I have mass and velocity, how do I get accel?
  • Thread starter Thread starter knight4life
    Mass Velocity
5 replies · 4K views · last reply
knight4life
The driver of a 1750 kg car traveling on a horizontal road at 110 km/h suddenly applies the brakes. Due to a slippery pavement, the friction of the road on the tires of the car, which is what slows down the car, is 25% of the weight of the car.
(a) What is the acceleration of the car?
(b) How many meters does it travel before
stopping under these conditions?
I keep getting -2.7m/s^2 and i cannot figure out the correct way to do it.
How did you get that value? (Hint: Use Newton's law.)
I don't know, I cannot seem to get that value again.
For part a, you do not even need the velocity of the truck. If you use Newton's law like Doc Al says, you will have -F(friction)=ma --> F(friction)=-ma, which makes sense because the truck is decelerating. You know the force of friction is (1/4)mg so a should equal (-1/4)g m/s^2. Then to find the distance traveled, use the equation Vf-Vi=2*a*delta x, where Vf is final velocity and Vi is initial velocity. In this case, your final velocity will be zero.
Thank you very much. I was trying to figure out using kinematics, and getting very angry. I also was assuming that she wanted the acceleration of the vehicle, not that of the friction force.
That is the acceleration of the vehicle. The friction force is used because it is the only force acting on the truck.
