Inexact differential equation with unknown function M(t)
9 replies · 2K views · last reply
I am looking for a general expression for an integrating factor μ(x,t) to solve the following diffential equation for x(t)
[tex]\frac{dx}{dt} = \frac{x - f}{x}[/tex]
f = f(t) is an arbitrary function of t with f > 0 and df/dt < 0
Any ideas?
This ODE is an Abel's equation which is not solvable on it's general form. The function f must be explicitely defined for any further attempt to solve it.
Thanks for the hint regarding the type of the equation. One can set z=1/x which transforms the equation in an Abel's equation of the 1st kind (in x it's 2nd kind). I found several statements that this type of equation is not solvable via integration in general, but that there are special cases where this may be possible - unfortunately w/o any further explanations what these special cases are :-(
MathematicalPhysicist said:
JJacqulin, is there a proof that you cannot solve it for general good profile for $f(t)$?
I think "cannot solve" here means "cannot solve analytically", not "can prove that a solution does not exist even for well-behaved [itex]f[/itex]".
"An Abel ordinary differential equation class generalizing known integrable classes" : E.S. Cheb-Terrah, A.D.Roche, arXIV:math/0002059v3, 23 Feb 2004
Note: in is impossible to say that a today non-integrable ODE wili not become integrable in the futur. All depends of the standard special functions defined in the present and in the futur. A new special function could be studied, published, implemented in the maths sofwares, accepted and recorded as a standard special function. Eventualy, this new special function may allow to solve an Abel's ODE which was not solvable before.
http://fr.scribd.com/doc/14623310/S...tions-Safari-au-pays-des-fonctions-speciales-
Of course, "cannot solve" here means "cannot solve analytically". The ODE considered by tom.stoers is solvable thanks to numerial methods.
tom.stoer said:
I found several statements that this type of equation is not solvable via integration in general ...
What I mean is that the equation
cannot be solved via a general formula like the formula used for exact differential equations. This is what I am looking for and what is not known today, as I had to learn.
If ##f## is a constant, you can solve this in terms of the Lambert W function. I discovered this by plugging it into Mathematica DSolve, but here's a simple way to get the answer. Consider
[tex]t = x - a + a \ln (x - a) + C[/tex]
Then
[tex]\frac{dt}{dx} = 1 + \frac{a}{x - a} = \frac{x}{x - a}[/tex]
which is what we want, so just invert ##t(x)##:
[tex]\tilde{C} e^{t/a} = \frac{(x - a)}{a} e^{(x - a)/a}[/tex]
or
[tex]x = a \big[ 1 + W( \tilde{C} e^{t/a} ) \big][/tex]
Edit: But I guess if ##f## is a constant, the equation was separable anyway.
