Induced EMF in a rectangular loop with changing magnetic flux
8 replies · 2K views
liamporter1702
A rectangular wire loop, 24mm by 36mm, is placed in a magnetic field. The flux density perpendicular to the loop is decreasing in magnitude at a rate of 0.2Wb/[itex]m^{2}[/itex]/s. Calculate the induced emf around the loop.
The problem is I don't know which equation applies to this question. I know that 0.2Wb/[itex]m^{2}[/itex]/s = [itex]\frac{d\phi}{dt}[/itex] but as far as I was concerned from what I have read so far is that you would need to know the number of loops to get the answer to this question.
I know that the answer is 0.17mV. I managed to get this answer by multiplying the dimensions together 24mm x 36mm = 8.64x[itex]10^{-4}[/itex] then multiply this by 0.2. But I don't understand why this this is the method, if someone could explain this for me I would greatly appreciate it :biggrin:
Let's look at the equation in question: [itex]\int[/itex][itex]\vec{B}[/itex][itex]\cdot[/itex]d[itex]\vec{A}[/itex] = - N*d[itex]\phi[/itex]/dt
Since you're examining magnitudes, let's forget the minus sign. You have B, and the problem states there is one rectangular loop, so you know N. The induced EMF is defined by d[itex]\phi[/itex]/dt, so all that's missing is ∫dA. That's just A, which you calculated.
That's why the given B multiplied by the A you calculated gives your answer, and why N = 1.
As always, it's best to start with the general form of the applicable physical principle. In this case, what is the relationship between induced emf and magnetic flux?
Ah I see where I have gone wrong! Was just a matter of reading the question properly :rolleyes:Thanks a lot guys!
?? Don't look at it too long ...
Edit: Oops! I forgot the d/dt on the L.H.S.!
B is a function of N, so it isn't necessary to include on the L.H.S. It is implied.
Then it's implied in ø on the right-hand side as well, so you'd have to get rid of it there.
N needs to be on the left and right.
The relation is ∫B.dA = ø, and emf = - N dø/dt.
