Implement MIMA Function EQL adr - Wondering
  • Context:
  • Thread starter Thread starter mathmari
    Function
2 replies · 2K views
mathmari
MHB
Hey! :o
We have that MIMA (Neumann MInimal MAchine) has the following commands:
Code:
LCD const   :  Load constant
LDV adr      :  Load value from address
LDIV adr     :  Load value indirect from address
STV adr      :  Set value at address
STIV adr     :  Set value indirect at address
Code:
NOT            :   Inverse of the constant-bits
RAR            :   Rotate accumulator right
Code:
ADD adr      :   Addition
AND adr      :   bitwise AND
OR  adr       :   bitwise OR
XOR adr      :   bitwise exclusive OR
Code:
JMP  adr      :   Jump
JMN adr       :   Jump if negative
I want to write a MIMA program that takes the value $2^{23}-24=8.388.584$ to the memory $y$.
We have to take attention at the number of the bits, that we need for the representation of the number in two's complement.
How do exactly do we make the representation? (Wondering)
The other part is the following, or not?
Code:
LDC  const
STIV  y
Then I want to implement the Mima-command EQL adr (equal?) with the other Mima-commands.
We have that for that command it holds the following: $$\text{Accu} \leftarrow \left\{\begin{matrix}
-1 , &\text{ Accu }=M(adr)\\
0 , &\text{otherwise}
\end{matrix}\right.$$
I have done the following:
My idea is to compute -M(adr) and then to add it to Accu, and then to check if it i <0.
And then to compute the inverse of the result and check if it is <0.
Is it correct? (Wondering)
Code:
LCD const
LDV adr
NOT
STV adr
ADD adr
STV adr
JMN x
LDC -1
JMP z
x: LCD 0
z: NOT
   JMN m
   LDC -1
   JMP n
   m: LCD 0
   n: STV adr
Is the implementation correct? Could I improve something? (Wondering)
We have also the following information about the bits:
Address: 20 Bit and Values: 24 Bit
About the representation of the number in two's complement, I have done the following:
We have that $2^{n+1}=2\cdot 2^n=2^n+2^n$.
So, $$2^1=2^0+2^0=1+1 \\ 2^2=2^1+2^1=(1+1)+(1+1) \\ 2^3=2^2+2^2=[(1+1)+(1+1)]+[(1+1)+(1+1)] \\ \text{etc} $$
And we have that $24=2^3\cdot 3=2^3+2^3+2^3$.
We initialize the memory cell $y$ with $1$ and we repeat $23$ times to add the value of $y$ by itself and the result we put it at $y$.
Then we have to subtract three times $2^3$.
How do we do this? Do we have to compute again the $2^3$'s, then compute the inverse and add it to the value that is at $y$ ?
But where do we do these operations? To calculate $2^3$ as above, we have to save the results at each step, or not? But where? Do we consider an other memory cell, say $a$, for that? (Wondering)
Let $x$ be the memory cell where the representation of $23$ in two's complement is, and let $z$ be the memory cell where the representation of $3$ in two's complement is.
I wrote the following code (about the part of $2^3$ I computed it in the way we compute $2^{23}$ and I subtracted it three times from $y$):
Code:
            LCD 1
            STV y
while1:     LDC 0
            NOT
            ADD x
            STV x
            JMN end1
            LDV y
            ADD y
            STV y
           JMP while1
end1:       LDC 1
            STV a
while2:     LDC 0
            NOT
            ADD z
            STV  z
            JMN end2
            LDV a
            ADD a
            STV a
            JMP while2
end2:       LDV a
            NOT
            ADD y
            LDV a
            NOT
            ADD y
            LDV a
            NOT
            ADD y
            HALT
Is this correct? (Wondering)
