Hydrogen Atom; energy state transitions
The discussion revolves around the energy state transitions of a hydrogen atom, specifically focusing on the transition from the n=3 state to the ground state and the associated photon emission. Participants are examining the implications of energy calculations related to this transition.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are exploring the formula for calculating energy levels in a hydrogen atom and questioning the negative value obtained for ground state energy. There is uncertainty regarding the correct application of the energy formula and its implications for ionization energy.
The discussion is active, with participants questioning the validity of the formula used and the interpretation of the negative energy value. Some guidance has been offered regarding the correct formulation of energy levels, indicating a productive exploration of the topic.
There is mention of potential confusion regarding the derivation of energy levels and the assumptions about ionization energy, which may affect the understanding of the problem.
hhhmortal
A hydrogen atom is initially in the state n=3. Subsequently it falls to its ground state with the emission of a photon. If the photon energy is ћω , then what is the ground state energy?
I tried using E= h².n²/8ma².
and got -9ћω/8
I wasn't to sure how to go about with this question.
Uh, how did you get a negative ground state energy using that formula?
Not too sure. I think that formula would just give you the energy of the level, but doesn't the electron in that level require that amount of energy to be ionised, hence the negative sign.
You are right about that. And in fact, I think your answer is right. On the other hand the formula you gave for E is wrong. Why do you try and write down a clear derivation of your result?
I'm not too sure, I think I just used that equation then I canceled out certain terms and multiplied it by ћω. This is wrong, but I can't find the right way of doing it.
Start by finding the correct formula. The formula for the energy levels has an n^2 in the denominator, not the numerator. How can you be 'not to sure' of how you got the answer?!
  • · Replies 0 ·
  • · Replies 21 ·
