Identifying external forces for a trolley with oscillating sphere
8 replies · 3K views · last reply
curiousPep
Thread moved from the technical forums, so no Homework Template is shown.
So I have a trolley of mass m that moves on a straight line.
A sphere of mass m, is attached on the trolley with a light string of length a and it is left to oscillate.
Just to give some idea of their positions:
r_trolley = xi
r_sphere = (x-asinθ)i - acosθj (θ is the angle between the string and the vertical - j axis)
Are the external forces the weight of the trolley, mass and the reaction betweeen the trolley and the rack/ground?
Welcome!
Is the sphere oscillating under the trolley?
You determine the limits of the system and which forces are external or internal.
If the system to study is trolley-string-sphere, the weights and the reaction forces are external, while the tension of the string is internal.
If the system is only the trolley, then the string pulls externally from it.
Lnewqban said:
Welcome!
Yes the sphere is hanging below the trolley.
I see, I have been trying to calculate the rate of change of angular momentum (torque) using:
##\dot{\vec{h_{a}} + \dot{\vec{r_{a}}x p = Q,####\Q = sum_{n=i}^\n (r_{i} - r_{p}) x F_{i} ,##
PS:sorry for the equations, if someone can fix it , that wouldb ereally helpful (thank you n advance!)
F_i are the external forces of the system.
In the case that I take p as the combined momentum of the trolley and the sphere, does it mean that the exetrnal forces that I consider are the weights and the reaction force of the trolley?
Thank you!
Thank you!
Weights and reaction force from the ground, yes. The latter may include a horizontal component.
We really need a system diagram and a Free Body Diagram (FBD) to see what is happening.
Which forces are external/internal depends on how you define the bodies for analysis. Which definition of bodies is sensible depends on the specific question being asked.
By considering the trolley, string and mass, the external forces are the weights and the reaction force but the weight and reaction force for the trolley have no effect in the cross product to callculate Q, since r_a - r_p (p is the centre of mass of trolley) is parallel to the direction of F_i (external forces)
As I mentioned in post #4, the reaction from the ground may have a horizontal component.
What is ##r_a##, and how are you defining Q?
To determine which forces are external requires the definition of a system boundary. Often it is useful to include all parts in the system within the boundary, but this is not always true. The choice of system boundary is a matter of experience, but a good choice makes life much simpler.
One the system boundary is defined, then any force that crosses the boundary is an external force, and any force that with its reaction is internal to the system boundary is not an external force. This is where looking for reactions can be very important and the place where d'Alembert's Principle can lead the user astray.
