I thought I understood double integrals until I saw this
  • Thread starter Thread starter 1MileCrash
    Integrals
10 replies · 3K views · last reply
1MileCrash
http://img710.imageshack.us/img710/4764/doubleintegral.png
Now, my understanding of the region is that x spans from the line x = y to x = 1, and that given that parameter, the applicable y's are 0 to 1.
In other words, my region looks like a right triangle with corners at the (0,0), (1,0), (1,1).
Since the region ends at the line x = 1 due to the parameters of x, my understanding is that the upper limit on y is effectively 1, and that running it to 3 doesn't do anything. So reversing the order of integration, I get that y will span from 0 to y = x, and x will span from 0 to 1.
However, when I click "GO tutorial:"
http://img714.imageshack.us/img714/6250/doubleintegral2.png
And their final answer is .99.
This has literally destroyed every ounce of comfort I had with the process. WHY are we running x from 0 to 3 when the order of integration is reversed? That's not in the region!
Im still learning double integrals and my intuition was that the upper limit on y is still 3 but you take the negative of that area and add to whatever's under y=1 so you get a negative value.
Thats what I get when I used the double integral calculator. H/e the solutions you shown on the next page are all positive. So I am confused too, any one else please enlighten, I want to know what's going on too.
1MileCrash said:
Can anyone clarify?
Hey sry if I am wrong about this but I checked the calculation and I believe the answer is wrong it should be
[itex]\int{^1_0}\int{^x_0}\sin(x^2)dydx - \int{^3_1}\int{^3_x}\sin(x^2)dydx[/itex]
I got the same value -0.4343...
I would agree, the region as is is a triangle that flips at x=1 and is upside down until x=3. They reversed integration as if it were just one big triangle.
Can anyone confirm?
I agree with hqib's answer. So 1milecrash, I think you understand perfectly well. I think almost certainly this problem has some typo in its statement. This type of problem usually appears in a calculus text to illustrate that the order of integration can make a real difference in the difficulty of calculating the integral. But here it doesn't help because in that second integral ##\int_1^3\int_x^3\sin(x^2)dydx## you are going to have a ##3\sin(x^2)## to integrate after you do the inner integral, which is as bad as the original problem. Almost surely a typo.
Can anyone confirm?
If we let [tex]F(y) = \int_{x=y}^1 \sin(x^2)\, dx \text{ for } y \leq 1 \text{ and } F(y) = -\int_{x=1}^y \sin(x^2) \, dx \text{ for } y > 1,[/tex] then F(y) can be evaluated in terms of Fresnel functions. Evaluation of the integral
[itex]\int_0^3 F(y) \,dy[/itex] involves hypergeometric functions. Maple gets its numerical value as -0.4343175641. I, personally, do not understand the 'tutorial'.
RGV
*sigh*
I feel better, I guess, but this kind of thing happens too often. It sucks not having confidence in your textbook's info.
I have never run into a double integral where the two limits did not "end" at the same place graphically.
Thank all for your input.
1MileCrash said:
*sigh*
Actually, I think the typo was that the original problem should have been:$$
\int _0^3\int_y^3\sin(x^2)dxdy$$That would also explain their answer.
If we let [tex]F(a) = \int_{y=0}^a \int_{x=y}^a \sin(x^2) \, dx \, dy = \int_{x=0}^a \int_{y=0}^x \sin(x^2) \, dx \, dy = \frac{1}{2}[1 - \cos(a^2)],[/tex] then F(1) = 0.22985 and F(3) = 0.95557. If we want F(a) = 0.99, we need to take a = 1.715009566.
RGV
I don't know about the .99 or where it came from but the third choice they have marked here:
could have come from ##\int _0^3\int_y^3\sin(x^2)dxdy##
