Converting encoder counts to angle and RPM for 128 count motor
4 replies · 2K views
AC130
Hi please see the image that I have attached. The text colored in red is the data I need to calculate.
The encoder has 128 counts per revolution
So to calculate corresponding angle change this I what I did
I divided encoder count in decimal number by 128 which gave the number of revolutions, I then multiplied it by 360 to find the angle change
So for example I did
6350/128 = 49.61 revolutions
49.61 * 360 = 17859.34 degrees
Is this method right?
To calculate no load speed RPM, I divided the revolutions by (time*60) to get it to RPM
So for the 6350 encoder count which gave 49.61 revolutions
I did
49.64/(5.25*60) = 0.1575 RPM
Is this RPM calculation right?
For me it looks as if the RPM is well below and so I must have made a mistake somewhere but I don't know specifically where
That's correct.
To calculate the speed, you must know the sample frequency. Say it is 1Hz. Then you will have 6350 counts per second.
Convert to RPM. ( 128 counts per rev, 60 sec/min ).
The result is close to 3000 RPM.
If the sample frequency were 2Hz, the motor speed would be the double ( ≈ 6000 RPM ).
Hesch said:
That's correct.
Hi can you please tell me where RPM came from?
I know that it took 5.25 sec for the angle change and so frequency would be 1/T = 1/5.25 = 0.1905Hz
But I don't really know how to find RPM
So 49.61 rev. within 5.25 sec, which gives 9.449 rev./sec ≈ 567 rev/min. = 567 RPM. ( 1 min = 60 sec ).
The RPM's in #2 is just an example, not knowing your mentioned 5.25 sec.
Ok thanks I understand it now
