How would I integrate -y'/(y-3)y?
  • Thread starter Thread starter vanceEE
    Integrate
16 replies · 4K views
vanceEE
how would I integrate -y'/(y-3)y??
If you want to integrate that w.r.t. x(which I think is the case),I should say you can't do it. That should be a differential equation but if you don't specify what is it equal to,then its not even a differential equation and you can do nothing with it.For example you may say -y'/(y-3)y=y'' or any other thing and then you should go for finding a method for solving it.
Sorry, the diff. eq is dy/dx = y(3-y) maybe that will help!
Oh...well...that isn't very hard.
You can multiply by dx and divide by y(3-y) to have in rhs and lhs,integrals w.r.t. x and y.Then complete the square in the denominator of the y integral and then set the square part of it equal to sin(t) for a change of variable which solves the differential equation!
Please show, on wolframathematica It is giving my a general logarithmic solution. Can I use the arctan formula for integrals? I am here now:
y'/[(3/2)^2-(y-(3/2))^2] = 1
A different approach than the one Shyan gave is to use partial fraction decomposition to break up the left side.
You have
##\frac{dy}{y(3 - y)} = dx##
You can write the left side as [A/y + B/(3 - y)]dy and then integrate that with respect to y.
You have
Hi Mark!
I think I've got it, I just have one quick question.
$$\frac{1}{3}∫ (\frac{dy}{y-3}-\frac{dy}{y}) = ∫ 2 dx → -\frac{1}{3} ln |3-y| + \frac{1}{3} ln |y| = 2x + C $$
why does the 3 and the y switch places? When solving for y at the end, I get $$\frac{-3e^{3(2x+C)}}{e^{3(2x+C)}-1}$$
unless the y and the 3 switch places in the natural log, which gives the correct answer of
$$ \frac{3e^{3(2x+C)}}{e^{3(2x+C)}+ 1} $$
**THE 3(2x+C) are exponents
why do we change y-3 to 3-y??
When I did the partial fractions business, I got this:
$$ \frac{1}{y(3 - y)} = \frac{1/3}{y} + \frac{1/3}{3 - y}$$
The last fraction is the same as -(1/3)/(y - 3). If you integrate, you get 1/3 [ ln|y| - ln|y - 3|] = 1/3 * ln[|y/(y - 3)|]. Notice that |3 - y| = |y - 3|.
The factor of 2 that you show in the original differential equation will change dx to 2dx, so the integral of the right side changes from x + C to 2x + C.
So when taking the base e of both sides, must I change |y-3| to |3-y|? Switching these signs gives me different answers when solving for y, are they both considered correct?
I think that you might have made a mistake when you exponentiated both sides (what you referred to as "taking the base e of both sides").
After I integrate, I get 1/3 * [ln|y| - ln|y - 3|] = 2x + C, or [ln|y| - ln|y - 3|] = 6x + C'. That's the same as ln[|y|/|y - 3|] = 6x + C'.
Without an initial condition, you can't get rid of the absolute values. Is there an initial condition that you haven't shown us?
Since
Since
The initial DE is $$\frac{dy}{dx} = 2y(y-3)$$
After integrating I get
$$-ln|y-3|+ln|y| = 3(2x+C)$$
then after exponentiation I get..
$$\frac{y}{y-3} = e^(3(2x+C)) $$
$$\frac{y-3}{y} = \frac{1}{e^(3(2x+C))} $$
$$-\frac{3}{y} = \frac{1}{e^(3(2x+C))} -1$$
$$-\frac{3}{y} = \frac{1-e^(3(2x+C))}{e^(3(2x+C))} $$
$$y = -\frac{3e^(3(2x+C))}{1-e^(3(2x+C))} $$
But, via. the link provided, the solution is $$\frac{3e^(3(2x+C))}{e^(3(2x+C))+1}$$
since $$|y-3|$$ was changed to $$|3-y|$$
Are both solutions correct?
*the 3(2x+C)'s are exponents
Two things:
1. Where did the absolute values go? As already mentioned, if there is an initial condition, you might be able to get rid of them, but you don't show an initial condition. Are you making an assumption that y(x) and y(x) - 3 are both positive?
2. In LaTeX, put exponents inside braces - {}.
The expression on the right side should be written as e^{3(2x+C)} to make it render correctly. Also, instead of writing 3(2x + C), you can write 6x + C', where C' = 2C.
Writing the right side as ##e^{6x + C'}## allows you to write it as e6x * eC' = Ae6x, where A = eC' = e2C.
|y - 3| and |3 - y| are identically equal, so you can change one for the other. The bigger question is what happened to the absolute values in the first place?
You can check to see. If they both satisfy the differential equation, they're both correct.
Mark44 said:
Two things:
The question says "Let f be a function with f(0)=1 such that all points (x, y) on the graph of f satisfy the logistic differential equation $$\frac{dy}{dx} = 2y(3-y).$$"
With f(x) = y, f(0) = y(0) = 1, and 3 - y(0) = 2. Both expressions are positive, and if we assume that x is close to 0, then both y(x) and 3 - y(x) will be positive.
This allows us to remove the absolute values.
y/(y - 3) = Ae6x
##\Rightarrow## (y - 3)/y = Be-6x
Use the initial condition (y(0) = 1) to solve for the constant B, and then solve for y in terms of x.
