How was the number 'e' 2.718 originated?
  • Thread starter PrakashPhy
In summary, the mathematical constant 'e' was first referenced in 1618 and is credited to Jacob Bernoulli who attempted to find its value in an equation involving compound interest. It is also used in Euler's identity and has a relationship with trigonometric functions when using complex numbers. Its origins can be traced back to various equations and problems, such as the Taylor series of e^x.
PrakashPhy
35
Since past two years I have been using the mathematical constant 'e' over and again in mathematics (calculus and logarithm). I wonder how this number first originated. Who first used this number , this particular number e=2.718281828459045... .
Thank you for your help in advance.
<<<sorry if this thread already exists in the forum; i searched in the forum but couldn't find it>>>
Mathematics news on Phys.org
The first references to the constant were published in 1618 in the table of an appendix of a work on logarithms by John Napier.[4] However, this did not contain the constant itself, but simply a list of logarithms calculated from the constant. It is assumed that the table was written by William Oughtred. The discovery of the constant itself is credited to Jacob Bernoulli, who attempted to find the value of the following expression (which is in fact e):
[tex] e = \lim_{n\to\infty} \left( 1 + \frac{1}{n} \right)^n[/tex]
The first known use of the constant, represented by the letter b, was in correspondence from Gottfried Leibniz to Christiaan Huygens in 1690 and 1691. Leonhard Euler started to use the letter e for the constant in 1727 or 1728,[5] and the first use of e in a publication was Euler's Mechanica (1736). While in the subsequent years some researchers used the letter c, e was more common and eventually became the standard.
http://en.wikipedia.org/wiki/Euler's_number#History
How at once did he encounter this limit? There must have been some earlier equations or problems or something that led to this equation.
Like pi =3.14... is the ratio of circumference of a circle to its diameter which is a simplest way to understand pi and probably which is the origin of of pi ; I wish to get such simpler and similar information on origin of e
And with a little more digging...
Bernoulli discovered the constant e by studying a question about compound interest which required him to find the value of the following expression (which is in fact e):
[tex]e = \lim_{n\to\infty} \left( 1 + \frac{1}{n} \right)^n[/tex]
http://en.wikipedia.org/wiki/Jacob_Bernoulli
That's how it was discovered anyway. As far as what uses it has, the more time that passed, the more people that found a particular use for e. ex is the only function who's derivative is equal to itself. e is a key component of Euler's identity. etc.
Check http://summer-time-nerd.tumblr.com/post/8628678169" out (it's my blog :)). Apparently Bernoulli (one of them :p) explored this finance problem, where he encountered this limit in this theoretical situation.
Another useful definition of e can be found by taking the taylor series (more specifically, the Maclaurin series) of e^x.
[tex]\begin{align*} e^{x} &= \sum_{n=0}^\infty \frac{( x)^n }{n !} \\ e^1 &= \frac{1}{0!}+\frac{1}{1!}+\frac{1}{2!}+\frac{1}{3!}+\frac{1}{4!}+\frac{1}{5!} +...\\ &=1+1 +\frac{1}{2}+\frac{1}{6}+\frac{1}{24}+\frac{1}{120}+... \end{align*}[/tex]
If you do the same for sine and cosine, and e(i x)
[tex] e^{ix} = \sum_n \frac{(i x)^n }{n !} [/tex]
you'll find a very clear relationship between the exponential functions and the trigonometric functions, using complex numbers.
1. What is the significance of the number 'e' in mathematics?
The number 'e' is a mathematical constant that is approximately equal to 2.718. It is a fundamental number in calculus and is used to represent the base of the natural logarithm. It also has many important applications in fields such as physics, finance, and statistics.
2. Who discovered the number 'e'?
The number 'e' was first discovered by the Swiss mathematician Leonhard Euler in the 18th century. However, it was also independently discovered by other mathematicians, such as Jacob Bernoulli and Johann Bernoulli, in the 17th century.
3. How was the number 'e' derived?
The number 'e' was derived through a series of mathematical proofs and calculations. It was first defined as the limit of (1 + 1/n)^n as n approaches infinity. This led to its representation as an infinite series (1 + 1/1!) + (1 + 1/2!) + (1 + 1/3!) + ... = 2.718...
4. What are the applications of the number 'e'?
The number 'e' has many applications in mathematics and other fields. In calculus, it is used to express exponential growth and decay, and is also the base of the natural logarithm, which has numerous applications in solving equations and modeling real-world situations. In finance, 'e' is used to calculate continuous compound interest, and in statistics, it is used to represent the normal distribution curve.
5. Is there a real-life example of the number 'e'?
Yes, there are many real-life examples of the number 'e'. One example is population growth, where the rate of growth of a population is proportional to the current population, and can be modeled using the number 'e'. Another example is radioactive decay, where the rate of decay of a substance is also proportional to the current amount of the substance, and can be expressed using 'e'.
  • General Math
  • General Math
  • Calculus
