Implementing Recursion Function w/o FORTRAN 90 Built-in
5 replies · 2K views · last reply
Sue Parks
I understand that FORTRAN 90 has a built-it recursion function. How could I implement this function without using the built in recursion function?
Fortran:
PROGRAM RECURSIVE_FACT
    IMPLICIT NONE
    INTEGER, PARAMETER :: M = 100
    DOUBLE PRECISION :: fact
    INTEGER :: I
   PRINT *, factorial (N)
        CONTINUE
    RECURSIVE FUNCTION Factorial(n)  RESULT(Fact)
        IMPLICIT NONE
        INTEGER :: Fact
        INTEGER, INTENT(IN) :: n
        IF (n == 0) THEN
              Fact = 1
        ELSE
              Fact = n * Factorial(n-1)
        END IF
        END FUNCTION Factorial
END PROGRAM RECURSIVE_FACT
Don't you need a return statement following the IF statement in your Factorial function?
Fortran:
       IF ( n == 0 ) THEN
              Fact =1
       ELSE
              Fact = n * Factorial( n - 1 )
       ENDIF
       RETURN Fact
WHE I FIRST TRIED YOUR SUGGESTION (RETURN STATEMENT), IT RETURNED 0. Now I have multiple errors: (Here is one). Do I HAVE to use the recursive function?
RECURSIVE_FACTORIAL.f90:20.26:
Function 'factorial' at (1) has no IMPLICIT type
Fortran:
IMPLICIT NONE
        INTEGER :: I,N
        CONTINUE
    RECURSIVE FUNCTION Factorial(n)  RESULT(Fact)   ! CAN I MAKE MY OWN FUNCTION HERE??
        IMPLICIT NONE
        DOUBLE PRECISION :: Fact
        IF (n == 0) THEN
              Fact = 1
        ELSE
        END IF
        RETURN FACT
 END PROGRAM RECURSIVE_FACTORIAL
Also, there was another thread where we discussed the fact that the factorial can get really large and may end up not fitting even in a double precision number...
gsal said:
the word CONTINUE , should really be CONTAINS.
Or you could write the program like this:
Fortran:
    IMPLICIT NONE
    INTEGER :: I
     IMPLICIT NONE
     INTEGER :: Fact
     IF (n == 0) THEN
           Fact = 1
     ELSE
     END IF
