I am 47 years old and I trying to learn Mathematics
  • Context: High School
  • Thread starter Thread starter Marcio reis
    Mathematics Years
The discussion revolves around the isomorphism between the additive group of polynomials with integer coefficients, denoted as Z[X], and the multiplicative group of positive rational numbers, Q+. Participants explore the conditions and mappings that could establish such an isomorphism, questioning the exclusion of negative rational numbers and the implications of different types of mappings.
  • Some participants assert that Z[X] and the multiplicative group of positive rational numbers are isomorphic, while others challenge this claim by pointing out the need for a detailed mapping.
  • There is a discussion about the nature of the groups involved, with some clarifying that Z[X] is only a group under addition and Q+ is a multiplicative group.
  • One participant suggests a specific mapping from polynomials to positive rational numbers but questions its surjectivity and injectivity.
  • Another participant notes that the groups (Q+,·) and (Q×,·) are not isomorphic due to differences in their identity elements.
  • Concerns are raised about the conditions required for the mapping to be well-defined and the implications of choosing specific sequences for the coefficients in the polynomials.
  • Some participants propose that the coefficients of the polynomials could be chosen as inverses of prime numbers to satisfy certain properties.
  • There is a repeated emphasis on the need for clarity regarding the definitions of homomorphisms, injectivity, and surjectivity in the context of the proposed mappings.
Participants do not reach a consensus on whether Z[X] and Q+ are isomorphic, with multiple competing views and ongoing questions about the nature of the mappings and the properties of the groups involved.
Participants express uncertainty regarding the specific mappings and conditions necessary for establishing isomorphism, highlighting the complexity of the relationships between the groups and the need for further clarification on definitions and properties.
Marcio reis
What isomorphism do you mean?
Yes, ##\mathbb{Z}[X]## is only a group under addition, and you said multiplicative group of positive rational numbers. As ##0## isn't positive, it can only be the multiplicative group. What I meant was, how do you map a polynomial ##p(X)=a_nX^n+a_{n-1}X^{n-1}+\ldots +a_1X+a_0## into a positive rational number?
Btw: Hello and :welcome: !
Z[X] is the additive group and Q is the multiplicative group of all rational numbers without zero.
Thanks! It's proved somewhere else that Z[X] and the multiplicative group of positive rational numbers are isomorphics. I was wondering why the negative rational numbers must be excluded.
I don't know whether they are isomorphic without seeing the mapping. If there is one, and I still like to see it, then they are isomorphic. The notation should be more detailed like ##\left(\mathbb{Z},+\right)\cong_\varphi\left(\mathbb{Q}^+,\cdot\right)## and ##\varphi(p(X))## should be defined. I assume it is ##\varphi\, : \,p(X) \longmapsto 10^{p(1)}## or so but I do not see surjectivity. Which polynomial belongs to e.g. ##\dfrac{1}{7}\,?##
Another possibility is, that the author uses "isomorphism into" as being a monomorphism and distinguishes it from "isomorphism onto". This happens occasionally but is very confusing in my opinion.
The correct correspondence is:
monomorphism = injective (bad alternative: isomorphism into)
epimorphism = surjective (alternative: mapping onto)
isomorphism = bijective = injective and surjective (bad alternative: isomorphism onto)
So the answer to your question depends on what you have not given us as information.
Note that ##(\mathbb{Q}^{>0},\cdot)## and ##(\mathbb{Q}^{\times},\cdot)## are not isomorphic, since the first group has only one element that squares to the identity (namely ##1##) but the second group has two elements that square to the identity (##\pm 1##). So if ##\mathbb{Z}[X]## is isomorphic to the first group, it cannot be isomorphic to the second group.
The groups are certainly isomorphic.
Suppose f is a function from z[X] to Q+. We must have f(0) = 1. (identities of the groups)
Suppose f(1) = a0, then f(2) must be a02, f(-1) must be 1/a0, and f(n) must be a0n.
The same can be said about f(0)=1, F(X)=a1, F(2X) =a12 etc, so you get all powers of a1
Now all of those powers must be different numbers, or you'll get strange polynomial identies like a0 = a1 X
What condition must the sequence a0, a1, a2, ... satisfy that all of the powers are different. There is a fairly simple example.
It doesn't become right by repetition!
You defined ##f\, : \,\mathbb{Z}[x]\longrightarrow \mathbb{Q}^+## by ##f(1)=a_0## which automatically gives us by ##f(z)=f(1+(z-1))=f(1)f(z-1)=a_0f(z-1)## all other values of constant polynomials. Next you defined - I assume - ##f(x^n)=a_n##. In short we have for ##p(x)=p_nx^n+\ldots +p_0## a function ##f(p)=p_na_n+\ldots p_1a_1+p_0a_0##.
Now we have to check the following properties:
  1. Is ##f## well-defined?
  2. Is ##f## a homomorphism?
  3. Is ##f## injective?
  4. Is ##f## surjective?
As polynomials are given by the sequence ##(p_0,\ldots,p_n)## and a sequence ##(a_n)_{n\in \mathbb{N}}## is chosen in advance to set up the function, there will be no two different images for ##f(p)## possible.
1. Check.
Since we defined ##f## by the rule ##f(p-q)=f(p)f(q)^{-1}## we automatically have a homomorphism per construction.
2. Check.
For injectivity, we must show, that ##f(p)=f(q)## implies ##p=q##. So given ##f(p)=p_na_n+\ldots p_1a_1+p_0a_0=q_ma_m+\ldots q_1a_1+q_0a_0=f(q)##, how do you guarantee that ##n=m## and ##p_j=q_j## for all ##j=0,\ldots, n\,?##
For surjectivity, we must show that for any positive rational number ##\dfrac{s}{t}## there is a way to write ##\dfrac{s}{t}=p_na_n+\ldots p_1a_1+p_0a_0## for suitable ##p_0,\ldots,p_n## by our given choice of ##a_n\,.##How do you find those ##p_j\,?##
My suggestion is to choose ##a_n## to be the inverse of ##n-##th prime number: ##a_0=\dfrac{1}{2},a_1=\dfrac{1}{3},a_2=\dfrac{1}{5},a_3=\dfrac{1}{7},\ldots ##. Can you now check point 3. and 4.?
fresh_42 said:
For surjectivity, we must show that for any positive rational number stst\dfrac{s}{t} there is a way to write st=pnan+…p1a1+p0a0st=pnan+…p1a1+p0a0\dfrac{s}{t}=p_na_n+\ldots p_1a_1+p_0a_0 for suitable p0,…,pnp0,…,pnp_0,\ldots,p_n by our given choice of an.an.a_n\,.How do you find those pj?
Well I'd left that as an exercise for the reader.
Every positive rational number can be written in a unique way as a product of powers of prime numbers. (including negative powers). The polynomials corresponding to [itex]\Pi{p_i}^{a_i}[/itex] is [itex]a_0 + a_1 X + a_2 X^2 + \ldots[/itex]
(where the pi are the primes starting with p0 = 2.
Sorry, my fault, I confused you with the OP.
How do you get the negative coefficients?
The ai can be negative. 1/pia corresponds to -a Xi-1
Ah, yes, mixed up the ##\mathbb Z## and ##\mathbb Q ##, my bad.
  • · Replies 43 ·
9K
  • · Replies 18 ·
