In Fermi V-A theory, where does the Weak Interaction occur
The discussion revolves around the nature of the weak interaction in the context of Fermi's V-A theory, particularly focusing on the location of the electron-nucleon interaction—whether it occurs at the surface of the nucleus or at the origin. Participants explore the implications of this positioning for calculations involving weak processes, such as electron capture, and the definitions of nuclear properties like the nuclear radius.
  • One participant questions whether the electron-nucleon interaction occurs at the surface of the nucleus or at the origin.
  • Another participant requests the interaction term or the full Lagrangian density related to the weak interaction.
  • A participant describes the Lagrangian as containing a 'contact potential' and discusses the evaluation of invariant matrix elements in relation to the weak interaction Hamiltonian.
  • There is a proposal to compute the electron density at the origin versus the surface when evaluating cross sections or rates for weak processes.
  • A participant asks for a definition of the "surface of the nucleus," indicating a need for clarity in the discussion.
  • Another participant suggests that the nuclear radius can be estimated using a formula based on the atomic mass number, contributing to the context of Fermi's V-A theory in calculations.
  • One participant mentions the finite nuclear radius hypothesis in the context of the Dirac equation and notes a lack of knowledge regarding its application in weak coupling scenarios.
  • Another participant discusses the measurement of the proton radius and the discrepancies observed in different experimental contexts, such as electron scattering and muonic atoms.
Participants express differing views on the location of the electron-nucleon interaction and the definition of the nuclear surface. There is no consensus on how the Fermi V-A theory is applied in detailed calculations, and multiple competing perspectives are presented regarding the measurement of nuclear properties.
Participants highlight limitations in defining the nuclear surface and the implications of different measurement techniques for nuclear properties. The discussion reflects uncertainty regarding the application of the finite nuclear radius hypothesis in weak interactions.
charlesmartin14
Where is the electron-nucleon interaction? On the surface of the nucleus, or at the origin (R-0) ?
Can you write down the interaction term or, even better the whole, Lagrangian density?
The Lagrangian contains a 'contact potential' , which Fermi assumed is a contact coupling of two vector currents. (prior to when parity breaking was discovered. This is now part of the Standard Model, in some cryptic form.
IMHO, you can not see it obviously in the Lagrangian until you specify the Dirac Spinors explicitly and evaluate the invariant matrix elements The Weak Interaction Hamiltonian element is
\mathcal{H}(x)=-\dfrac{G_{F}}{\sqrt{2}}\left[J^{\mu}(x)L^{+}_{\mu}(x)+h.c.\right]where
J^{\mu} and L_{\mu}
are (in modern parlance) the Hadron and Lepton currents, resp.,
The question is really how to evaluate the invariant matrix element -- at the surface of the nucleus, or at the origin ? That is, say, given some expression that appears in a cross section or a rate
\sum_{fi}\big\vert\mathcal{M}_{fi}\left[p_{ep}\rightarrow i\nabla)\right]\psi_{ep}(\mathbf{x})\big\vert_{\mathbf{x}=0}\big\vert^{2}
or would we compute the electron density at the surface ?
for example, we do compute the rate of Electron Capture , a typical weak process, we can write the capture rate as
\Gamma_{EC}=\big\vert\Psi_{ep}(0)\big\vert^{2}\mathbf{v}^{in}_{ep}\sigma_{EC}
where \big\vert\Psi_{ep}(0)\big\vert^{2} is the electron density at the origin, representing the nuclear charge.
Or , again, should this be the charge on the surface of the nucleus ?
How would you define the „surface of the nucleus”?
Whatever the experimentalists tell me their best estimate it.
The nuclear radius can be estimated using a simple formula
R\sim A^{\frac{1}{3}}
where A is the Atomic mass number.
I am asking how the Fermi VA theory is typically used in very detailed calculations.
Me neither, I have only seen a „finite nuclear radius” hypothesis only in a Dirac equation context (as a perturbative effect). AFAIK, it was described only in section 13.4 of Akhiezer and Berestetskiis book on QED. A finite nuclear hypothesis in case of a weak coupling is not known to me.
Fermi theory is an effective low-energy theory which treats the nucleons as elementary fields.
To define a "proton radius" you need a context, how you measure it. One way is to use electron scattering, defining a charge radius. Another way is to consider the fine structure of the atomic hydrogen transition lines, also defining a charge radius. There's some "crisis" there, because measuring the charge radius with the transitions in muonic atoms, you get a different (smaller result). For a review, see this recent talk from our Nuclear Physics Colloquium:
http://th.physik.uni-frankfurt.de/~hees/np-colloquium/ss17/talk-gao.pdf
  • · Replies 0 ·
  • · Replies 0 ·
