Idempotency (Boolean Algebra Theorem)
  • Thread starter Thread starter JJBladester
    Algebra Theorem
8 replies · 6K views
JJBladester
The idempotency theorem X∙X=X is defined for one variable, but does it apply to logic expressions with multiple variables?
Example:
ABC∙ABC = ABC
Is this valid?
Switching algebra single-variable theorems:
X+X = X
X∙X = X
My book gives single-variable and general theorems in its switching algebra section. The single-variable theorem is listed above. The general idempotency theorems are:
X+...+X = X
X∙X...∙X = X
However, it says nothing about whether or not the expression ABC∙ABC = ABC can be made.
Hi JJBladester. The dot is AND, I presume? Could you draw a truth table to test whether A.B.C = ❲A.B.C❳.❲A.B.C❳
Idempotency (Multiple Variables)
NascentOxygen said:
Hi JJBladester. The dot is AND, I presume? Could you draw a truth table to test whether A.B.C = (A.B.C).(A.B.C)
I use the middle dot for AND and the plus symbol for OR. Some authors use the ampersand symbol or even a period to mean AND.
I've drawn the truth table below and it appears that idempotency is valid for multi-variable terms because F3=F1&F2. Am I correct?
My professor claims that "the theorem is for single input and single output logic" but I don't know if that's correct because of my table above...
You know that [itex]X \land X = X[/itex] is true, so why not just let [itex]X = A \land B \land C[/itex]?
milesyoung said:
You know that [itex]X \land X = X[/itex], so why not just let [itex]X = A \land B \land C[/itex]?
I believe what you suggested is valid. This is why I am utterly confused why my professor said that the idempotency theorem is "for single input and single output logic".
I could also re-write the original expression as:
(A∙B∙C)∙(A∙B∙C)=(A∙A)(B∙B)∙(C∙C)=A∙B∙C
Which uses the associativity theorem and then applies the idempotency theorem to single variables.
My book says "In all of the [switching algebra] theorems, it is possible to replace each variable with an arbitrary logic expression" which seems to back up what you said (let X = A∙B∙C).
Your theorem states that [itex]X \land X = X[/itex] is true for any X, where X is a variable that has a truth value. [itex]A \land B \land C[/itex] has a truth value so it follows that [itex](A \land B \land C) \land (A \land B \land C) = A \land B \land C[/itex].
Yep!
NascentOxygen said:
It looks like you have it all figured out.
Yep, thanks to you and miles. You've helped me on various things in the past. As I work my way through my degree I am always pleasantly surprised at the helpfulness of PF members.
I'm not entirely sure what your professor meant, but you were critical and did good work in proving what you thought to be true.
