abdallah306
- 2
- 0
Question 1:
A pressure gauge has accuracy equal +/-2% of full scale. The gauge range is from 0 to 100 kg/cm2. When the gauge indicate 50 kg/cm2 What is the tolerance of this indication?
a) +/- 2 kg/cm2
b) +/- 10 kg/cm2
c) +/- 1 kg/cm2
Question 2:
An instrument system consists of pressure transducer with a range of 0 to 4 bar and a corresponding output of 0 to 10 mV. The output is connected to an electronic processor which converts the output into a current in the range 4 to 20 mA, and an analogue meter which indicates the measured pressure.
If the output of the signal processor is 12 mA. Deduce the indicated pressure?
a) 2 bar
b) 5 bar
c) 2.5 bar
Question 3:
What is the minimum motor power capacity required to drive a water pump to raise water from sea level to a hill of 1000/9.8 m height AMSL to get a flow rate of 1000 cu m/sec. Ignoring pipe losses. If the motor is to be fed by a 11KV feed, using a 1.1 safety factor, what is the size of the used cable using the following details.
mm2 ------- Ampere
16 ------------110
25 ------------140
35-------------165
a) 1M Watt, 25 mm2
b) 1K Watt, 16 mm2
c) 1M Watt, 16 mm2
a) +/- 2 kg/cm2
b) +/- 10 kg/cm2
c) +/- 1 kg/cm2
Question 2:
a) 2 bar
b) 5 bar
c) 2.5 bar
Question 3:
mm2 ------- Ampere
16 ------------110
25 ------------140
35-------------165
a) 1M Watt, 25 mm2
b) 1K Watt, 16 mm2
c) 1M Watt, 16 mm2
