I about how to get a pixel value in Java
The discussion focuses on retrieving pixel values from images in Java, specifically using the BufferedImage class. The original code successfully retrieves pixel values for images up to 100 pixels but fails for larger images due to exceeding RGB value limits. Participants suggest implementing a modulus operation on the pixel indices to prevent overflow and maintain valid RGB values. This approach allows for the retrieval of pixel data from larger images without losing color integrity.
  • Java programming language knowledge
  • Understanding of BufferedImage class in Java
  • Familiarity with RGB color model and pixel manipulation
  • Basic knowledge of modulus operation in programming
  • Implement modulus operation in pixel retrieval code to handle larger images
  • Explore Java's ImageIO class for advanced image processing techniques
  • Learn about color models and their implications in image processing
  • Investigate performance optimization techniques for image manipulation in Java
Java developers, software engineers working with image processing, and anyone interested in manipulating pixel data in Java applications.
ohaited
Greetings!
Hey guys, I need help on how can I get pixel value of an image with pixels more than 100px (10x10).
Here the code that I execute in order to get the pixel value
Java:
try{
            File f = new File ("input image location");
            BufferedImage img = ImageIO.read(f);
        }catch(IOException e){
            System.out.println(e);
        //get image width and height
        int width = img.getWidth();
        int height = img.getHeight();
        int count=0;
        for(int i=0; i<height; i++){
            for(int j=0; j<width; j++){
                count++;
                //get pixel value
                Color c = new Color(img.getRGB(j, i));
                int p = img.getRGB(j, i);
                //get alpha
                int a = (p >> 24) & 0xff;
                //get red
                int r = (p >>16) & 0xff;
                //get green
                int g = (p >> 8) & 0xff;
                //get blue
                int b = (p >>0) & 0xff;
                System.out.print("No. "+count);
                System.out.println("Value of Alpha: "+a+ " Value of Red: "+r+" Value of Green: "+g+" Value of Blue: "+b+"");
                p = (a<<24) | (r<<16) | (g<<8) | b;
                System.out.println("Value of Pixel in Binary Presentation"+p);
                img.setRGB(j, i, p);
                    try{
                    f = new File("output image location");
                    ImageIO.write(img, "png", f);
Actually I've tried this code for an image with 100px (10x10). And the value that I've got is quite good. But if I try with an image more than 100px it will not produce any output.
The only output I receive as i attached below
as in the link here
Hope you guys can help me out. Thank you in advance
Technology news on Phys.org
It looks like you're building RGB values from the image position. Since RGB values have a finite max value, your code exceeds that value for larger images.
Oh i see, so is there any alternative I can use to get the RGB values for a larger image that 100px? If you have any suggestion I could use
If you still want to use the image position, you could use the remainder of a modulus check to set the values. That way it resets itself when it gets too big. Of course the colors will suddenly change on the screen where that happens.
Erm it's a bit blurry for me to understand. Can you clear me out using codes or references?
Do you know what the modulus function is?
Yup, I know how the modulus function works. But I don't know where to implement the modulus function in order to reset itself
Right where I showed you that it was breaking. Instead of using i and j directly, replace those values with the modulus of i and the modulus of j.
Oh I see, so after I do the looping, and just modulus the value of i and j before I want to getRGB(),
Java:
                count++;
                //get pixel value
                //get alpha
                //get red
                //get green
                //get blue
is it right?
Yes but where's your modulus?
Good question :oops: erm haven't figure it out yet
That's OK. You're here to learn. You're going to want to replace the values of i and j after the count++ line with new variables that are based on the modulus values of i and j. Does that make sense?
Yeah mate, I'm kinda new here. It kinda make sense to me. So should i do this?
Java:
   int k = i % j;
Erm.. does it work? Or it doesn't help at all?
No, you want two new variables. For i, you want to 'modulate' the value to not exceed the max RGB value.
So i should modulus both variables with odd number or even number ? and it looks like this?
Code:
   int k = i % 2;
   int l = j % 2;
Closer. Instead of 2, you want the max value for an RGB color.
So it would be..?
OK, good luck. I'm sure that you have what you need now.
11K
