If f is continuous on [a, b], then f is bounded on [a,b].
  • Context: Graduate
  • Thread starter Thread starter Esran
    Bounded Continuous
The discussion revolves around the theorem stating that if a function f is continuous on the closed interval [a, b], then f is bounded on that interval. Participants explore various approaches to proving this theorem, including the use of compactness and properties of continuous functions. The scope includes theoretical aspects of analysis, proof techniques, and mathematical reasoning.
  • One participant outlines a proof strategy involving the set S defined by the boundedness of f on subintervals, but expresses confusion about the next steps in the proof.
  • Another participant suggests that the proof relies on the compactness of the interval [a, b] and the continuity of f, indicating that the image of a compact set under a continuous function is compact.
  • A different participant emphasizes the importance of establishing that S contains more than one point and suggests applying continuity at the endpoints to show boundedness.
  • One participant provides a detailed proof by contradiction, asserting that if p is the least upper bound of S, then continuity at p leads to a contradiction if p is less than b.
  • Another participant points out a potential misunderstanding regarding the order of symbols in a claim about boundedness, suggesting a need to clarify the implications of the closed interval [a, b].
  • There is a discussion about the logic used to show that f is bounded on [a, y] versus [x, y], with participants seeking clarification on the reasoning behind these steps.
  • One participant humorously notes their intention to respond to their past self, indicating familiarity with the standard proof.
  • Another participant questions whether digging into older posts is appropriate, reflecting on community norms regarding thread activity.
Participants express various viewpoints and approaches to the proof, with some agreeing on the use of compactness and continuity, while others raise questions about specific steps and logic. The discussion remains unresolved, with multiple competing views on how to effectively prove the theorem.
Some participants highlight the need for clarity regarding the definitions and properties of compact sets and continuity, as well as the implications of the closed interval in the context of the theorem. There are unresolved questions about specific proof steps and their logical connections.
Esran
Dear friends,
I just joined the forums, and I'm looking forward to being a part of this online community. This semester, I signed up for Analysis II. I'm a math major, so I should be able to understand pretty much everything you say (hopefully). However, I'd really appreciate it if you try not to be too arcane in your explanations.
So, here's the theorem I'm stuck on.
Suppose f is continuous on [a,b] and S is the set such that x is in S if and only if x is in [a,b] and, (1) x = a or (2) f is bounded on the subinterval [a,x]. Then S is [a,b].
This is what I have so far.
Let S = {x in [a,b] | x = a or f is bounded on [a,x]}
Thus, by definition, S is a subinterval of [a,b].
Because of this fact, S is bounded.
Because S is bounded, S has a least upper bound, call it p.
It follows that p > a must be true.
Because b is an upper bound of S, p <= b.
Now, we employ an indirect argument.
Thus, assume p < b.
By definition, b is the LUB of set [a,b].
From here on out, I'm confused about where to go and what to do. Does anyone have any pointers or suggestions? What approach do I need to take to complete this proof? The only thing I can think of is that it might have to do with f being continuous on an interval implying that f is bounded on that interval. However, I'm not sure how to prove this implication either.
Thank you in advance for your help.
Have you taken analysis I? The proof that the image of a compact set under a continuous function is compact is straightforward, and should be in your book in any case. Once you have that, you're done.
I assume you are speaking of a compact subset of a metric space. In that case, then the theorem will support the OP's goal, since a compact subset of a metric space is necessarily closed and bounded.
Well this is kind of one of the theorems it's good to know a number of approaches to solve.. Such as [a,b] is compact, you wouldn't want to just apply the Heine-Borel theorem, and actually - the proof above that f([a,b]) is bounded is somewhat like the usual proof that [a,b] is compact from first principles..
So first clarify: what you are trying to show basically is that f([a,b]) = {y: y = f(x) for some x in [a,b]} is bounded.
To do this, I think the first thing to do is to establish that S contains more than one point {a}. You can apply continuity (at a) here: Let e = 1. Then there exists d > 0 such that f[a,a+d]) \subseteq [f(a)-1,f(a)+1]. Thus f([a,a+d]) is bounded.
The next step is to show that if M = sup S, then M is in S, i.e. f([a,M]) is bounded: to do that you have to apply the continuity at M as you did at a in above. (I won't write everything out here..)
Then the next thing to show is that M = b. To do this, assume M < b, apply continuity at M, and get a contradiction to the fact that M = sup S...
This is very much like the proof that [a,b] is compact, by taking an open cover {U_i} of [a,b] and letting S = {x: [a,x] has a finite subcover}.
Theorem: If f is continuous on \left[a,b\right], then f is bounded on \left[a,b\right].
Proof: Let \epsilon &gt; 0 and define S=\left\{x: x=a\ or \left[a,x\right] \ is \ bounded\right\}. Clearly, S is nonempty, bounded below by a, and bounded above by b. Thus, there exists p\in\left[a,b\right] such that p=LUB\left(S\right).
We shall proceed with a proof by contradiction. Assume p\in\left[a,b\right). Because f is continuous at p, there exists \delta &gt; 0 such that x\in \left(p - \delta,p + \delta\right)\rightarrow \left|f\left(x\right) - f\left(p\right)\right|&lt;\epsilon, whence it is easy to see that f is bounded on \left(p - \delta,p + \delta\right). Furthermore, we note there exists x\in S such that x\in \left(p-\delta, p\right), which implies f is bounded on \left[a,x\right]. Now, pick y\in \left(p, p+\delta\right); it follows that f is bounded on \left[x,y\right], and thus on \left[a,y\right], wherefore y\in S but y&gt;p, which is a contradiction.
Hence, p=b. It remains to show b\in S. This is established by logic almost identical to that which was used previously to show y\in S.
This completes the proof.
Esran said:
Assume f is not bounded on \left[a,b\right]. Then for some x\in\left[a,b\right], \left|f\left(x\right)\right|\geq M for all M\geq 0.
The right symbols, but not in the right order. The correct deduction would be
for each M\geq 0 there exists an x\in\left[a,b\right] such that \left|f\left(x\right)\right|\geq M.​
You need to make use of the fact that [a,b] is closed, because the theorem wouldn't be true on (a,b).
Very true. I just thought I'd type something out to reply to myself two years ago just for the fun of it. I know the standard proof.
Furthermore, we note there exists x∈S such that x∈(p−δ,p), which implies f is bounded on [a,x]. Now, pick y∈(p,p+δ) ; it follows that f is bounded on [x,y], and thus on [a,y].
[STRIKE]I don't see why we just don't get f is bounded on [a,y] right away from the second part. Why does it only prove that it's bounded on [x,y]?[/STRIKE] See below for revised question
Hence, p=b. It remains to show b∈S. This is established by logic almost identical to that which was used previously to show y∈S.
I don't see how what logic this is supposed to be... Can anyone elaborate?
That was a typo- he meant [a, b], not [x, y]. By the way, this thread was started almost two years ago and the last post before yours was a year and a half old.
Hmm I don't think that's a typo. Isn't he saying that [a,x] is bounded, [x,y] is bounded, and therefore [a,y] is bounded?
Oops that was a very poorly worded question as well on my part... I meant: So we have [a,x] is bounded above from the first part("we note there exists x∈S such that x∈(p−δ,p)"), but I guess I didn't understand why fully because I have trouble seeing why the second part ("Now, pick y∈(p,p+δ)") shows that f is bounded on [x,y] and not [a,y] right away... Could somebody explain why? Thanks
Hmm is digging old posts looked down upon? Should I just make new threads for minor questions like this? Sorry if it is.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 23 ·
