Ice Skating conservation of momentum (conceptual problem)
The problem involves two ice skaters who push off each other while stationary, leading to their movement in opposite directions. The scenario examines the conservation of momentum and the effects of kinetic friction as they come to a halt, with a specific focus on the ratio of their masses based on their displacements and accelerations.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the conservation of momentum in the presence of external forces, particularly friction, and question how this affects the skaters' motion. There are attempts to relate the distances traveled by the skaters to their masses and to clarify the relationship between their times to stop.
The discussion is exploring various interpretations of momentum conservation and the implications of equal accelerations. Some participants are questioning the assumptions made regarding friction and time, while others are attempting to derive relationships between the skaters' speeds and displacements.
Participants note the importance of neglecting friction during the initial push and the need to consider how external forces affect momentum conservation. There is uncertainty about the relationship between the times taken by the skaters to come to a stop, given their different displacements.
Physicscct
Two ice skaters have masses m1 and m2 and are initially stationary. Their skates are identical. They push against one another, as in Figure 7.11, and move in opposite directions with different speeds. While they are pushing against each other, any kinetic frictional forces acting on their skates can be ignored. However, once the skaters separate, kinetic frictional forces eventually bring them to a halt. As they glide to a halt, the magnitudes of their accelerations are equal, and skater 1 glides twice as far as skater 2. What is the ratio m1/m2 of their masses?
m1v1 + m2v2 = m1vo1 + m2vo2
v = x/t
At the beginning, the skaters are stationary:
m1v1 + m2v2 = m1(0 m/s) + m2(0 m/s)
since distance has doubled for skater 2:
m1(x/t) + m2(2x/t) = 0 N(s)
Factoring out velocity
(x/t)(m1 + 2m2) = 0
Therefore, m1/m2 = 1/2
What did I miss?
Physicscct said:
What did I miss?
Is momentum conserved when the external force of friction acts on the skaters? You are told that the magnitude of the skaters' acceleration is the same. Is that important?
For future reference: If you cite a figure, please post it.
Same t?
Yes, momentum is always conserved. I don't know how acceleration is useful though, other than proving that the force of friction on each person is different.
haruspex said:
Same t?
They have different times to come to a stop, as haruspex helped me realize. I just don't know the relationship between both times.
Would it be a 2:1 relationship based on the 2x displacement?
That would mean that m1/m2 = 1
Momentum is not[/color] conserved when there are external forces acting on the center of mass. Here, friction is an external force acting on the CM, therefore momentum is not conserved.
Why? Write some equations down. First you need to figure out the ratio of the speeds of the two skaters. You are supposed to neglect friction as the two push against each other, therefore the net force acting on one skater is the force exerted by the other skater. How can you use this fact to find the skaters' ratio of speeds at the time they separate?
It's a matter of using the equation that has the right combination of variables.
Of distance, acceleration, time, initial velocity and final velocity, which are you trying to find and which three do you know? Pick the SUVAT equation with those four.
  • · Replies 16 ·
  • · Replies 16 ·
