Hypsometric equation derivation: why is g/R in the exponent?
  • Thread starter Thread starter arenaninja
1 reply · 4K views
arenaninja
Derive the hypsometric equation, assuming a sea level temperature of 15 C, and that the temperature decreases with heigh at a rate of 6.5 C per km.
Ideal gas law:
[tex]P=\rho RT[/tex]
Hydrostatic equilibrium:
[tex]dP = -\rho gdz[/tex]
Temperature varies with height:
[tex]T = 288 - 6.5*10^{-3}z[/tex]
[tex]\int_{P_{0}}^{P} \frac{dP}{P} = \int_{0}^{z} \frac {-gdz}{RT(z)}[/tex]
[tex]\int_{P_{0}}^{P} \frac{dP}{P} = \int_{0}^{z} \frac {-gdz}{R*(288 - 6.5*10^{-3}z)}[/tex]
[tex]ln\left(\frac{P}{P_{0}}\right)=\frac{g}{6.5*10^{-3}*R}ln\left(\frac{288-6.5*10^{-3}z}{288}\right)[/tex]
And exponentiating this:
[tex]\frac{P}{P_{0}} = e^{\frac{g}{0.0065R}}\left(1-2.26x10^{-5}z\right)[/tex]
and finally
[tex]P = P_{0}\left(1-2.26x10^{-5}z\right)e^{\frac{g}{0.0065R}}[/tex]
but from a dimensional analysis, I know g/R is not a dimensionless quantity and therefore I should *not* be exponentiating this. I expect an exponential in the final answer but I'm not sure whether this is correct. (Some of you may recognize the initial conditions set this to be the equation used by a standard altimeter).
Did I make any conceptual mistakes? I'm fairly confident about the math.
