Hubble's Law and Star Velocity
The discussion revolves around Hubble's Law and its implications for star velocity, exploring theoretical relationships between distance and velocity in the context of an expanding universe. Participants examine mathematical formulations, the validity of special relativity in cosmological contexts, and the interpretation of observational data.
  • One participant presents a formula for star velocity based on Hubble's law and claims that the universe is expanding faster, suggesting a maximum expansion speed can reach the speed of light.
  • Multiple participants challenge the dimensional consistency of the proposed equation and question its derivation.
  • There is a discussion about the relationship between star velocity and distance, with references to Hubble's law and the superposition of velocities.
  • Some participants express uncertainty about the validity of applying special relativity in cosmological contexts, particularly in non-flat spacetime.
  • Concerns are raised regarding the clarity of variable definitions and the implications of using certain mathematical relationships.
  • One participant argues that the observed expansion exceeding the speed of light is a consequence of separation distance rather than true velocity, emphasizing the role of Hubble's law.
  • Another participant introduces the concept of the observable universe and discusses the implications of its finite or infinite nature.
Participants generally disagree on the validity of certain claims and mathematical formulations. There is no consensus on the implications of Hubble's law at large distances or the applicability of special relativity in this context.
Limitations include unclear definitions of variables, unresolved mathematical steps, and the dependence on the validity of Hubble's law at varying distances and speeds.
Gege01
TL;DR
The universe is still expanding faster! The maximum expansion speed can reach the speed of light C! Thereafter, the expansion rate slowed down.
By using Hubble's law and the principle of velocity superposition of relativity, we can deduce when the distance of star from the observation point is (photometric distance)r, its velocity V can be expressed as:
V = Csin (Hr/C)
Therefore, the following conclusions are drawn:
The maximum radius of the universe is 3.14 times that of today.
Most of what you've said here is incorrect. I highly recommend the attached "Expanding Confusion". Read it carefully and if you have questions, come back and ask.
Gege01 said:
V = Csin (Hr/C)
This equation appears to be dimensionally inconsistent. Where did you get it?
Thank you very much!
There is a functional relationship between star velocity and distance:
V=V(r)
245993
V=V(r)
245994
It can satisfy Hubble's law :
V(dr’) =Hdr’
The true velocity V(r+dr) of B, measures by viewer of o, is the superposition of the velocity V(r) of the star A and the velocity V(dr') of the star B relative to A.
245995
245996
The relationship between dr’ and dr is:
dr’=γdr
Also, according to the differential definition:
V(r+dr)-V(r)≡dV(r)
We get
245997
After the above formula, wei have
245998
V(dr’) =Hdr’
Oh, I see. I thought your Hr was the Hubble radius so Hr/c would have units. But you meant H is the Hubble constant and r the radius so Hr has units of velocity and Hr/c is dimensionless.
Next time please be clear about the meaning of your variables.
Thank you for your reminder.
Gege01 said:
We get
Note that the last formula only follows from the previous one for ##r\le \frac{\pi}{2} \frac{c}{H}##. So you cannot use it to claim:
Your claim is based on applying a formula in a region where it is not valid. I am not certain that the rest of the derivation is correct, but at least that part has clear mathematical limitations.
Yes, some of the conclusions are not very rigorous.
However, it is reasonable in the scope of r≤πc/(2H).
I am not sure. With none of the variables being clearly defined it is hard to follow. Unless this has been derived in the professional scientific literature (not only Chinese) then it is highly suspect.
Based on the following facts That Hubble's law is valid at short distances and at small speeds:
V(dr') = Hdr'
Although we can't guarantee that Hubble's law holds at large distances and high speeds, we can still assume that special relativity is satisfied.
The true velocity v (r + dr) of b, measured by the observer of o, is the superposition of the velocity v (r) of a star and the velocity v (dr') of B star relative to a.
dr’=γdr
This appears to me to be attempting to relate the distance, ##dr##, between two nearby objects as measured by local observers to the distance, ##dr'##, measured by observers who see the objects receding at ##Hr##. It seems to be simply the special relativistic formula for length contraction, and therefore assumes a single inertial reference frame covering a spatial patch of radius at least ##r##. This seems to me unlikely to be valid at cosmological distances.
No we can’t. Special relativity is only satisfied for flat spacetime. The FLRW spacetime is not flat.
What is dr’. What are a, b, and B? Which observer is o?
246005
Dale said:
No we can’t. Special relativity is only satisfied for flat spacetime. The FLRW spacetime is not flat.What is dr’. What are a, b, and B? Which observer is o?
Although FLRW spacetime is not flat,We can still think that special relativity can be satisfied in a very small space-time range.
O is the position of any observer. A is a star whose distance from the observer is r.
B Distance Observer Distance is r+dr
The distance of B measured by point A observer is dr'
Sure, but “the maximum radius of the universe” hardly qualifies as “very small”.
What your seeing as expansion >c is a consequence of separation distance between the observer (us) and the objects beyond Hubble horizon. In point of accuracy the expansion rate is approximately 70 km/s/Mpc far slower than c. If you situate an observer at every Mpc this rate will be the same in our universe today.
Due to Hubble law ##v_{resessive}=H_OD## the greater the distance the greater the resessive velocity the separation distance gives the appearance of exceeding c. However this is merely a consequence of the separation distance and application of Hubble's law nor a true velocity.
If you prefer to apply Hubble's law in terms of radius simply replace D with r. V=Hr. SR isn't needed to apply this as pointed put it's a simple consequence of separation distance and expansion rate.
When we study specific problems, for example, the distance between A and B is R and r+dr, then, in the range of R to r+dr, it is a small area. Special relativity is satisfied
The radius of the observable universe being roughly 46 billion light years isn't small. Think about how far into the past you are looking at when you see the surface of last scattering at z=1100. Does that sound like something SR handles ?
Edit: I should specify in this scenario as certainly the FRWL metric applies GR and SR. Example being it's light cone and worldline applications.
If the universe is finite but unbounded, it means that the universe is smaller than the observable universe. In this case, galaxies that look far away may be illusions of neighboring galaxies, which are illusions created by light circling the universe. This hypothesis is very difficult to detect because galaxies are different at different ages, or even completely different.
No it doesn't the observable portion is certainly finite as the cosmological event horizon sets an observational limit. The full universe could very well be finite or even infinite.
We simply do not know as we cannot observe or measure the entire universe. We however do know it is far larger than our observable portion.
The mirror effect you described was once studied but observational evidence of objects at extreme distances have different metalicity percentages than objects nearby. Then there is also different temperatures involved. As you approach the CMB the temperature rises.
Observational data doesn't rely solely on distance estimates but also includes thermodynamic changes due to expansion.
If we use the formula in this post, some data may be changed.
This conclusion is based on the following assumptions:
1. Hubble's law is valid at small distances and velocities.
2. Special relativity can be satisfied in a very small space-time range.
3. There is a functional relationship between star velocity and distance:
V=V (r)
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 22 ·
  • · Replies 57 ·
