Hydrostatic forces on a submerged curved surface question
The discussion revolves around a fluid mechanics problem involving hydrostatic forces on a submerged curved surface. The original poster seeks assistance with calculations related to pressure and forces acting on a partially submerged gate.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the definition of pressure and its application in calculating forces on the surface. There are attempts to clarify the direction of pressure and the method of integrating forces over the surface. The original poster expresses difficulty in calculating the vertical component of the force due to uncertainty about the volume of water above the gate. Geometry and calculus are mentioned as potential methods for finding this volume.
Participants are actively engaging with the problem, exploring various methods to calculate the necessary areas and volumes. Some have provided hints and guidance on how to approach the geometry involved, while others are working through the implications of the problem setup. There is a collaborative effort to clarify concepts and assist the original poster in understanding the calculations needed.
The original poster notes that they are accustomed to problems with fully submerged surfaces, which adds complexity to this particular question. There is an emphasis on patience and understanding the geometry involved in determining the volume of water above the gate.
abuh11
No template because of misplaced homework
Hi, i would like to know how to do this question for fluid mechanics. Sorry as I am new i didnt know how to upload images so i just uploaded the image in justpaste, here is the link http://justpaste.it/pz7r
May you know a pressure definition like ##P=\frac{F}{A}##.
You can use it as ##dF = P\,dA## with direction vertical to surface.
I think what you mean is "perpendicular to the surface" rather than "vertical to the surface." Abuh11, to elaborate, the pressure at any depth is acting in the direction perpendicular to the surface. So you need to determine the pressure at each depth, multiply by the differential area involved, and add the forces vectorially (i.e., integrate over the arc of the surface).
Thanks for your reply, what I normally do is use F = pgha to find horizontal component of the force, then use F = phv to find vertical component forces, then I find out the actual force using F^2 = FH^2 + FV^2. However the problem I’m having is finding the vertical component as I don’t know how to calculate the volume of the water that the shape is occupying. I normally work with questions in which the curved surface is fully submerged whereas here it is only partially submerged. The correct answer is meant to be 52050N although I’m not getting it with my current calculations.
There's another way to do this. Do you know how to calculate the weight of the part of the water sitting directly above the gate?
no
abuh11 said:
no
Do you know how to find the volume of this water using geometry or calculus?
I used geometry but not calculus
OK. From geometry, what is the volume of water directly under the gate.
That is part of the problem, i know how to do this for when the curved surfaces is fully submerged, but for this type of question i don't know how to do it.
I asked you for the volume of liquid below the gate. This is a geometry question, not a physics question. This is just the first step in getting to the answer you want. If you 're not willing to be patient, I won't be able to help you. This is part of how we determine the vertical component of force on the gate.
i don't know how to do that for this type of question.
Hint: Find area A, then area B.
Interesting, i see where you are going with this, but how would you find the area of B.
You find A +B and subtract A to get B
Ok, i done that. I got A and B now, what should i do with these numbers now?
Area B can get you to the volume of water displaced, right?
How would you find the area of the shape above A, I am asking as i tried subtracting A from the area of the entire semi circle, but in order to find B we need to take into account the area above/next to A.
abuh11 said:
...in order to find B we need to take into account the area above/next to A.
Not really. What are the angles of triangle A? What is the area of the sector of the circle (A+B)?
I don't think we know the angles of A.
Hmm...a right triangle with two of the sides known...you've had trigonometry, right?
yay. I manged to figure it out using your diagram and information. Thanks a lot.
An interesting problem; I enjoyed working on it.
insightful said:
I like problems with obvious real-world application:
https://en.wikipedia.org/wiki/Tainter_gate
Yeah this question was actually one question from a exam for my course, I am studying civil engineering (one of benefits as you mentioned is that the math is applied).
  • · Replies 17 ·
  • · Replies 22 ·
