Inelastic collision, determine ratio KEf/KEi
This discussion focuses on calculating the ratio of final kinetic energy (KEf) to initial kinetic energy (KEi) in completely inelastic collisions involving a moving train and a stationary car, as well as a moving car and a stationary train. The participants clarify that typical mass values for the car range from 500 kg to 3000 kg, while the train's mass is significantly larger. The key formula for the energy ratio is derived using variables for mass and initial velocity, allowing for a general understanding of how mass ratios affect the final kinetic energy.
  • Understanding of kinetic energy formulas
  • Basic knowledge of inelastic collisions
  • Familiarity with mass and velocity concepts in physics
  • Ability to manipulate algebraic expressions for ratios
  • Study the principles of inelastic collisions in classical mechanics
  • Learn how to derive kinetic energy formulas for different mass scenarios
  • Explore the implications of mass ratios on energy conservation
  • Investigate real-world applications of inelastic collision calculations
Students of physics, educators teaching mechanics, and engineers involved in collision analysis will benefit from this discussion.
Anonymous123451234
Consider the following extreme cases for a completely inelastic collision. In each case, determine the approximate ratio KEf/KEi.
a) A moving train collides with a stationary car.
b) A moving car collides with a stationary train.
I do not understand this question, I'm not given masses or velocities. Can anyone explain?
You can use typical values, the answer won't depend on your specific choice. You are asked for approximations. A car might have a mass of 500 kg (very light car) or 3000 kg (very heavy car), but it won't have a mass of 10 kg or 100,000 kg.
Hello,
I suppose KEf/KEi is the ratio Final Kinetic Energy / Initial Kinetic Energy.
You must answer the following questions:
1) What will be the final velocity (approximately) in each case?
2) What will be the final mass of the two bodies in case (a)?
3) What is the ratio Final Kinetic Energy / Initial Kinetic Energy (simplify the fraction till you get a number)?
4) What is the acceptable range for KEf/KEi value?
Rather than plug in numbers (pace @mfb), I would create unknowns: m for the mass of the car, M for the much larger mass of the train, and u for collision speed. Once you have the formulae for the energy ratios, you can consider how they are affected by the mass ratio.
  • · Replies 21 ·
