Identifying Substance Z Using Titration Method: Results and Analysis"
  • Thread starter Thread starter paulhunn
The discussion focuses on the titration method used to identify Substance Z, represented by the reaction Z2CO3(aq) + 2HCl(aq) -> 2ZCl(aq) + CO2(g) + H2O(l). The experiment involved titrating a 250 cm³ solution of Z2CO3 with 0.1 M HCl, yielding a mean titre of 26.8 cm³. Calculations determined that there were approximately 1.134 x 10^-2 moles of Substance Z, leading to a molar weight of 36.1375 g, suggesting that Substance Z is likely potassium. The participant questioned the significance of a 3 g discrepancy from the expected potassium weight, which was deemed too large by another user.
  • Understanding of acid-base titration principles
  • Familiarity with molarity calculations
  • Knowledge of stoichiometry in chemical reactions
  • Ability to use indicators like methyl orange in titrations
  • Study the principles of acid-base titration in detail
  • Learn about the use of indicators in titration, specifically methyl orange
  • Explore stoichiometric calculations in chemical reactions
  • Investigate the properties and identification methods of alkali metals, particularly potassium
Chemistry students, laboratory technicians, and educators involved in analytical chemistry and titration methods.
paulhunn
Hi
I have been set the following problem. Z2CO3(aq)+2HCl(aq) -> 2ZCl(aq) + CO2(g) + H2o(l)
We did the experiment in class to find the amount of HCl it would take to titrate the soloution. First by measuring an amount of Z2CO3 and dissolving it into 250cm^3 of water and using methl orange indicator to know when the reaction had taken place. We did this three times using 25cm^3 samples and i got a mean titre of 26.8cm^3
We are told that it is a group one element and the concentration of the HCl is 0.1
So using the formula M=number of moles/volume in dm^3 i rearranged and got 0.1*0.0268=2.68*10^-3 meaning that it would be 2.68*10^-2 for the entire soloution.
Knowing it will take 2 moles of HCl to react one mole of substance Z it would mean there was 1.134*10^-2 moles of substance Z in the 250ml soloution and knowing the original mass that was dissolved (1.5g) i can use the formula weight(g)/number of moles=molar weight which gave me 132.275g. Then knowing that the rest of substance Z is CO3 i can subtract their weights (12+16+16+16) which gives 72.275 and then halfing to find the molar weight of Z (because in the formula we have Z2) we get 36.1375. which is relatively close to potassium.
Does my method follow correctly?
And is the 3g that i am off from potassium enough to say there was a significant error in working or is it ok?
Thanks in advance
Paul
Approach is correct, error is too large for my liking (but it was very likely potassium as you think).
Ok thanks Borek
9K
11K
17K
11K
9K
