Calculating Force on Shaft Bearings - Hydro Power Systems
The calculation of force on shaft bearings in hydro power systems involves understanding both axial and radial forces, as well as the impact of vibration, which is specified at 2 mm/sec. A simplified model includes components such as lumped masses and springs representing the rotor, shaft, bearings, and machine frame. Accurate bearing force calculations require knowledge of unbalance moments and speeds, particularly in simple machines. For complex systems, a two-plane dynamic balance is essential to minimize unbalance forces compared to hydrodynamic forces, which can vary at the blade passing frequency.
  • Understanding of axial and radial forces in rotating machinery
  • Knowledge of vibration measurement techniques and specifications
  • Familiarity with dynamic balancing methods in mechanical systems
  • Basic principles of hydrodynamic forces in rotating equipment
  • Research the calculation of unbalance moments in rotating machinery
  • Learn about two-plane dynamic balancing techniques
  • Explore hydrodynamic force calculations in hydro turbines
  • Study vibration analysis methods for rotating equipment
Mechanical engineers, vibration analysts, and professionals involved in the design and maintenance of hydro power systems will benefit from this discussion.
tamar
TL;DR
Force calculation
I know the moment of inertia and the rotating speed of a shaft, and the allowable vibration is 2mm/sec. How is the force calculated? What is the formula to calculate the force on the shaft bearings which are a know distance from centre of gravity?
Thanks
:welcome:
Which forces, axial or radial? What does vibration have to do with it?
Is this a homework question? If so, we can move it to a homework forum, and you are required to post your attempt at the answer before getting help.
Not a homework question.
Both axial and radial.
Vibration means it is the limit allowable as an unbalanced load for vibration hence this will exert extra load on bearings which I need to calculate.
School notes I have pulled out from the garage from 30yrs ago:)
It would depend very much on the type of hydro turbine, and its condition. I don't know of any simple formula. Perhaps others here can help, such as @jrmichler
A vibration specification of 2 mm/sec can be translated into acceleration and displacement if it is at a single frequency. This is only rarely the case.
A simplified model of a simple rotating machine, such as a simple hydro turbine is as follows:
A lumped mass representing the rotor
A spring representing the shaft
A spring representing the bearing
A lumped mass representing the bearing housing
A spring representing the machine frame
A lumped mass representing the machine frame
A spring representing the machine foundation
Vibration measurements are typically made on bearing housings, and sometimes on machine frames. Given all of the springs and masses in a simplified model, calculating bearing forces from a measurement made on the bearing housing is only rarely possible.
If you have an unusually simple machine where all stiffnesses are "large", and there is a known unbalance, then bearing forces can be calculated from the unbalance moment and speed. This would be the case in, for example, a one cylinder engine or reciprocating air compressor.
The real world solution is to do a two plane dynamic balance, then calculate the hydrodynamic forces. If it is properly balanced, the unbalance forces will be small compared to the hydrodynamic forces. Note that hydrodynamic forces can vary at the blade passing frequency, which is a cause of vibration.
Likes anorlunda, berkeman, Lnewqban and 1 other person
  • · Replies 16 ·
  • · Replies 28 ·
