Ideal gases: irreversible transformation
The discussion revolves around an ideal gas contained in a balloon that is subjected to a change in depth within a lake, exploring the implications of heat exchange during an irreversible transformation. The subject area includes thermodynamics, specifically focusing on isothermal processes and the behavior of gases under varying external pressures.
  • Participants discuss the nature of the transformation, questioning the assumptions of isothermal expansion and the calculation of work done by the gas. There are inquiries about the correct expression for external pressure and its constancy during the process.
The discussion is active, with participants exploring different interpretations of the problem. Some have provided insights into the relationship between internal and external pressures, while others express confusion regarding the assumptions made about pressure constancy and the implications for heat exchange calculations.
Participants note potential typos in the problem statement and discuss the implications of rapid transformations on the assumptions of isothermal processes. There is an acknowledgment of the need for clarity regarding the external pressure at different depths.
armandowww
A balloon featured with a negligible thermal capacity contains V_{l}=3l of ideal gas and is immersed in a lake (thermal bath) at the depth of h_{l}=10m beneath the lake surface. If it is brought to the depth of h_{l}=3m, how much is the heat exchange?
I did 2 typos. The first h_{l} has to be replaced with h_{1} and the second with h_{2}... anyway, could you help me please? Thanks
Sounds like a case of isothermal expansion.
yes, it is. But I don't know how to calculate that heat...
Remember that for an isothermal expansion, the internal energy doesn't change, so work done is equal (up to a sign) to the heat transfer. Now, what's the work done by the gas in the expansion?
I was just arrived to this same conclusion. But now, about work integral W=\integral_{V_{1}}^{V_{2}}p_{ext}dV, what is the correct expression I have to use for external pressure? I supposed it is a constant because of fast rising. But what's the value?
W=\int_{V_{1}}^{V_{2}}p_{ext}dV
I'd expect that the internal pressure equals the external pressure. As it's isothermal, that also allows you to work out the volume. You should get an integral involving 1/V, and so some logs out the end.
Surely you'd be right if transformation could be thought as a reversible transformation (a nearly static one). I learned that heat exchange and work done by the system are not function of state and are strictly dependent upon the particular path the transformation has gone across.
Isothermal expansion is reversible
The equation of state PV=nRT keeps always its validity, but the reversibility is not a prerequisite at all. If transformation takes place with rapidity, alas, your last sentence is not satisfactory anymore.
Okay, that is true. However, assuming that in moving the balloon doesn't put significant amounts of energy into the system, the answer will be the same as if the entire process happened quasi-statically.
I was told that the correct calculation is given by using as p_{ext}=const. Nevertheless, this constant is the external pressure corresponding to h_{2}! This is the incomprehensible enigma I'm stuck in!
I don't see why the external pressure is constant -- pressure of the water would be depth dependent.
  • · Replies 16 ·
  • · Replies 17 ·
