In 4-momentum, why is E the 4th component?
  • Level: Graduate
  • Thread starter Thread starter jaguar7
    4-momentum Component
7 replies · 2K views · last reply
jaguar7
Assuming that c is a "conversion factor" to convert between space and time,
Then, in 4-vector, we have x_1 through x_3, and t, where, x/c = t
x/c = t, (where t = time, c= lightspeed, x = spatial dimension)
If we do what we did to space to get time, to momentum,
p/c = m*v/c = m (x/t) / c = m(x/c)/t = mt/t = m
we actually end up with mass... not energy...
So, there is an inconsistency, and I must have made a mistake somewhere. Can you please describe the method and mathematical proof and context for calling energy the component of momentum that is in the time dimension?
Thank you very much. -- j
hi jaguar7! :smile:
you're assuming that a change of velocity should affect different dimensions equally
but a change of velocity is a rotation between two dimensions (t and x, say), and its matrix is
Code:
cosh  sinh
sinh  cosh
just as a rotation between two space dimensions is
Code:
cos   sin
-sin  cos
… a rotation does not affect dimensions equally! :wink:
Hi, tiny-tim. Thank you for your response.
I'm afraid I'm not very good with matrices. I suppose I'll have to review that. I've been looking for my old books. They've been mysteriously difficult to find after I moved...
I understand that a change in velocity is a rotation between dimensions.
Does that mean I can't use the term velocity in the mathematics? Or that I must use a "4-velocity"? I'm not sure how I would go about doing that... though I would very much like to learn how, somehow... :p
Thank you, again, tim. -- j
hi jaguar7! :smile:
i don't think I've ever seen the term "4-velocity"
(4-momentum and 4-force, yes)
Thanks. =)
Still, though, how would one go about showing mathematically that energy is the 4th component of momentum, I wonder...?
jaguar7 said:
Thanks. =)
You'd just want to show that (E,P) transformed as a 4-vector using the lorentz transform for an isolated point particle.
To do this, you might first prove that the four-velocity is a 4-vector, then consider the prodect mass * 4-velocity, where mass is the invariant mass.
http://en.wikipedia.org/wiki/Four-velocity
I think it is a fourth component because of the simple relation
E2-P2=m02,c=1 I have put.
