I still don't get it, changing your choice.
  • Thread starter 1MileCrash
  • Tags
    Choice
In summary, the conversation discusses the concept of "changing your choice" in a scenario where you are given three options and one is eliminated. The group agrees that changing your choice increases your chances of winning, despite some confusion about how this works. The probability is explained as being dependent on which door is eliminated and the fact that one door is not eliminated due to the participant's initial choice. The analogy of a million doors is used to illustrate the concept. Ultimately, it is concluded that the probability of winning by switching is 2/3.
1MileCrash
1,342
41
I still don't get it, "changing your choice."
21 is on, you know the old situation where you're given three choices, you make your choice, then one of the incorrect options is eliminated, and the question is whether or not it benefits you to change your choice.
The answer is yes, apparently. But why?
I asked a friend in support of the answer "what if I change it, and change it back?" and he says that this also gives me the benefit. What? That changes nothing regarding the probability other than the words I spoke to change my choice twice.
As far as I can tell, once the third, incorrect option is eliminated, it becomes 50/50 probability regardless of whether or not I change my choice.
Can someone explain?
Mathematics news on Phys.org
Your friend is incorrect, changing your choice, then changing it back does not give you the benifit.
The point is that the "quizmaster" will give you information in regarding your choice. Here's to see why:
Say you choose DOOR A, then there are three possibilities:
1) DOOR A contains the price, DOOR B and DOOR C not.
2) DOOR B contains the price, DOOR A and DOOR C not.
3) DOOR C contains the price, DOOR A and DOOR B not.
Obviously, all these three possibilities occur with probability 1/3. Now, the quizmaster opens a door:
1) DOOR B is opened. (doesn't really matter here, the quizmaster can also choose C)
2) DOOR C is opened. (since B contains the price, and you've chosen A)
3) DOOR B is opened. (since C contains the price, and you've chosen A)
Again, 1, 2 and 3 occur with probability 1/3. Now, let's say you stay with your choice:
1) You win!
2) You lose!
3) You lose!
So the probability of winning is only 1/3, while the probability of losing is 2/3! So staying with your choice is not good here!
Your friend is on crack...
Here's an analogy that can help you conceptually. Instead of just three doors, imagine that there are a million doors. A lot of doors, I know...
The car is behind one of the doors but you don't know which one. What are the chances you will choose the right one? Almost zero but you choose one anyway...
Now, because I'm such a nice guy, I will open 999,998 doors so now there are only two doors left: the door you picked and some other door.
Would you change your guess then?
So essentially the difference between the two possible choices left is that the "quiz master" eliminated one because it is certainly not correct, and other is eliminated just because you chose it, therefore preventing him from eliminating it as a possibly surely incorrect answer himself?
Yes, that makes sense! Do you understand it with that reasoning?
Yes, I do. Here's how I'm seeing it go down, logically.
Choice A is either incorrect or correct. 1/3
Choice B is either incorrect or correct. 1/3
Choice C is either incorrect or correct. 1/3
C is actually correct. I choose B.
A is subject for elimination, and is eliminated. - 0%
B would be subject for elimination, but it is not because I selected it.
So, in my mind that means the probability of B being correct is essentially the product of the probability that it was not eliminated because I choose it and that it was not eliminated because it is the correct answer.
(50%) (2/3) = 1/3 of being correct.
C is not subject for elimination, as B, however C's probability of being correct hinges only on it's probability that it was not eliminated because it is the correct answer.
= 2/3 of being correct.
Am I being clear on that?
Sounds like you get it :smile:
The short, uninteresting answer is that you can pick the wrong door, and the quizmaster will pick the right door for you. You have a 2/3 chance of picking the wrong door, in which case you should switch.
Another way to say it: The only way you can lose by switching doors is if you had the right door in the first place. The probability of that is 1/3. So the probability of winning if you switch is 2/3.
Personally, I think draw a tree diagram helps.
1. How does changing your choice impact the outcome?
Changing your choice can have a significant impact on the outcome, depending on the situation. In some cases, it may lead to a better outcome, while in others it may not make a difference. It ultimately depends on the specific factors at play.
2. Why is it important to consider changing your choice?
It is important to consider changing your choice because it allows for a more thorough evaluation of all possible options. It also allows for adaptability and the ability to make better decisions based on new information or changing circumstances.
3. How do you determine when it is appropriate to change your choice?
The decision to change your choice should be based on a careful analysis of all available information and potential outcomes. It is important to consider the potential risks and benefits of changing your choice and make an informed decision.
4. Can changing your choice lead to regret?
In some cases, changing your choice may lead to regret if it results in a worse outcome than the initial choice. However, it can also prevent regret if it leads to a better outcome. Ultimately, regret is a subjective experience and can vary from person to person.
5. Is it always better to change your choice?
No, it is not always better to change your choice. Sometimes, sticking with the initial choice may lead to the best outcome. It is important to carefully evaluate the situation and consider all factors before making a decision to change your choice.
  • Quantum Physics
  • General Discussion
  • New Member Introductions
Writing: Input Wanted Captain's choices on colony ships
