Reaction score
- 9
micromass said:The only thing that's not allowed is to call ##\{x~\vert~P(x)\}## a set.
While we're talking about this might as well refresh my mind.
Suppose the set ##A = \{x~\vert~x \in A\}## , this would be an incorrect definition because it says nothing about A except that A is made of his own elements?
Something like ##A = \{x \in A~\vert~x\not \in B\}## if ##A = B'## would be better because it explains what A is is that correct? But I can't say that ##A = \{x~\vert~x\not \in B\}##.
Why can't I say ##A = \{x~\vert~x\in A \land x\not\in B\}## ? Is it because I can't use A in it's own definition , a little bit like not using a word in it's own definition?
thanks
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:I'm busy now, I'll explain what I was thinking later.
No problem man! Take all the time you need , I'm already considering myself very lucky to receive so many good answers to my questions!
- Messages
- 10,876
- Reaction score
- 423
Yes, that's what I meant. This statement is OK:reenmachine said:What do you mean? Did you made a mistake in your previous post? (just to be sure we're on the same page)
This one is not:Fredrik said:Note that for all x,
\begin{align}
\end{align}
Yes, I understand that, but I saidmicromass said:I'm not sure why you think that this statement is nonsense. Something like ##\exists x:~P(x)## or ##\forall x:~P(x)## is perfectly allowed. Quantifiers can take as range all sets. The only thing that's not allowed is to call ##\{x~\vert~P(x)\}## a set.
$$\forall i~~ (i\in I\ \land\ \text{something}),$$ and didn't say anything to restrict the scope of the ##\forall##. So the sentence says that all sets in ZFC set theory are members of the set I.
@reenmachine: The statement "for all i in I, x is in Ai" can be written as
$$\forall i\in I~~ x\in A_i.$$ This should be viewed as a simplified notation for the following sentence:
$$\forall i~~\left(i\in I\ \Rightarrow x\in A_i\right).$$ My mistake was to write ##\land## instead of ##\Rightarrow##.
- Messages
- 10,876
- Reaction score
- 423
Even if we replace ##\land## with ##\Rightarrow##, all we have there is a statement about the set x, so it can't by itself define the set ##\bigcup_{i\in I} A_i##. It says that for all ##i\in I##, we have ##x\in A_i##. This means that x is an element of every ##A_i## with ##i\in I##. A statement like that must be a part of the definition, but it can't be the whole thing.reenmachine said:Okay so I could also write ##\forall i\ \left(i\in I\ \land\ x\in A_i\right)## to define the second one?
There are only two standard notations,reenmachine said:What about this then?
$$\bigcup_{i\in I}A_i,$$ and $$\bigcup_{i=1}^n A_i.$$
I'm not sure what you've been trying to do, but yes, if you want to assign a meaning to the symbol I, you have to do it using one of the standard ways to specify a set. In this case, ##I=\{1,2,3\}## is the obvious option, and ##I=\{n\in\mathbb Z\,|\,1\leq n\leq 3\}## is one of the alternatives.reenmachine said:If not , I'm not sure what to do.Is it useless to try inserting the definition of ##I## in the notation or should I simply define it separately before starting to define some other set that ##I=\{1,2,3\}## ?
Lose the 3 on top, and the notation is fine.reenmachine said:EDIT: What I mean by this is doing something like:
It doesn't really describe it. It's just an alternative notation for it. (And I think you meant ##A_{1} \cup A_{2} \cup A_{3}##).reenmachine said:...to describe the set ##\{A_{1} \cup A_{2} \cup A_{3}\}##?
Exactly.reenmachine said:It's not clear what ##I## is unless I previously defined it.
That's right. The statement would be true, but it doesn't tell us anything about the sets represented by the symbols in it (in particular A). Such statements are said to be vacuously true.reenmachine said:Suppose the set ##A = \{x~\vert~x \in A\}## , this would be an incorrect definition because it says nothing about A except that A is made of his own elements?
B' is only defined when all the sets we're working with are subsets of some set X. Then B' is defined as X-B. B' is not defined here.reenmachine said:Something like ##A = \{x \in A~\vert~x\not \in B\}## if ##A = B'## would be better because it explains what A is is that correct? But I can't say that ##A = \{x~\vert~x\not \in B\}##.
No, but you could say e.g. that ##A = \{x\in C~\vert~x\not \in B\}##, if you have already specified what C is.reenmachine said:But I can't say that ##A = \{x~\vert~x\not \in B\}##.
Right, you can't use the definition while you're stating it. But you also need to be careful when you use the notation ##\{x\,|\,P(x)\}##, because unlike ##\{x\in y\,|\, P(x)\}##, it's not guaranteed by the axioms to always make sense.reenmachine said:Why can't I say ##A = \{x~\vert~x\in A \land x\not\in B\}## ? Is it because I can't use A in it's own definition , a little bit like not using a word in it's own definition?
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:Even if we replace ##\land## with ##\Rightarrow##, all we have there is a statement about the set x, so it can't by itself define the set ##\bigcup_{i\in I} A_i##. It says that for all ##i\in I##, we have ##x\in A_i##. This means that x is an element of every ##A_i## with ##i\in I##. A statement like that must be a part of the definition, but it can't be the whole thing.
Hmmm , by stating that ''This means that x is an element of every ##A_i## with ##i\in I##'' , you are saying that we're making a statement about the set x and not about ##\bigcup_{i\in I} A_i##.
I somewhat intuitively understand but still have some confusion.I will take the liberty of creating a scenario to put things into perspective as I think it might help me in that case.Take note that I am thinking as I type the post.
Suppose a room full of people that have either blond , brown or white hair.There's no bald people or people that have another hair color than blond , brown and white.
Set ##A_1## is made of all people in the room with blond hair , set ##A_2## is made of all people in the room with brown hair and set ##A_3## is made of all people in the room with white hair.
A person with blond hair ##\in A_1## but a person with brown hair ##\not \in A_1## and so on...
We can conclude that the set:
$$\bigcup_{i\in I}A_i = A_1 \cup A_2 \cup A_3$$
...is made of every person in the room.
The earlier statement ''This means that x is an element of every ##A_i## with ##i\in I##'' would mean ##1,2,3 \in I## and ##x \in A_i##.If he is in ##A_i## and ##i \in I## then ##x \in A_1## , ##x \in A_2## or ##x \in A_3## , but since he either has blond , brown or white hair , how could he be an element of each ##A_i##? In a way , to find an element of the big set you have to find what's common between elements from the 3 subsets? Like ''being in the room'' in my previous exemple?
Set notation where x = a person in the room: ##\{ x\in\bigcup_{i\in I}A_i : \forall i\in I \land x \in A_i\}##
Does this really define the set of all people in the room?
ok good
Ok , so if ##I = \{1,2,3,4,5,6,7,8,9\}## then ##I = \{n \in\mathbb Z\,|\,1\leq n\leq 9\}##?
Ok so we only use the number or symbol on top with we have ##i=1## at the bottom and not ##i \in I## ?
What do you mean? I can't write it between {}?
Ok , so B' doesn't really exist except in naive set theory?
So I can't say ##A = \{x \in A~\vert~x\not \in B\}## ?
Because of:
thanks!
- Messages
- 10,876
- Reaction score
- 423
First of all, you shouldn't have included the word "this", because it referred to the previous statement in my post. I assume that you meant thatreenmachine said:The earlier statement ''This means that x is an element of every ##A_i## with ##i\in I##'' would mean ##1,2,3 \in I## and ##x \in A_i##.If he is in ##A_i## and ##i \in I## then ##x \in A_1## , ##x \in A_2## or ##x \in A_3## , but since he either has blond , brown or white hair , how could he be an element of each ##A_i##? In a way , to find an element of the big set you have to find what's common between elements from the 3 subsets? Like ''being in the room'' in my previous exemple?
x is an element of every ##A_i## with ##i\in I## ##.\qquad(1)##
means##1,2,3 \in I## and ##x \in A_i## ##.\qquad(2)##
Clearly (2) is very different from (1). (2) tells us that {1,2,3} is a subset of I. (1) tells us nothing about I. (2) tells us that ##x\in A_i##. (What is i here?) (1) says that x is in all the A_i.Several things here don't make sense. ##\forall i\in I## is only half a statement ("for all i in I such that"), so it doesn't make sense to say that "and" something else. I also don't understand what you're trying to do.reenmachine said:Set notation where x = a person in the room: ##\{ x\in\bigcup_{i\in I}A_i : \forall i\in I \land x \in A_i\}##
Yes to both questions.reenmachine said:Ok , so if ##I = \{1,2,3,4,5,6,7,8,9\}## then ##I = \{n \in\mathbb Z\,|\,1\leq n\leq 9\}##?
You can, if you meant the singleton set whose only element is ##\bigcup_{i=1}^3A_i##.reenmachine said:What do you mean? I can't write it between {}?
I think that even in naive set theory, complements are always defined with respect to some set. You don't use the notation B' if it's not clear from the context what set ##B\cup B'## is.reenmachine said:Ok , so B' doesn't really exist except in naive set theory?
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:First of all, you shouldn't have included the word "this", because it referred to the previous statement in my post. I assume that you meant that
x is an element of every ##A_i## with ##i\in I## ##.\qquad(1)##means
##1,2,3 \in I## and ##x \in A_i## ##.\qquad(2)##Clearly (2) is very different from (1). (2) tells us that {1,2,3} is a subset of I. (1) tells us nothing about I. (2) tells us that ##x\in A_i##. (What is i here?) (1) says that x is in all the A_i.
I was trying to write a set notation for ##A_{1} \cup A_{2} \cup A_{3}## with the knowledge that ##I=\{1,2,3\}##
$$\{x \in \bigcup_{i=1}^3 A_i : \forall i~~\left(i\in I\ \Rightarrow x\in A_i\right)\}$$
Would that be a better set notation for ##A_{1} \cup A_{2} \cup A_{3}##?
ok thanks a lot man!
- Messages
- 10,876
- Reaction score
- 423
If you just want a notation for it, you can use ##\{x\,|\,\exists i\in I~~ x\in A_i\}##.reenmachine said:I was trying to write a set notation for ##A_{1} \cup A_{2} \cup A_{3}## with the knowledge that ##I=\{1,2,3\}##
Note that this wouldn't be a great way to define the notation ##\bigcup_{i\in I}A_i##, since it it's not written in the way that's guaranteed to be "safe". Recall that ##\{x\in y\,|\,P(x)\}## is always OK, but ##\{x\,|\,P(x)\}## is sometimes not.
Since ##A_{1} \cup A_{2} \cup A_{3}## means the same thing as ##\bigcup_{i=1}^3 A_i##, this wouldn't work as a definition, because of the problem of "using the definition while stating it".reenmachine said:$$\{x \in \bigcup_{i=1}^3 A_i : \forall i~~\left(i\in I\ \Rightarrow x\in A_i\right)\}$$
If you meant this as a notation rather than as a definition, and you have previously specified that ##I=\{1,2,3\}##, then you would have to change ##\forall## to ##\exists##. If you do, you have a valid notation for ##\bigcup_{i\in I}A_i##. But the ##\in \bigcup_{i=1}^3 A_i## before the colon looks pretty strange. If you want to put a set there in order to ensure that the notation is in the form that's guaranteed to be safe, it should be a set that's guaranteed to exist by the ZFC axioms and contains all the elements of all the ##A_i##. (Edit: And it can't be the set we want to define).
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:If you just want a notation for it, you can use ##\{x\,|\,\exists i\in I~~ x\in A_i\}##.
I did mean it as a notation , though in some ways I thought the definition should be a part of the notation , which I guess is wrong now.It's like my brain knows it's simple but yet I have some problems keeping the ''big picture'' of all these facts in my head.
I'm still having some confusion on when to use ##\forall## versus ##\exists## , which I guess remains a big problem.I'm trying to pinpoint where I'm confusing the two in my thought process.If ##\forall i \in I \ x \in A_i## it would mean that if ##i=2## , then ##x \in A_i## which is not true since if ##i=2## then ##x \not \in A_1## and ##x \not \in A_3##.Is my observation correct? Then the ##\exists## instead of ##\forall## in ##\exists i \in I \ x \in A_i## makes the connection between ## i \in I## and ##x \in A_i## possible?
If ##\{x\,|\,P(x)\}## is not ok (sometimes) because of the Russell Paradox or similar problems , then we have ##\{x\in y\,|\,P(x)\}## which is always ok.That is very clear , yet if I try to use it with ##A_1 \cup A_2 \cup A_3## I'm confused about what ##y## could represent if ##y## doesn't equal the set we're trying to define.
##I=\{1,2,3\}##
$$\{x \in \ y : \exists i \in I \ x \in A_i\}$$
$$\{x \in \ ? : \exists i \in I \ x \in A_i\}$$
Suppose I try:
$$\{x \in A_i : \exists i \in I \ x \in A_i\}$$
Here ##x \in A_i## repeats itself , would this be an acceptable definition? (since ##A_i## isn't the set we're trying to define?)
Suppose:
$$\{x \in \bigcup_{i \in I} A_i : \exists i \in I \ x \in A_i\}$$
There the definition cannot be safe because I am using the set to define itself.I have a feeling I'm seeing all of this as more complicated than it really is , so in some ways that's comforting
Suppose:
$$\{x \in \bigcup A_i : \exists i \in I \ x \in A_i\}$$
does that even work? In that case the set we're trying to define would be a subset of ##\bigcup A_i##.
To put it more precisely , to define set ##A_1 \cup A_2 \cup A_3## , ##\{x \in y : \exists i \in I \ x \in A_i\}## you need that ##A_1 \cup A_2 \cup A_3 \subseteq y## ?
thanks!
- Messages
- 10,876
- Reaction score
- 423
If you're considering an example such as the one with hair colors, then yes. Otherwise, it's possible that some x is an element of several of the ##A_i##.reenmachine said:I'm still having some confusion on when to use ##\forall## versus ##\exists## , which I guess remains a big problem.I'm trying to pinpoint where I'm confusing the two in my thought process.If ##\forall i \in I \ x \in A_i## it would mean that if ##i=2## , then ##x \in A_i## which is not true since if ##i=2## then ##x \not \in A_1## and ##x \not \in A_3##.Is my observation correct?
Not sure I understand this question. What I'm saying is thatreenmachine said:Then the ##\exists## instead of ##\forall## in ##\exists i \in I \ x \in A_i## makes the connection between ## i \in I## and ##x \in A_i## possible?
\begin{align}
\{x\,|\,\exists i\in I~~ x\in A_i\} &=\bigcup_{i\in I}A_i\\
\{x\,|\,\forall i\in I~~ x\in A_i\} &=\bigcap_{i\in I}A_i
\end{align}
That's understandable because I don't think there's a good answer. Maybe there is no better option than ##y=\bigcup_{i\in I}A_i##. Books on set theory don't define unions with a notation like ##\bigcup_{i\in I}A_i=\{x\in y\,|\,\exists i\in I~~ x\in A_i\}## and a clever choice of y. They do it by referring to the "axiom of union", which says (this is a direct quote from Hrbacek & Jech): For any set S, there exists a set U such that ##x\in U## if and only if ##x\in A## for some ##A\in S##.reenmachine said:I'm confused about what ##y## could represent if ##y## doesn't equal the set we're trying to define.
If we apply this axiom to the set ##S=\{A_1,A_2,A_3\}##, the ##U## that the axiom says exists is the set we denote by ##\bigcup_{i\in I}A_i##. Since the axiom ensures that unions exist, there's no need to worry about the notation ##\bigcup_{i\in I}A_i=\{x\,|\,\exists i\in I~~ x\in A_i\}## not being in the "guaranteed safe" form. It also means that we can take y to be the set ##\bigcup_{i\in I}A_i## and write
$$\left\{x\in\bigcup_{i\in I}A_i~\Big|~\exists i\in I~~ x\in A_i\right\}$$ instead of ##\bigcup_{i\in I}A_i##. It's not wrong, it just looks really weird. It's like writing ##\{x\in A\,|\,x\in A\}## instead of ##A##. Since the statement ##\exists i\in I~~ x\in A_i## is true for all ##x\in\bigcup_{i\in I}A_i##, we might as well write
$$\left\{x\in\bigcup_{i\in I}A_i~\Big|~x=x\right\}.$$ By the way, another notation for the set U is ##\bigcup S##, which in our case means ##\bigcup\{A_1,A_2,A_3\}##. This notation is sometimes useful (when we for some reason don't feel like defining an index set I and choosing a notation like ##A_i## for members of S), but the notations ##\bigcup_{i\in I}A_i## and ##\bigcup_{i=1}^3 A_i## are used much more often.
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:Not sure I understand this question. What I'm saying is that
\begin{align}
\end{align}
Oh ok , so by taking the second one and saying it in reverse it's ##x \in A_i## for all ##i \in I## meaning that ##x## will be in every ##A_i##.
Just to be sure , in ##\{x\,|\,\exists i\in I~~ x\in A_i\} =\bigcup_{i\in I}A_i## , ##x## could be in a single ##A_i## or multiple ones is that correct?
To conclude with this , is ##\{x\,|\,\exists i\in I~~ x\in A_i\}## a notation of the form ##\{x\,|\,P(x)\}## ? If it's not , is it because of ##i\in I## ?
But isn't the set U guaranteed to be the exact same set as S? If U is every elements of S unionized , the result is the same no?
Doesn't ##\{A_1,A_2,A_3\} = \bigcup_{i\in I}A_i## ? (If ##I = \{1,2,3\}##)
If so , doesn't ##S = U## ?
thanks man!
- Messages
- 10,876
- Reaction score
- 423
I wouldn't talk about x as if it's not a dummy variable here. But the statement ##\forall i\in I~~ x\in A_i## does of course mean that ##x\in A_i## for all ##i\in I##.reenmachine said:Oh ok , so by taking the second one and saying it in reverse it's ##x \in A_i## for all ##i \in I## meaning that ##x## will be in every ##A_i##.
It doesn't really make sense to ask about a dummy variable, but it's true that an element of ##\bigcup_{i\in I}A_i## may belong to several of the ##A_i##.reenmachine said:Just to be sure , in ##\{x\,|\,\exists i\in I~~ x\in A_i\} =\bigcup_{i\in I}A_i## , ##x## could be in a single ##A_i## or multiple ones is that correct?
It is, because ##\exists i\in I~~ x\in A_i## is a statement about x, just like P(x).reenmachine said:To conclude with this , is ##\{x\,|\,\exists i\in I~~ x\in A_i\}## a notation of the form ##\{x\,|\,P(x)\}## ?
No.reenmachine said:But isn't the set U guaranteed to be the exact same set as S?
$$\bigcup\{\{1,2\},\{2,3\}\}=\{1,2,3\}\neq \{\{1,2\},\{2,3\}\}.$$
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:$$\bigcup\{\{1,2\},\{2,3\}\}=\{1,2,3\}\neq \{\{1,2\},\{2,3\}\}.$$
I want to make sure I understand this very clearly.
In your exemple , ##S = \{\{1,2\},\{2,3\}\}## and ## \cup \ S = \{1,2,3\}##.
##1 \in \{1,2,3\}## if and only if ##1 \in A## for some ##A \in S##.
##A = \{1,2\} \ or \ \{2,3\}## so ##1 \in A## for some ##\{1,2\} \in \{\{1,2\},\{2,3\}\}## is that a good way of understanding it?
Despite this , I'm still not sure what would happen if we took our previous exemple.
If ##S = \{A_1 , A_2 , A_3 \}## then what is ##\cup##? Can ##\cup = S## sometimes , like in this case? Or is it that ##\cup## will be the set of all elements of ##A_1## , ##A_2## and ##A_3## , while ##S## is simply the set with three elements in the form of ##A_i## ?
thanks a lot!
- Messages
- 10,876
- Reaction score
- 423
Should be \bigcup instead of \cup here.reenmachine said:In your exemple , ##S = \{\{1,2\},\{2,3\}\}## and ## \cup \ S = \{1,2,3\}##.
This is like saying "x=x if and only if x=x". It's not wrong, but it doesn't really say anything.reenmachine said:##1 \in \{1,2,3\}## if and only if ##1 \in A## for some ##A \in S##.
This statement is a bit strange since A is a dummy variable, but I think I know what you mean.reenmachine said:##A = \{1,2\} \ or \ \{2,3\}##
This doesn't make sense. It should be ...for some ##A \in \{\{1,2\},\{2,3\}\}##.reenmachine said:so ##1 \in A## for some ##\{1,2\} \in \{\{1,2\},\{2,3\}\}##
This isn't really an example until you have specified what the ##A_i## sets are. So suppose thatreenmachine said:If ##S = \{A_1 , A_2 , A_3 \}## then what is ##\cup##? Can ##\cup = S## sometimes , like in this case? Or is it that ##\cup## will be the set of all elements of ##A_1## , ##A_2## and ##A_3## , while ##S## is simply the set with three elements in the form of ##A_i## ?
\begin{align}
A_1&=\{1,3,5\}\\
A_2&=\{1,4,7\}\\
A_3&=\{1,5\}
\end{align}
What are the elements of the set
$$\bigcup \{A_1,A_2,A_3\} =A_1\cup A_2\cup A_2 =\bigcup_{i=1}^3 A_i =\bigcup_{i\in I} A_i?$$
Also, don't confuse the letter U with the symbol ##\bigcup U## in the Hrbacek & Jech definition.
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:This is like saying "x=x if and only if x=x". It's not wrong, but it doesn't really say anything.
I was trying to introduce your exemple in your previous statement that:
##A \in \{\{1,2\},\{2,3\}\}## means that A is either ##\{1,2\}## or ##\{2,3\}## no?
I used 1 for ##x\in U## , if and only if ##1 \in A## for some ##A\in S##.Since ##\{1,2\}## could be A since ##\{1,2\} \in S## , then ##1 \in U##.
\begin{align}
A_1&=\{1,3,5\}\\
A_2&=\{1,4,7\}\\
A_3&=\{1,5\}
\end{align}
##\{1,3,4,5,7\}## ?
Is ##\bigcup## = ##U## or not? Is ##\bigcup U## an expression? What I mean is I thought it was ##\bigcup S## and not ##\bigcup U##.I thought the set ##U## was already ''unionizing'' another set ##S##?
thank you so much!
- Messages
- 10,876
- Reaction score
- 423
Yes.reenmachine said:##A \in \{\{1,2\},\{2,3\}\}## means that A is either ##\{1,2\}## or ##\{2,3\}## no?
Right. This is the U in Hrbacek & Jech's definition applied to the set ##S=\{A_1,A_2,A_3\}=\{\{1,3,5\},\{1,4,7\},\{1,5\}\}##, and as you can see, S and U are very different.reenmachine said:##\{1,3,4,5,7\}## ?
I don't remember the exact definition of "expression" from mathematical logic (I think there is an exact definition), but ##\bigcup## is a symbol that's used in the notation for unions. It doesn't denote a set. It looks like a U because that makes it easier to remember that it's part of the notation for unions. In Hrbacek & Jech's definition, U is a dummy variable. The definition says that given a set S, there exists a set U with a useful property. What I said is that this set is often denoted by ##\bigcup S##.reenmachine said:Is ##\bigcup## = ##U## or not? Is ##\bigcup U## an expression? What I mean is I thought it was ##\bigcup S## and not ##\bigcup U##.I thought the set ##U## was already ''unionizing'' another set ##S##?
reenmachine
- Messages
- 514
- Reaction score
- 9
Fredrik said:Yes.Right. This is the U in Hrbacek & Jech's definition applied to the set ##S=\{A_1,A_2,A_3\}=\{\{1,3,5\},\{1,4,7\},\{1,5\}\}##, and as you can see, S and U are very different.I don't remember the exact definition of "expression" from mathematical logic (I think there is an exact definition), but ##\bigcup## is a symbol that's used in the notation for unions. It doesn't denote a set. It looks like a U because that makes it easier to remember that it's part of the notation for unions. In Hrbacek & Jech's definition, U is a dummy variable. The definition says that given a set S, there exists a set U with a useful property. What I said is that this set is often denoted by ##\bigcup S##.
All very clear! I'm very happy with the understanding I have of this section of the book of proof.The next section involves logic , which should be a lot of fun since we already talked about the basics earlier.
Thanks a lot Fredrik! Your help has been tremendously important for my progress.
- Messages
- 10,876
- Reaction score
- 423
Cool. You have certainly made a lot of progress. If you haven't already, you should examine the examples from sections 1.1-1.8 in the Book of Proof, and do some exercises from each of those sections. I recommend that you do enough exercises from each section that you feel like you could do all the others in the section if you wanted to.
reenmachine
- Messages
- 514
- Reaction score
- 9
I have some questions about the set ##P(P(R^2))##. (here P = powerset , couldn't find how to write it in LaTeX.
Suppose we take (1,2) and (2,3) as elements of ##R^2##.
##P(R^2)) = \{∅ , \ ... \ , \{(1,2)\} , \{(2,3)\} , \{(1,2),(2,3)\} , \ ... \ \}##
Would
##P(P(R^2)) = \begin{align}&\{∅ , \ ... \ , \{\{(1,2)\}\} , \{\{(2,3)\}\} , \{\{(1,2),(2,3)\}\} ,\\
&\{\{(2,3)\},\{(1,2),(2,3)\}\} , \{\{(1,2)\},\{(1,2),(2,3)\}\} , \{\{(1,2)\} , \{(2,3)\}\} , \\
&\{\{(1,2)\} , \{(2,3)\} , \{(1,2),(2,3)\}\} , \ ... \ \}\end{align}## ?
I'm not sure if you understand what I'm trying to do , but basically I want the ''powersets of powersets'' concept to become very clear in my mind.
BTW , in the book of proof they denote the set ##R^2## with ##\{(x,y) : x,y \in R\}## , which is a notation of the form ##\{x : p(x)\}##.It still confuses me a little bit when it is correct or not to use it.
About denoting the set ##P(P(R^2))## , would this be a possible notation:
##\{x : x \subset P(R^2)\}##
Here again I have the problem of leaving x alone on the left side.I could do:
##\{x \in ? : x \subseteq P(R^2)\}##
##\{x \in P(P(R^2)) : x \subseteq P(R^2)\}##
thanks !
EDIT: hmm seems like my long LaTeX sentence is ruining the size of the page.How can I fix this?
Would
thanks !
- lostinspace89
- · Replies 11 ·
- Calculus and Beyond Homework Help
- Replies
- 11
- utkarshakash
- · Replies 9 ·
- Precalculus Mathematics Homework Help
- Replies
- 9
- Butelle
- · Replies 4 ·
- Engineering and Comp Sci Homework Help
- Replies
- 4
- j9mom
- · Replies 3 ·
- Replies
- 3
High School
How to Write Set A if Set B is a Factor of it
- anonymous007
- · Replies 1 ·
- Set Theory, Logic, Probability, Statistics
- Replies
- 1
- dancergirlie
- · Replies 1 ·
- Replies
- 1
- DanielT29
- · Replies 5 ·
- AI and Computer Science
- Replies
- 5
- amitccc
- · Replies 9 ·
- STEM Academic Advising
- Replies
- 9
