I need a valve for the quick release of air, help please?
  • Thread starter Thread starter nuclear-boy
    Air Release Valve
The discussion revolves around finding a suitable valve for a homemade airgun project that utilizes a bicycle pump to compress air. The focus is on achieving a quick release of air to propel a projectile effectively.
  • One participant expresses the need for a valve that can open fully and quickly to release compressed air effectively, as standard valves do not meet this requirement.
  • Another participant suggests studying the release mechanism of a CO2 canister, comparing it to a balloon with a pinhole, and mentions that the challenge lies in controlling the release rather than just the speed of air.
  • A participant shares their experience with using a RainBird irrigation valve, noting its effectiveness for quick release of compressed air and its design for high water pressures.
  • Another participant agrees with the use of irrigation valves and references additional resources on spudfiles.com for similar setups.
Participants generally agree that irrigation valves can be effective for the intended purpose, but there are differing opinions on the best approach and mechanisms to achieve a quick release of air.
Some participants mention specific models and types of valves, but there is no consensus on a single best solution, and the discussion includes various experimental approaches and personal experiences.
Individuals interested in DIY airgun projects, pneumatic systems, or those seeking solutions for rapid air release mechanisms may find this discussion beneficial.
nuclear-boy
hi,
im not sure that this is the correct category, or even the correct forum, but I am sure someone will answer my question,
i am intending to build an airgun, which uses a bicycle pump to build up pressure inside a treacle tin (hahaha), and i need a valve, so that when i have compressed the air enough, i will open the valve and the air will come out, but the problem i am having is, a normal valve, doesn't release the air quick enough so it doesn't push the projectile out of the barrel quickly enough, so what i am needing is a valve which can be opened fully, quickly.
please help, thanks in advance, alf
nuclear-boy said:
hi,
reply
study the release of a CO2 canister, in a flip way it is much like a balloon with a pin hole in it
turning it off is a whole other problem really your problem is not so much air speed its resevoir of propulsion or elongation of blast much like the old air daisy bb guns study that mechanism
please reply!
i need to know please.
please help me.
I did an experiment for quick release of compressed air.
Believe or not, the best valve i found that was cost effective was an ordinary
RainBird irrigation valve. These are designed for high water pressures.
These are electrically opened, this released all of the air until the pressure dropped to a certain point. I used the 1" model.
thanks for your help, sorry i didnt reply sooner, i shall try one of those :) thanks again.
i'll see if i can find a picture and post it to photobucket
Like bob671 said a good irrigation valves works fine. There should be some examples of this type of setup over on spudfiles.com.
thanks for all of your help :)
thanks for all of your help, i greatly appreciate it :)
  • · Replies 28 ·
9K
