Infinite series, does ∑ n/2^n diverge?
The series ∑ n/2^n converges, as established by applying the Limit Ratio Test. Initially, the Cauchy condensation test was incorrectly utilized, leading to confusion regarding the series' behavior. The correct application of the Limit Ratio Test, where lim |a_{n+1}/a_{n}| = 1/2 < 1, confirms convergence. Therefore, the series converges definitively.
  • Understanding of infinite series and convergence tests
  • Familiarity with the Cauchy condensation test
  • Knowledge of the Limit Ratio Test
  • Basic calculus concepts related to limits
  • Study the Cauchy condensation test in detail
  • Learn about the Limit Ratio Test and its applications
  • Explore other convergence tests such as the Root Test
  • Investigate the behavior of series involving exponential functions
Students studying calculus, particularly those focusing on series convergence, as well as educators seeking to clarify convergence tests in mathematical analysis.
utleysthrow
\sum^{\infty}_{n=1} \frac{n}{2^{n}}
Does this series converge or diverge?
By the Cauchy condensation test (http://en.wikipedia.org/wiki/Cauchy_condensation_test) I think this one diverges. But not sure if I am using it correctly.
According to the test,
converges if and only if
\sum^{\infty}_{n=1} 2^{n} \frac{2^{n}}{2^{n}} = \sum^{\infty}_{n=1} 2^{n}
converges, which doesn't.
Thank you for any help.
In the line above, you aren't using the condensation test correctly. For your series, f(n) = n/(2n), so what would be f(2n)?
A test that would be simpler to apply would be the Limit Ratio Test.
Ah, okay, I see it where I went wrong..
Using the limit ratio test
lim \left| a_{n+1}/a_{n} \right| = lim \left| \frac{(n+1)/2^{n+1}}{n/2^{n}} \right| = 1/2 &lt; 1
So it converges...
  • · Replies 17 ·
