Human Brain vs. Quantum Computer
The discussion revolves around the comparison of the human brain to various types of computers, specifically quantum, classical, and semi-classical models. Participants explore the implications of these comparisons in terms of processing speed, efficiency, and the nature of consciousness, touching on both theoretical and conceptual aspects.
  • Some participants propose that the human brain could be likened to a quantum computer due to its potential subatomic processes, while others argue it is more accurately described as a classical computer.
  • There is a suggestion that the brain's processing speed and efficiency might not surpass that of artificial brains, which could perform certain operations much faster.
  • One participant questions whether the brain utilizes quantum superposition in its calculations, while another asserts there is no evidence supporting this claim.
  • Some participants express skepticism about the idea of quantum consciousness, noting that it remains a contentious topic with limited empirical support.
  • Discussions include the role of electrochemical interactions in brain function, with some arguing that these interactions alone cannot account for sensory experiences.
  • There are references to research on consciousness and quantum effects, with varying degrees of acceptance and skepticism among participants.
  • Several participants highlight the importance of efficiency over speed in computing, suggesting that the classical model may align more closely with brain function.
Participants exhibit a range of competing views regarding the nature of the brain in relation to computers, with no consensus reached on whether it is best described as a quantum, classical, or other type of computer. The discussion remains unresolved with differing opinions on the implications of quantum mechanics for brain function.
Some claims about the brain's processing capabilities and the nature of consciousness are based on speculative interpretations and lack empirical backing. There are also unresolved questions regarding the definitions and assumptions underlying the comparisons made between the brain and various types of computers.
Hyperreality
Do you think the human brain is best described
a) Quantum computer
b) Classical computer
c) Semi-classical computer
d) None of the above
Cheers
Biology news on Phys.org
Quantum computers, because the protein folding is at a photon level, right? As well as the synapse connections in the brain which are subatomic. Would an animal brain be like this as well?
The brain is as fast as you can go I think, so an artificial brain couldn't go any faster and it might or might not be more efficient to have parallel processing in either or comparatively.
Side Note:
Theories suggesting that robots will somehow become smarter then man probably won't be true unless man decides not to live longer then robots though. Because we are less sturdy.
But to be a quantum computer, doesn't by definition the computer use superposition in calculations as another possible "state?"
There's no evidence that the brain uses quantum superposition to perform calculations. There's also no evidence that the brain is anything more than a chemical computer with incredible optimizations discovered by billions of years of evolution.
Even mechanical computers can perform certain kinds of operations ten of thousands of times faster than human brains, so I certainly don't think it's accurate to say that the human brain is, in any sense, "faster" than any possible artitifical brain.
- Warren
I got that wrong. I have read that the brain can operate at a sub-atomic level at the Axon, but not Quantum (Quark, Lepton etc.).
Where do our thoughts come from? Maybe a Quantum computer can better help identify that.
I agree the artificial computer is probably always faster.
This topic is discussed allot with programming languages too. It's not speed that's most important but an overall efficiency. First it has to be efficient to the task and then speed is secondary.
The Classical computer is probably like the brain
a) Quantum computer
Cheers
d)Fuzzy logic computer ?:-p :smile:
The brain simply just looks like a Labyrinth maze. I think that's pretty cool.
Axons are not sub-atomic. Axons operate at the cellular level with electrochemical reactions.
None of the above from what little I know of the human brain or anyone does for that matter, I'd say it is a biological "entity" with a great deal more potential than any computer, at least for now.
Quantum conciousness is a very: shall we say contentious subject although I've seen a bit of research I'm not sure I'm convinced, and anyway it only deals with quantum tunneling and is nothing similar to quantum computing.
IIRC correctly Arizonas University's website has some interesting research into brain function, and a little bit about Quantum conciousness?
http://www.consciousness.arizona.edu/"
Paul Davies’ lecture was on ‘life and consciousness as emergent
phenomena’. He laid out many basic quantum terms and phenomena
in a clear way: quantum indecision, superposition, entanglement,
quantum clock, coherence, decoherence, and gravity. Then, in an
admittedly wildly speculative tone he suggested that the conditions
for life and consciousness might be limited by quantum effects, and
that the former might have harnessed quantum effects to improve performance,
so that quantum mechanics might be their midwife or at
least helper. Time keepers in cells might be quantum clocks; proteins
might fold at a quantum edge; decoherence may be the killer; and
thoughts move muscles through downward causation. He closed with
the challenge to find the physics of consciousness...
Wll I'm reaching here but there was some research into tubuoles between axons and QET effects, but it's not as if it's accepted even if it is published.
If I were a "quantum computer" is there some line of question(s) that you can ask me to determine if I were either a human or computer?
Well my pocket calculator is faster and better at maths than me, it has a better memory and it will most likely last longer than me. I am not so sure of the "Quantum SuperBrain" thing. There are a lot of stupid people about.
I would lean more towards a classical computer, but i don't know much about either. I think the genius is in the programming, not the method of computing, complex heuristics.
How about: Are you a quantum computer? *chuckle*
I could be programmed to conceal my true identity, therefore, "No! I can not divulge that answer.".
the human brain is an electro-chemically based classical computer which contains ~10^15 bits of information and processes it at ~10^16 operations per second- now while all matter performs quantum computation by it's very nature there does not appear to be any processes in the brain which harness any natural forms of quantum computation of it's constituent proteins or chemistry- at least not in any general or direct fashion in terms of basic brain functions- edit:[the subtle fringes of emergent perception and awareness might be another matter however]
Yes, I agree.
Do you have any reputable references for these figures, or did you simply make them up? It doesn't make any sense to apply the concept of "operations per second" to the brain.
- Warren
I don't think you can chalk it all up to electro-chemical interactions.
How do you see?
How do you smell?
How do you taste?
How do you feel?
How do you hear?
Basically, how do you sense?
Even if the brain was a chemical computer, a number of these effects rely on quantum interactions to take part in the 'total picture'.
I like the superposition analogy where consciousness is a quantum singularity arising from these chemical interactions that can interact with the various 'evolved' structures of the brain to interpret information.
However, this is just my opinion.
I have no idea why you think sensation is in any way related to quantum mechanics.
This is nothing more than word salad, as the phrase "quantum singularity" is meaningless. Please note that personal theories are not welcome here.
- Warren
http://science.slashdot.org/article.pl?sid=06/12/11/1952201"
Eyesight has a good analogy too with CCD sensors.
Taste would fall under the same realm as smell.
As for a personal opinion, isn't that's what was being asked for by the original question?
I'm just interpretting quantum singularity to mean 'point of view'. That's something we all have, correct?
If anyone would like to explore the idea of "superposition" or "non-locality" of neuronal impulses please feel free to comment in this thread
https://www.physicsforums.com/showthread.php?t=147833
on the PhysicsForum
Its in the Metaphysics & Epistemology section of philosophy.
- Warren
it's on the high end of the average values given by Moravec/ Merkle http://www.merkle.com/brainLimits.html and Schmidhuber http://www.idsia.ch/~juergen/raw.html
10^15 bits is quite basic: the average adult human brain contains a few hundred billion neurons each with a few thousand connections on average- and individual synapses are Boolean operators: either active or not- contrary to what many believe- the complex electrochemistry of the brain does NOT affect the quality of neural signals- there is no 'gradient' of neural activity- a synapse is either active or not active- 1 or 0- the complex neurochemistry affects brain-states through modulating the NUMBER of active signals in bundles and groups of neural signals- therefore all aspects of the deepest most complex brain activity are entirely based on Boolean operations in those 10^15 connections- this is discrete foundation of the brain's function [I was once one of the skeptics myself of interpreting the brain's function as a linear computation before this discovery- I always thought that a true algorithmic expression of the brain would require detail to the very quantum state of every atom in the brain and it's local environment- but it isn't so! all that complex biochemistry and physics only serves as a sysem that influences which synaptic bits get flipped]- at least this is what the evidence supports at this time
Well, you'd first have to show that the brain actually works in "binary" (01010). Neural nets are a much viable alternative.
I wish I had noticed this thread a lot sooner. :bugeye: As chroot and berkeman have explained, neurons function through chemical signaling and ion gradients. The rest of the posts are completely off-base speculation, and for that reason, I'm going to lock this thread.
  • · Replies 40 ·
9K
  • · Replies 29 ·
