How would we define a value for acceleration if only the direction is changing?
2 replies · 1K views
mancity
How would we define a value for acceleration if only the direction is changing and not the speed?
acceleration has both speed and direction
Acceleration is the time derivative of velocity, not speed. It is defined as ##\vec a = d\vec v/dt##.
Edit: If speed ##v## is constant, then ##\vec v = v\vec e## where ##\vec e## is a unit vector. The acceleration would then be ##\vec a = v (d\vec e/dt)##, ie, the speed multiplied by the derivative of the unit direction.
Reply
mancity said:
Homework Statement: How would we define a value for acceleration if only the direction is changing and not the speed?
Relevant Equations: acceleration has both speed and direction
The most common example of this is uniform circular motion, where an object or particle moves in a circle at constant speed. In this case, the acceleration vector points to the centre of the circle. This is known as centripetal acceleration. See, for example:
https://byjus.com/physics/uniform-circular-motion/
Or, a more advanced analysis here:
https://openstax.org/books/university-physics-volume-1/pages/4-4-uniform-circular-motion
Reply
