Hydrostatic force, half circle
3 replies · 11K views · last reply
kevtimc
Find the hydrostatic force on any side of a bottom half-circle with a 6 m diameter with the top 1 m above water level.
http://img377.imageshack.us/my.php?image=45095885io3.png"
P = 1000 * 9.8 (mass density of water) * displacement
A = l * w
F = P * A
Pressure = density * gravity * displacement
displacement = (2 - y)
x = [tex]2\sqrt{9 - y^2}[/tex]
A = x * delta y (for any rectangular strip)
I'm concerned with my displacement; would it be 2 - y?
Would I be integrating from -1 to -3?
EDIT: I looked over the problem again, I think what we really have is a semi circle with a radius of 2 at sea level.
The area would be 2 * sqrt(4 - y^2) and the displacement just y, I think :)
No, you do not have a semi-circle with a radius of 2: the problem specifically says a "half-circle with a 6 m diameter" so you have a semi-circle with a radius of 3 m, not two. The fact that the water only comes up to 1 m below the top means that the depth for any y (with [itex]x= \sqrt{9- y^2}[/itex]) is y-1. You will want to integrate from y= 1 to y= 3.
(Note: I've taken my positive y-axis downward to avoid negatives.)
Thanks, but I'm having trouble with the second integral in the problem:
[tex]2pg \int (y-1) * \sqrt{9-y^2}[/tex]
For: [tex]2pg\int \sqrt{9-y^2}[/tex] from 1 - 3 (when integrals are separated)
doesn't that evaluate to [tex]2pg \int9*cos^2\theta[/tex] ?
I'm not getting the correct answer when I evaluate this integral.
I'm having a problem with the exact same problem. The answer should be 6.7x104N, but I have yet to get this answer.
I evaluate [tex]2pg\int(y-1)\sqrt{9-y^{2}}dy[/tex] from 1 to 3
And get: [tex]2pg\inty\sqrt{9-y^{2}dy - 2pg\int\sqrt{9-y^{2}}dy[/tex] from 1 to 3.
I then do u substitution for the first integral using [tex]u=9-y^{2}, du=-2y, -\frac{1}{2}du=ydy[/tex]
For the second integral, since the are is a semicircle, I use [tex]2pg\pi3^{2}[/tex]
So I have: [tex]-pg\inty\sqrt{u}du - 2pg\pi3^{2}[/tex] from 1 to 3.
Then I take the antiderive of the first integral to get
[tex]-pg\frac{2}{3}(9-y^{2})^{\frac{3}{2}} - 2pg\pi3^{2}[/tex]
From here I plug in the numbers and get:
[tex]-147832-277088[/tex] which give me [tex]-424920[/tex] I then divide it by 2, since it says to find the Hydrostatic Force on one side of the semicircle to get [tex]2.1x10^{5}[/tex]
I think I'm making a little mistake somewhere, but I can't seem to figure out where. Any help would be appreciated.
