If all space-time already 'exists' then
  • Context: Graduate
  • Thread starter Thread starter DarkMatterHol
    Space-time
The discussion explores the nature of time and space, particularly in relation to concepts such as determinism, quantum uncertainty, and various models of spacetime. Participants question whether all time in the universe is already defined and how this relates to apparent randomness in quantum mechanics.
  • Some participants question whether the idea that "God plays dice with the universe" is an illusion if all time is already defined.
  • There is a suggestion that apparent randomness may stem from the nature of experiments rather than true indeterminism.
  • One participant notes that general relativity allows for multiple spacetimes compatible with the same initial conditions, introducing unpredictability.
  • Another participant argues against the notion that all time is defined, stating that there is no global time function applicable throughout the universe.
  • Models like the "space-time loaf" are mentioned, with some participants expressing uncertainty about their implications and whether they correspond to physical reality.
  • There is a discussion about the potential irreconcilability of the block universe model with quantum uncertainty, raising questions about the nature of a theory of everything.
  • One participant emphasizes that classical theories are deterministic, but this does not validate arguments for the block universe based on relativity of simultaneity.
  • Another viewpoint suggests that time is inherently dynamic, with changes occurring even if viewed from an outside perspective.
Participants express multiple competing views on whether time is already defined and how it relates to determinism and quantum mechanics. The discussion remains unresolved, with no consensus reached on these complex topics.
Some claims rely on specific interpretations of relativity and quantum mechanics, and there are unresolved assumptions regarding the nature of time and space. The discussion also touches on philosophical implications of these models.
DarkMatterHol
...is the impression that "God plays dice with the universe" an illusion?
If all time in the universe is already defined, then, is the apparent randomness a result of the nature of the experiments we can perform?
Does a 'sum of histories', and quantum probability... 'square' with the concept that all time and space exists already? If so how?
Is there a test or thought experiment that could reveal the answer?
If there is no test, then what does it matter, and should we dispose of the notion altogether?
OK, that's several question already, but I'm not sure i could have made my query clear otherwise. thanks.
Why do you think this is the case?
I would actually bring up an interesting point: there is actually a massive element of unpredictability in the framework of general relativity. For any given set of initial conditions (though in some cases even the concept of initial conditions can become tricky), there are actually an infinite number of spacetimes compatible with those initial conditions. Only by imposing stringent conditions on the spacetime can we actually make sure that we get a set of initial conditions that determine a unique set of final conditions.
Well, this is proposed in models like the space-time 'loaf', is it not?
If not then maybe I'm misunderstanding just what IS being proposed in such a model.
It isn't. Nature doesn't provide us with a global time function that partitions the space-time of the universe into "past", "present", and "future" throughout the universe; in other words there is no god given notion of global time that defines "now" throughout the universe. We can only do this relative to a family of observers disseminated throughout the universe that satisfy certain very specific properties.
This is only a model (sometimes called Block Universe, or Block Time). There is not proof yet that this corresponds to physical reality, although there have been many physicists, past and present, who have accepted this model. The model is consistent with all observations of special relativity. However, there may be other models consistent with special relativity that are equally valid.
I see. The model does appear to be irreconcilable with 'quantum uncertainty' model though, does it not?
If it does, wouldn't a theory of everything have to rule out 'block time' or rule out 'uncertainty' as we understand these concepts today?
In my opinion, yes, but, knowing PF, I'm sure that others here will differ with this view.
Yes, but I would suggest looking at previous threads on PF on that topic before reading too much into that. Try these for a start:
https://www.physicsforums.com/showthread.php?t=676547&highlight=spacetime+loaf
https://www.physicsforums.com/showthread.php?t=675194&highlight=spacetime+loaf
No, you're not, but you do need to realize that this is an *interpretation* of SR; it's really philosophy, not physics.
Yes, it is; but as I've pointed out in other threads (including the ones I linked to just now), it's also irreconcilable with ordinary *classical* uncertainty. In order to construct a fully deterministic classical model of the entire universe, you have to have a set of initial data on an entire spacelike slice. We do not have such a data set and never will: the best we can do is the set of data in our past light cone, which only covers a finite portion of any spacelike slice. That data is not sufficient to deterministically predict what will happen at any event that is spacelike separated from us; we can extrapolate from the data in our past light cone to say what *might* happen at such events, but any such prediction basically assumes that nothing of any interest happens outside our past light cone, which is a very extravagant assumption.
This point is glossed over in thought experiments because in thought experiments, we *make up* the data: we just declare by fiat that the events we put into our model are the only events of interest. Of course if you do that, you are basically declaring the initial data on an entire spacelike slice, so of course you can construct a deterministic model. But in the real world, we can't do that, and the argument for the "block universe" based on relativity of simultaneity requires us to assume that we can; otherwise the argument does not go through.
To put it another way, the argument for the block universe based on relativity of simultaneity requires us to assign physical reality to "simultaneous spaces": but that amounts to assuming the conclusion! We don't directly observe simultaneous spaces; we only observe what's in our past light cone. We *construct* simultaneous spaces in our model in order to help us understand what's going on; but they are not required to make predictions and no physical observable depends on them being physically real. The only reason to believe they are physically real is that the "block universe" view says they are; but of course that means you can't use the reality of simultaneous spaces as an argument for the "block universe" view, because you'd be arguing in a circle.
I should clarify, btw, that all the classical theories we have--Newtonian mechanics, Maxwell electrodynamics, special and general relativity--*are* deterministic in the sense I gave above; so if any of these theories were actually true of our world (which they aren't because of quantum mechanics), our world would in fact be deterministic. But that still wouldn't make Greene's argument for the "block universe" based on relativity of simultaneity valid; it would just mean he happened to hit on the right answer, but for the wrong reason.
Space exists, time happens. It is the verb to space's noun. Even if we were to take a slice of time and analyse it as if it had happened all at once we would see the verbiness of time. Objects moved relative to one another. Temperatures changed. Generation and degeneration take place.
Even for an entity outside of time,viewing it all at once it is not determininistic simply already done.
some of your questions above are already answered, but this article may assist you in understanding time in the universe and some of the problems involved in defining a physical basis for describing time.
"On the physical basis of cosmic time"
http://arxiv.org/abs/0805.1947
On that note, this thread is done.
Zz.
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 32 ·
  • · Replies 58 ·
