Inequality proof: If a>b implies a>c then b>c
9 replies · 2K views · last reply
dimitri151
Summary:: To prove a conditional statement on a pair of inequalitites.
Mentor note: Moved from technical forum section, so the post is missing the usual fields.
I feel it should be possible to prove this but I keep getting lost in the symbolic manipulation.
Theorem: If a>b implies a>c then b>c.
Intuitively if every time a number a is greater than a number b it is also greater than a number c then b>c.
Is this correct?
Is this correct?
The "theorem" is not true in general. Suppose a = 3, b = 1, and c = 2.
We have a > b being true, and we have a > c also true, but b < c.
No. It is not correct. Even if you interpret it as (##\forall a \in R, a \gt b \implies a \gt c##) implies (##b \gt c##), the statement is false when ##b = c##.
I think you have overlooked the significance of the "implies". The concept is that if b and c are such that, for all a, a>b implies a>c then it says something about the relationship between c and b.
As @FactChecker notes, the correct implication is b≥C.
So, the original theorem needs to be: $$(\forall a \in \mathbb R, a \gt b \implies a \gt c) \implies (b \ge c)$$
Stuff like this is the reason we need and use the formal symbolic notation.
Ah, it's a tautology in the new form by PeroK:
##(a>b\Rightarrow a>c)\Rightarrow(b\geq c)##
##=[\neg (a>b)\vee (a>c)\Rightarrow(b\geq c)##
##=(a\leq b\vee a>c)\Rightarrow b\geq c ##
##=\neg(a\leq b\vee a>c)\vee b\geq c##
## (a>b\wedge a\leq c)\vee (b\geq c)##
##=b<c \vee b\geq c##
Thanks for your help guys.
Goodness gracious, now I think it IS correct again! Aaarg..
Stop me where I go wrong:
##(p\rightarrow q)\rightarrow r##
##=(\neg p\vee q)\rightarrow r##
##=\neg(\neg p\vee q)\vee r##
##=(p\wedge \neg q)\vee r##
If
##p=a\geq b##
##q=a\geq c##
##r=b\geq c##
Then ##(a\geq b\rightarrow a\geq c)\rightarrow b\geq c##
##=(a\geq b\wedge a<c)\vee b\geq c##
##b<c\vee b\geq c## is a tautology, that is, is always true.
dimitri151 said:
it IS correct
What exactly is "it" here?
You started off with
$$(\forall a \in \mathbb R, a \gt b \implies a \gt c) \implies (b \gt c)$$
which is not true.
In post #7 you showed $$(\forall a \in \mathbb R, a \gt b \implies a \gt c) \implies (b \ge c)$$
And in post #8
$$(\forall a \in \mathbb R, a \ge b \implies a \ge c) \implies (b \ge c)$$
What is the strongest true version?
It may also be instructive to look at the contraposition: $$(c < b) \implies (\exists a, c < a < b)$$ Note that you can replace either or both of the ##<## with ##\le## in the second expression.
Note also that if ##c \le b##, then you can't necessarily find a similar ##a##, because of the case ##b = c##.
